tlambert Samba Member
Posted: Tue Nov 18, 2014 6:55 pm Post subject: |
That's right it will get there.
Yeah screw the cold. We are having cold nights here lately.....at least cold for us. (SC) |
wcfvw69 Samba Purist
Posted: Tue Nov 18, 2014 7:16 pm Post subject: |
Wow.. that is looking really, really good.
One thing I've never understood clearly. The Germans never painted the magnesium transmission cases yet the transmission builders do? I get that it prevents corrosion yet my 69 vert is running it's original, un-touched transmission in raw form w/out any corrosion on it.. Just talking out loud. _________________ Contact me at [email protected]
The Samba member since 2004.
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Tue Nov 18, 2014 7:53 pm Post subject: |
In fact they did paint some of them. The cars that were destined for colder climates where they were more prone to corrosion from road salt they were painted by the factory. I've seen many og transaxles with traces of factory black paint.
In case anyone disputes that (I know there is a lot of controversy on the subject).. ,here's my OG 52k miles trans that I removed, this car still had the og BOGE shocks, everything was original, obviously never rebuilt. Car was purchased new from a dealer in Minnesota where they salt the roads. I wiped off some dirt and voila! original factory black paint. nuf said.
_________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
Posted: Sat Nov 29, 2014 10:15 am Post subject: |
Got the engine up from the basement and heading out to the garage.
Posted: Sat Nov 29, 2014 8:41 pm Post subject: |
Nice Dave looks great.
What is the round port on the front of the carb at the choke? I don't think I've ever seen one like that. |
Posted: Sun Nov 30, 2014 6:26 am Post subject: |
my carb is a 28 PICT. It's the choke pull off vacuum chamber. same function as the triangle diaphragm on a 28PICT1 but an earlier carb. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
laneven28 Samba Member
Joined: January 09, 2007 Posts: 312 Location: Cedar Hills, Utah
Posted: Sun Nov 30, 2014 8:22 am Post subject: |
Just read the entire thread. Love the car, and what you're doing with it! _________________ 1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop |
Posted: Sun Nov 30, 2014 12:32 pm Post subject: |
laneven28 wrote: |
Just read the entire thread. Love the car, and what you're doing with it! |
Thanks! I'm also a follower of your Turkis build. Can't wait to hear what you do with the Judson you just scored also. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Posted: Tue Dec 02, 2014 7:08 pm Post subject: |
This past weekend I got the engine mounted to the trans and got it prepared to fire up for the first time and do the break in procedure. First I removed the rocker arms and spark plugs, I hooked up a makeshift oil pressure light using a dome light. got all the temporary wiring hooked up. I added Brad Penn break in oil. cranked it over for about ten seconds and oil pressure light went out! Awesome, so far so good..
After that I took a short break so not to rush and forget something. So I installed the rocker arms and adjusted valves, gapped the plugs. for some reason I didnt have new spark plugs installed. I guess I just threw in an old set to keep dirt out. I figured they would still work good enough till I could get new ones. Poured a teaspoon of gas down the carb and cranked it and it fired up for a couple seconds..Cool!
next step... hook up a gas can and fire it up.. at 2000 RPM for 20 minutes. sound nerve racking but it has to happen so I went for it. couple seconds in had gas pouring out the vent tube.. shut it down, changed the float needle and seat, round two.. fired up went to 2000 rpm, fuel hose pops off shoots gas all over my nice new clean engine. Damn old hose been on there for a couple years drying out so I got a couple hose clamps to hold it for now. round three, couple seconds in.. gas pouring out the vent tube again... too much fuel pressure in the rebuilt pump, got another pump flange gasket and doubled them up to lower pressure.. seemed to work. OK, round 4 finally got up to 2000 rpm waiting ...waiting... ok looks good,.. start my phone timer for 20 minute count down..so far so good. grabbed my phone to take video of it running and a couple seconds later..phone dies..crap! that's my timer. While engine is screaming on, I had to find a charging cord to plug in my phone. got phone on charger.. engine still screaming away. but I had no idea for how long so I guessed about 5 minutes so far and no issues.
checked phone after what I thought was about ten minutes and it said "timer done". that was the longest and fastest twenty minutes ever. weird!. kicked engine down to idle and was running a little rough. tried to adjust carb. didn't help, pulled off number two spark plug and didn't change idle at all. so i figured Id shut her down for the day and get back to it the next day to check valves and timing and get new spark plugs.
So yesterday I rechecked point gap, timing, valves, new plugs, new fuel hose, carb mixture screw, everything set to fire up.. cranked it and it ran perfectly smooth and quiet, let it idle till warm and fine tuned carb.
What a good feeling and a huge milestone. here's a picture of it a few minutes before firing it up
bigdog1962 Samba Member
Joined: August 11, 2010 Posts: 1586 Location: Augusta, Georgia
Posted: Wed Dec 03, 2014 5:45 am Post subject: |
I'm jealous...but in a good way. Love the pictures and story. Unless I missed it somewhere, how did you handle the bumpers? I can't imagine they're original unless you had them rechromed. What's the secret? |
Posted: Wed Dec 03, 2014 6:19 pm Post subject: |
Thanks bigdog, and yes, the bumpers are og.. but I've been piecing them together for 12 years. Every time I find another component better than what I have, I trade up. They look really good from 10 feet but there are minor imperfections here and there. I still need to take them apart to paint the brackets and back sides and I'll give them a good polish on my buffer wheel before the final install. I'm not ruling out getting them re-chromed if they bother me enough after the car is complete but I'd rather have og with some flaws than cheap repops. WW's are nice but big $$. I'd rather re-chrome ogs for the money. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
Posted: Sat Dec 06, 2014 3:43 pm Post subject: |
here are some detail shots.. NOS fan belt
hope I can keep it this clean for a little while (excuse the wheel rim)
bugpartslou Samba Member
Posted: Sat Dec 06, 2014 3:46 pm Post subject: |
all I can say is WOW!!! |
56TIMOTEO Samba Member
Posted: Sat Dec 06, 2014 11:18 pm Post subject: |
Pretty exciting stuff, nothing like it when a car comes back to life!! |
Posted: Sun Dec 07, 2014 7:29 am Post subject: |
freshened up my jack
alexvw1963 Samba Member
Joined: November 02, 2006 Posts: 91 Location: Berkeley heights nj
Posted: Sun Dec 07, 2014 6:55 pm Post subject: |
It's looking really good,keep up the good work !!! |
Posted: Mon Dec 08, 2014 7:23 pm Post subject: |
alexvw1963 wrote: |
thanks Alex. how's yours coming? just checked out your gallery and your 59 is awesome. lets see some more pics of your vert. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sat Dec 13, 2014 6:20 pm Post subject: |
Knowing how long you have been collecting parts, how long you have been working on the car and your attention to detail ...I wouldn't have expected anything other than a stellar job but i think you have surpassed stellar!
I can't wait to come by and see it in person!
Great job, Dave! _________________ Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92 |
Posted: Sat Dec 20, 2014 1:16 pm Post subject: |
thanks, Jerry!
here are some recent detail pictures
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Wed Dec 24, 2014 3:49 pm Post subject: |
What a cool idea! Can I ask where you got this accessory light? Thanks! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
