pip hancox Samba Member
Joined: February 01, 2005 Posts: 362 Location: Temecula,CA
Posted: Wed Mar 06, 2013 12:25 pm Post subject: Front body/beam mounts? |
I've been searching trying to find an exploded pic that shows the parts that mount the body to the beam on a june 52.
obviously 2 bolts and 2 thick pads between the body and beam but is there any plate under the bolt head or just a washer? any upper rubber pad between the bolt head and body?
thanks in advance,
pip. _________________ DBK!
'49 Standard.
'51 Crotch Cooler.
'58 Kombi.
'65 Notchback.
'64 Ghia.
2 Things.
wifes 2332 '59 lowlight ghia. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Wed Mar 06, 2013 8:46 pm Post subject: |
There is a rectangular plate about 1 inch by 1 1/2 inches that goes between the bolt head and the body. I'd use a washer between those. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
dlware1 Samba Member
Posted: Fri Jan 15, 2016 10:58 pm Post subject: Front body/beam mounts? |
virtanen wrote: |
No upper pads for June '52, just a washer under the bolt. The recangular plate is spot welded to body. |
For Oct 1950, is a rubber pad used between body and beam? what bolt/washer/pad combination is used? I'm now at this stage, and parts diagrams and posts haven't made it clear for me. I have seen rubber pads listed for 1946 - ?? from some advertisers, but they don't seem to agree with posted information. (my separation of body from pan was back in the 80's & some of the details have been forgotten or lost)
Thanks for any clarification anyone can offer.
Doyle |
Posted: Sat Jan 16, 2016 9:16 am Post subject: Re: Front body/beam mounts? |
Thanks, Mika.
Same thickness as rear pads? I haven't found a source for front pads, but I can make some if I know what thickness they are.
Doyle |
Posted: Sat Jan 16, 2016 10:51 am Post subject: Re: Front body/beam mounts? |
That link gave the answers I needed - pics & measurements. My searches never gave me that one.
Again, many thanks!
Doyle |
