Cracked a cylinder - too much boost
Page: 1, 2, 3, 4  Next
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
risk
risk is offline
PostPosted: Mon Apr 01, 2013 11:25 am    Post subject: Cracked a cylinder - too much boost Reply with quote
Well I learned my lesson..
Engine was only ran for a couple miles after the blowout to get it home.
I know the cylinder is junk, but are the rings ok to run? I haven't inspected them yet..
I'm currently trying to source a new cylinder, but it looks like I'm gonna have to buy a full set since I can't seem to find anyone selling them individually. Should I go ahead and get new rings?
Tramsdisciple
Tramsdisciple is offline
PostPosted: Mon Apr 01, 2013 1:39 pm    Post subject: Reply with quote
Yes get new rings and also look closely at the ring lands. I pup 100 low lead in my turbo and it cracked 2 barrels and the ring land on one piston. Do yourself a favor and get new again and use more octane or less boost. Boost is addictive so better just run race gas.
63 turbo ragtop bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=545985
03 passat
67 sunroof squareback
Vee Dub Nut
Vee Dub Nut is offline
PostPosted: Mon Apr 01, 2013 4:46 pm    Post subject: Reply with quote
Curious.. How much boost and what brand jug? Run lean, detonate?
Fightin' Texas Aggie Class of 2006
67 Beetle (1500sp, 1776dp, 1915NA, 1915T fuel injected, 2276NA, 2276T fuel injected, 2084NA, what's next??)
78 Transporter (FI 2.0L T4)
See all my VW pics on Instagram @ vee_dub_nut
white/red_68
white/red_68 is offline
PostPosted: Mon Apr 01, 2013 5:39 pm    Post subject: Reply with quote
Get mahle cylinders
New Rings....
Check your Mixture.....
You can go fast but, I am faster!
white/red_68
Get mahle cylinders
New Rings....
modok
modok is offline
PostPosted: Mon Apr 01, 2013 5:57 pm    Post subject: Reply with quote
what size cylinder?
Glen Urban
risk
risk is offline
PostPosted: Mon Apr 01, 2013 5:59 pm    Post subject: Reply with quote
94mm Mahle
I wasn't data logging, so I'm guessing 25-30 psi
modok
modok is offline
PostPosted: Mon Apr 01, 2013 6:11 pm    Post subject: Reply with quote
Looks like you can get the AA brand cylinders for about 130$
Mahle is getting scarce, especially in that size
Glen Urban
veedubcrazy
veedubcrazy is offline
PostPosted: Mon Apr 01, 2013 6:23 pm    Post subject: Reply with quote
I *think* I have a set of 94mm barrels in the back shed just sitting in the box. I needed long barrels for my 2387 and the stock ones just got put up. Lemme go check... If they check out, you can have them. Hang on...
1967 Deluxe Sedan
www.bayareavwclub.com
risk
risk is offline
PostPosted: Mon Apr 01, 2013 6:24 pm    Post subject: Reply with quote
Nice!!
veedubcrazy
PostPosted: Mon Apr 01, 2013 6:38 pm    Post subject: Reply with quote
Okay, look here. The barrels, with no other marking saying are 94mm, measure out to 3 11/16" in the widest spot I can see. They are marked 1 thru 4 and (here is an added bonus and to my surprise) that there are matching pistons rings in the barrels. I have no idea why but they are. The long barrels came in a AA box so I put the other barrels in the box. They are used so the barrels and rings are matched. I have no idea how many miles there are but when the itch took for a 2387, it did not take long. If you want pix, I can do that...
1967 Deluxe Sedan
veedubcrazy
PostPosted: Mon Apr 01, 2013 7:11 pm    Post subject: Reply with quote
Sent you pix. If you want them, pay the shipping and viola! I can send them whenever...
1967 Deluxe Sedan
turbo2go
turbo2go is offline
PostPosted: Mon Apr 01, 2013 8:17 pm    Post subject: Reply with quote
how much deck are you running?
If you can't win,be spectacular!
risk
risk is offline
PostPosted: Tue Apr 02, 2013 9:00 am    Post subject: Reply with quote
I believe it was around .085" plus I have a .040" copper gasket in there. I'll measure it tonight. I'm guessing that having that much deck makes it more prone to crack?
veedubcrazy
PostPosted: Tue Apr 02, 2013 10:01 am    Post subject: Reply with quote
Barrels sent... Cool
1967 Deluxe Sedan
risk
risk is offline
PostPosted: Tue Apr 02, 2013 10:04 am    Post subject: Reply with quote
My hero!!
veedubcrazy
PostPosted: Tue Apr 02, 2013 10:07 am    Post subject: Reply with quote
Hardly. I just dont throw anything away. Pure chance I clicked this thread. Just use them, I could not.
1967 Deluxe Sedan
cdupuy
cdupuy is offline
PostPosted: Tue Apr 02, 2013 5:20 pm    Post subject: Reply with quote
Think I would keep the deck in the Head not the Cyl. Just Sayen.
risk
risk is offline
PostPosted: Wed Apr 03, 2013 9:20 am    Post subject: Reply with quote
Pulled the 3-4 side apart last night... #4 was cracked too, almost the entire length of the barrel.
75smith
75smith is offline
PostPosted: Wed Apr 03, 2013 9:24 am    Post subject: Reply with quote
I would say too much deck; especially with an extra .04 shim-what size is your head CC?
My 1975 Beetle Build Updated 8-21-12
My engine build
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 1 of 4
