Cschenkel Samba Member
Joined: February 20, 2013 Posts: 114 Location: San Bruno, CA
Posted: Tue Nov 19, 2013 7:16 pm Post subject: |
KTPhil wrote: |
Cschenkel wrote: |
any one know how the CIP1 exhausts are? thinking of going with an aftermarket exhaust until I can find some heater parts or refurbish mine and make it not leak into the car. |
I like the stock setup for a stock displacement engine. Parts are available, and it is actually a pretty good system, with what amounts to an equal-length header inside the sheet metal outer jacket.
And you get quiet and heat. I like the sound-- not so boomy and it lets you hear all those wonderful mechanical noises-- almost Porsche-like in tone. |
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-D-2033-10
would this work with stock heat exchangers? just to put different mufflers on. |
Bobnotch Samba Member
Posted: Tue Nov 19, 2013 7:22 pm Post subject: |
KTPhil wrote: |
Cschenkel wrote: |
Having some trouble when starting in the mornings when the engine is cold, it likes to load up on fuel and the exhaust smells mostly of unburned gas, the idle also takes a bit to speed up, its very slow when starting. I cant locate the cold start injector, being a 68 is it located in a different spot than other models? |
If you are in California, it's not your cold start system. That system ONLY works at very low temperatures and while cranking. It does not squirt at idle even when cold. |
The Cold Start system doesn't even begin to work until the outside air temp is below 40 degrees F. So I doubt that's yout problem.
However, it sounds like you are running rich, and this can be the AAR, or even a VR trying to go bad (less than 14 volts causes the system to run rich). But I think you replaced the VR last year, so that shouldn't be it.
Jim Adney actually recommends trying to drive off right away, and let the car warm up at reduced speed on the road. He's thinking that some of the warm up issue is unburned fuel, that needs some engine heat to help burn off.
How does the car run once it's warmed up? _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Nov 19, 2013 7:28 pm Post subject: |
Well, that's just a standard type 3 BugPack header. You still need to buy some sort of muffler for it. A better choice is to just get the OTT (over The Top) from ISP West. The best choice is tolook thru the classifieds for a complete stock muffler. And yes, either will work with heat exchangers. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Nov 19, 2013 8:07 pm Post subject: |
Bobnotch wrote: |
How does the car run once it's warmed up? |
runs fine after warmed up, had to do some machining in the aar to make it work correctly, PO had warped it somehow. |
Posted: Tue Nov 19, 2013 8:21 pm Post subject: |
Bobnotch wrote: |
A better choice is to just get the OTT (over The Top) from ISP West. |
all are out of stock |
Posted: Wed Nov 20, 2013 7:11 am Post subject: |
Cschenkel wrote: |
Bobnotch wrote: |
You could try Kymco. They originally built the 1st OTT's. They're in California too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Nov 20, 2013 10:00 am Post subject: |
Bobnotch wrote: |
Cschenkel wrote: |
Bobnotch wrote: |
You could try Kymco. They originally built the 1st OTT's. They're in California too. |
http://www.thesamba.com/vw/classifieds/detail.php?id=1031687 this one? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Nov 20, 2013 10:43 am Post subject: |
'1600 Super' sounds like a Super Beetle exhaust. Call them and ask about a Type 3 over the top. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Nov 20, 2013 7:28 pm Post subject: |
Mike Fisher wrote: |
'1600 Super' sounds like a Super Beetle exhaust. Call them and ask about a Type 3 over the top. |
Yup, that's a t-1 header.You need to call and ask about a t-3 unit. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Dec 20, 2013 1:07 am Post subject: |
The car was running pretty good except it was using a lot of fuel, we dug into it and found that the wires to the injectors were switched between injectors. 3 was on 4 and 4 on 3, 2 was on 1 and 1 on 2.we were quite surprised the car was even running the way it was. now its running better. I got the Bentley manual as an early Xmas gift and some louvered eyelids |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Fri Dec 20, 2013 2:00 am Post subject: |
Cschenkel wrote: |
Noooooooooooo....
Whatever floats your boat man. _________________ 69 Fastback Build
Berg5 Build |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Fri Dec 20, 2013 5:54 am Post subject: |
Welcome to the dark side, have some fresh baked cookies. Great build & keep up the great work. I think you have a great helper in this project. |
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
61 BUS Samba Member
Joined: January 05, 2005 Posts: 692 Location: Tucson, Arizona
Posted: Fri Dec 20, 2013 9:00 am Post subject: |
Nice car, Chris! I just recently purchased a 66 fastback in Granada Red. It's the third fastback I've owned. My first car was a 69 Fastback in Savannah Beige. Keep yours fuel injected. It will be a very nice driver once you get past the minor repairs that are typical of an older car. You're now officially hooked on air cooled VWs. _________________ 61 Bus, 71 Bus, 76 Beetle, 2013 Fiat 500 Abarth, 47 Plymouth Business Coupe, 58 BMW Isetta 300 |
Posted: Wed Feb 19, 2014 12:50 am Post subject: |
finally found some time last week, kinda had to because she wont run now replaced the wiring harness and brain for the fuel injection, now it wont start, the injectors aren't spraying but with starting fluid it will run for a few seconds. I figured its about time to replace the ignition switch because it was sticky and temperamental, took it out and the turn signal decided to pop apart and spring a couple pieces around the car, managed to get them back in except the wire spring for the signal turn off, the ignition switch I picked up didn't fit into the housing so I hooked up the old turn signal and it wouldn't even give power to anything, I got all the wires hooked up to the right place except i think the long red wire is in the wrong place, I have it hooked to the headlight switch, which seems wrong but that's where it was hooked up when I took it out, so that's where I am stuck, have a new ignition switch that should fit in the housing. Also had to change the oil because the gas had seeped into it. Anyone have any ideas on whats going on? or have a turn signal switch? |
Posted: Wed Feb 19, 2014 8:12 am Post subject: |
Cschenkel wrote: |
Since you have a 68, all of the steering column parts you need (TS switch, ignition, etc...) should be available. They're shared with 68 and 69 beetles and ghias too.
As for the FI, I'd probably put the old ECU back in it, and try it. It sounds like you've got a couple of things going on, and you really need to wrap up a couple of them before moving on too far. I only say that, as the FI won't work, unless the ignition switch is hooked up (yes, it gets power from the headlight switch), but you could also have a bad ground on 1 of the 2 realys that's keeping it from working too. You might need to run Tram's trouble shooting pages to get to the root of your problem. It could even be your "new" harness, unless it was made by Joe.
Gas mixed with the oil, due to the injection system pumping fuel, but not actually running. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Feb 19, 2014 10:07 am Post subject: |
Tried switching the ecu's back and forth same thing, wiring harness is a used one but was in better shape than mine, actual VW connectors. This Sunday I'll have time to work on it again. On the headlight switch it looks like there's two spots to hook it I assume I just have it hooked to the wrong spot because they're right next to each other. |
Posted: Wed Feb 19, 2014 11:22 am Post subject: |
Make sure your fuel Return line isn't plugged or that will force gas into the oil and prevent it from starting. BTDT _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Feb 19, 2014 11:52 am Post subject: |
Bobnotch wrote: |
Cschenkel wrote: |
Gas mixed with the oil, due to the injection system pumping fuel, but not actually running. |
I've checked both the relays they're getting power to them and the ECU is getting power through the two wires, what's a cause of the injectors not squirting, could they be all clogged up because it was flooded with fuel? |
Posted: Thu Feb 20, 2014 8:04 am Post subject: |
Cschenkel wrote: |
Bobnotch wrote: |
Cschenkel wrote: |
Check the trigger point plug and wires.
About half way down on this page, is a resistance check you might want to perform. It'll tell you IF you have any breaks in the FI wiring harness.
http://members.rennlist.com/pbanders/djetparts.htm _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
