end float shims
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
rustydubnz
rustydubnz is offline
PostPosted: Sat Mar 30, 2013 3:32 pm    Post subject: end float shims Reply with quote
hi, i have read and watched a lot about setting the end float so understand that process, however i am a bit confussed about moving the crank in and out.
when i move the fly wheel out it rotates a couple of degrees, i am assuming that it is because of the crank/cam gear meshing and it moves about .035"(2 shims fitted). if i dont let the crank rotate i can get anything less than that.
the crank,flywheel,casings are the same as before the rebuild.
should i be letting the flywheel rotate?
Dale M.
Dale M. is offline
PostPosted: Sat Mar 30, 2013 4:43 pm    Post subject: Reply with quote
The crank rotation does not mean a lot as long as final end play (float) is .003 to .005 ...
Dale
Lives his life vicariously through his own self...
1970 "Kellison Sand Piper Roadster" For Street & Show.
mcmscott wrote:
...... and not keyboard jockeys that just have high post counts
rustydubnz
PostPosted: Sat Mar 30, 2013 5:47 pm    Post subject: Reply with quote
so you mean end float WITH the crank rotation then?
Dale M.
Dale M. is offline
PostPosted: Sat Mar 30, 2013 7:32 pm    Post subject: Reply with quote
NO... I mean rotation is non issue.... .003 to .005 total movement.... period.... IF you just do a push-pull on crank/flywheel to set end float there is not going to be enough rotation to make any difference....
Dale
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sat Mar 30, 2013 8:04 pm    Post subject: Reply with quote
Try turning the engine over to where the crank is at top dead center, or bottom dead center, then it usually doesn't rotate when you measure the endplay.
SRP1
SRP1 is offline
PostPosted: Sat Mar 30, 2013 11:24 pm    Post subject: Reply with quote
Pull the rockers off. The crank will not rotate now when you move the crank laterally.
Phenix Industries AN fittings- Stocking dealer
Braided hoses, AN Fittings, Fire Sleeve, E85 compatible braided AN line!!!- All 100% made in the USA!!!
Justice Brothers of San Diego
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
