brimfull Samba Member
Joined: December 15, 2004 Posts: 42 Location: nottingham,uk
Posted: Sun Apr 20, 2014 1:30 am Post subject: |
Thanks for the link to that guys work some great pics of bits I've gotta do to mine in there
On one of the restos there's some inner fender work being done and a part I've never seen before as a repair panel- anybody know please if it was available or if it's an nos piece? Tried to copy the link but I can't, bug it's the piece of inner fender that looks like the same shape as a beetle rear fender if that makes sense? |
Dlglobal1 Samba Member
Posted: Sun Apr 20, 2014 7:58 am Post subject: |
brimfull wrote: |
Which inner piece are you referring too? If its the red piece on the inner rear wheel well, that was a repair panel he found from a guy here in DK. NLA I believe, but I have seen them pop up from time to time on eBay. He really does some good clean work and is the best in DK from what I am told by various vw folks here. _________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
Posted: Sun Apr 20, 2014 10:55 am Post subject: |
Yes thanks, that was the part. Never seen one before but will have to keep my eyes out for one |
Posted: Mon Apr 21, 2014 11:16 am Post subject: |
Can anybody tell me if this section of the rear wheel well and forward section is the same size for all years notch and fastbacks? I have found some NOS repair panels, but want to be sure they will fit (or be close enough) before I buy. The guy has allot of early panels, early heater channels etc, that he may have aquired for his Notch, but I am not sure if they will fit my year. Thanks all!
1969 Bug
1972 Bug
Bobnotch Samba Member
Posted: Mon Apr 21, 2014 5:05 pm Post subject: |
Dlglobal1 wrote: |
David, that section is similar on the 3 body styles thru the years, but the early cars used a different heater outlet and lower hinge arrangement from your car. You could have your body guy adjust it though, so it would work for your car. It would probably be cheaper to have that done, rather than ship a later section over from the states.
I only say that, as early Squares and Notchbacks used a lot of the same parts up until 66, when the Square and Fastback started sharing parts and the Notch became it's own car like a T-34. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 21, 2014 11:06 pm Post subject: |
Perfect! Thanks Bobnotch! _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Mon May 05, 2014 4:04 am Post subject: |
I've posted a WTB ad for this section - if anyone in Europe has a donor piece, please contact me as I'm ready to buy. I do have a possible lead on a piece in the USA just waiting for a shipping quote.
1969 Bug
1972 Bug
Posted: Mon May 12, 2014 6:59 am Post subject: |
Has anybody used the side marker seals (both lens and body) from ISP? Do they fit correctly?
I tried to clean mine this weekend, but they are pretty far gone. _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Fri May 30, 2014 3:22 am Post subject: |
Picked these up recently and they are a perfect fit for the repair areas on the rear inner fenders. Body guy coming to assess the project on Monday...getting really excited now making some progress...still searching for the front inner fender section for the driver side.
1969 Bug
1972 Bug
Posted: Fri May 30, 2014 12:18 pm Post subject: |
Dlglobal1 wrote: |
Those should fix quite a bit of your rust. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Jun 03, 2014 12:30 pm Post subject: |
MonT3 wrote: |
The intent of my post was to think about how much time it would take to work a piece in versus replacing the whole area with four cuts. May be cheaper to do. It's worth a question being asked of your preferred body shop that would be able to pull this off. It would seem to me to be cheaper (don't like that word) or reasonable to explore your options before getting a bunch of metal to piece-meal in. The previous owner tried and you see what took place. Not putting his efforts down but if you have the chance and finances work with both the securing the piece and getting it grafted in...
Explore it and see what the shop has to say. Just some thoughts. |
I met up with the guy who will do the repair work yesterday. Monte you were spot on. He basically said its much easier to cut and replace the full sections in from a donor car. We also decided to pull the body off and do it proper.
Luckily, I have all the pieces for the rear inners. Now just looking for good front end sections. He really knew his stuff so I'm confident the work will be top notch and my fasty will be saved! He said in general it was one of the cleanest original cars he's seen, so that made me feel kinda good after months of cleaning and dirty work. Hopefully if I can get the front end pieces, the car can be essentially done and ready for paint by mid July...I might get to go for a drive this year!!!! _________________ Cheers, David
1969 Bug
1972 Bug
Otto1969 Samba Member
Joined: January 17, 2014 Posts: 31 Location: New Zealand
Posted: Wed Jun 04, 2014 1:28 am Post subject: |
Those rear wheel arch repair sections look fantastic. I wish those were being remanufactured as I could really do with them.
The only realistic (less expensive) option to repair mine is to find a solid donor car and down here in NZ and that is nearly impossible.
C'mon Gerson, there is a (small) market for this type 3 stuff that is going to explode in the next few years as more VW nuts catch the type 3 wave. |
Posted: Wed Jun 04, 2014 11:52 am Post subject: |
Otto1969 wrote: |
If you wish, I can see if the guy I bought these from has more pieces...I think he might. I'm sure shipping to NZ from here would be expensive, but cheaper than a donor car I imagine. Just say the word mate and I'll check it out for you. _________________ Cheers, David
1969 Bug
1972 Bug
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Wed Jun 04, 2014 2:13 pm Post subject: |
Dlglobal1 wrote: |
MonT3 wrote: |
Luckily, I have all the pieces for the rear inners. Now just looking for good front end sections. He really knew his stuff so I'm confident the work will be top notch and my fasty will be saved! He said in general it was one of the cleanest original cars he's seen, so that made me feel kinda good after months of cleaning and dirty work. Hopefully if I can get the front end pieces, the car can be essentially done and ready for paint by mid July...I might get to go for a drive this year!!!! |
Hope you find a clean front end to work into your project. At least there won't be a lot of grinding to get done! _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Thu Jun 05, 2014 11:26 pm Post subject: |
I've found several NOS inner front fender sections, but they are from early models. I know the overall length is different than mine, but would it be possible to cut the areas I need and use the sections for repair or are they just completely different? The pieces are not near me so I can't measure... _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Sat Jun 07, 2014 4:42 am Post subject: |
So can anyone answer the question about early vs. late inner fender sections? I need to make a decision soon. Would the early sections be close enough to repair the section from the A-pillar to about half way forward? _________________ Cheers, David
1969 Bug
1972 Bug
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Jun 07, 2014 6:38 am Post subject: |
No, the passenger side won't be formed to mount the fuel pipe & have the mount bracket at the top.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Jun 08, 2014 1:27 am Post subject: |
Mike Fisher wrote: |
Thanks Mike. I figured as much. I'd buy that piece in your photo though!! Those front sections are the last pieces I need. _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Sun Jun 08, 2014 7:42 am Post subject: |
Add in that the earlier pieces are shaped differently, due to a narrower and shorter hood. This is the main reason you can't use the early nose pieces on a "late" front end.
And yes, that piece Mike has is a nice clean piece. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jun 08, 2014 8:34 am Post subject: |
Unfortunately it doesn't look as good on the other side, but could be sandblasted and used.
I also offered David this drivers side in a little better shape, but I already started cutting it out. It would have to come as 2 separate pieces to weld back together?
