Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Mar 11, 2016 11:12 am Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Been busy so haven't had time to post any progress reports. Car has been home for a couple months. The rust repair work came out excellent and the car is solid.
Making good, but slow progress on all the prep for paint and re-assembly which mostly involves tedious cleanup of parts and removal of Silver overspray from standing exposed in the body shop, sanding epoxy primer areas that were painted with god knows what type of green paint in a feeble attempt to match L60D for reasons unknown to me
I'm going to Ohio end of April, with a trip to St. Louis as well and want to order/pick up parts to bring back with me.
A few questions I hope you all can help with:
Any suggestions on VW shops/supplier to visit in Cleveland and Columbus areas? Also around St. Louis? Our routes will be I-70 and I-64 via Louisville in between Columbus and STL.
Are these parts correct? Any issues from those who have used them?
Is the clutch disk here Ok to use with my OE stock pp and flywheel?:
http://vwparts.aircooled.net/Daikin-200mm-Solid-Su...m-503a.htm
Tie Rod Ends from Rock Auto:
MOOG ES419L - Fits Left Outer or Right Inner; Includes Greaseable Socket Design To Reduce Corrosion And Wear
MOOG ES419R
ACDELCO 45A0142
http://www.rockauto.com/en/catalog/volkswagen,1970...d+end,7428
Brake Caliper Repair from Rock Auto:
CENTRIC 14334003 Brake Caliper Repair Kit
http://www.rockauto.com/en/catalog/volkswagen,1970...r+kit,1720
Considering this kit for my OE ATE calipers if correct. |
Are you a Cleveland area boy? I lived in Akron/ Canton for many years. Also lived in the Bexley part of Cols. in 1966/7 and Cincinnati in '71-3. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Dlglobal1 Samba Member
Posted: Fri Mar 11, 2016 1:01 pm Post subject: Re: 1970 Fasty Danish barn find |
Tram wrote: |
Dlglobal1 wrote: |
MOOG ES419R
ACDELCO 45A0142
Are you a Cleveland area boy? I lived in Akron/ Canton for many years. Also lived in the Bexley part of Cols. in 1966/7 and Cincinnati in '71-3. |
Yeah I lived in Cleveland Hts and Chesterland when I was a kid from mid 60's until we moved to California in '75. My family is spread around the state, Kent, Aurora, Chagrin falls and Delaware. So get to visit the whole rust belt! _________________ Cheers, David
1969 Bug
1972 Bug
1968 Mercedes 230 "Heckflosse"
1970 Type 3 Fastback 1600 TA L60D |
Posted: Fri Mar 11, 2016 1:14 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Tram wrote: |
Dlglobal1 wrote: |
MOOG ES419R
ACDELCO 45A0142
Yeah I lived in Cleveland Hts and Chesterland when I was a kid from mid 60's until we moved to California in '75. My family is spread around the state, Kent, Aurora, Chagrin falls and Delaware. So get to visit the whole rust belt! |
Cool. I attended KSU for graduate studies and actually got arrested there during the 1977 "tent protests" protesting plans to build a gym on the site of the may 4 1970 killings.
NE Ohio was "Squareback Country" in the '60s and '70s. There were all sorts of VW specialty shops in the area back then. Almost all are gone, at least further south towards Akron. The last survivor that was still in business last I heard was Elmar in Streetsboro- Streetsboro Foreign Car Service, if memory serves.
EDIT: Had to go look... and yes, looks like he's still there. He opened up the same year I started my apprenticeship. Damn. Doesn't seem like over 40 years!
https://www.angieslist.com/companylist/us/oh/stree...365062.htm
Couldn't remember his last name... wanted to say "Krupa" but I am thinking of the drummer. Kruza it is. He's a very good egg! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Fri Mar 11, 2016 1:32 pm Post subject: Re: 1970 Fasty Danish barn find |
Thanks Tram! I know Elmar's place, but had completely forgotten.. _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Fri Mar 11, 2016 2:39 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Thanks Tram! I know Elmar's place, but had completely forgotten.. |
If anyone will know where the remaining Type 3 treasures are stashed in the area, Elmar might be the one.
I'd tell you to say hi but doubt he'd even remember me- it's likely been 30 years. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Mar 13, 2016 6:27 am Post subject: Re: 1970 Fasty Danish barn find |
Bumpin this to see if anyone has an answer to the clutch disc question... _________________ Cheers, David
1969 Bug
1972 Bug
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sun Mar 13, 2016 6:41 am Post subject: Re: 1970 Fasty Danish barn find |
Couldn't say about the clutch disc but I didn't like the MOOG tie rod ends - I wound up tossing mine in the garbage because the rubber boots didn't stay in place and the zerk fitting was a bitch and a half to install.
They're cheap and you get what you pay for with these...that's my .02 |
Posted: Sun Mar 13, 2016 9:22 am Post subject: Re: 1970 Fasty Danish barn find |
ataraxia wrote: |
Thanks for the info. Any recommended brand I should look for? _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Sun Mar 13, 2016 8:18 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
ataraxia wrote: |
Thanks for the info. Any recommended brand I should look for? |
If you're set on RockAuto.com, go with the ACDelco branded tie rod ends, they worked pretty well for a friend's Type 3.
You can get OCAP (Italian) tie rod ends from www.bughaus.com for about $15 each. I buy a decent amount from them and, so far, all of the parts are nice.
The inner left you can get from Lucas:
http://www.thesamba.com/vw/classifieds/detail.php?id=1662921 |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Mar 14, 2016 5:13 am Post subject: Re: 1970 Fasty Danish barn find |
Thanks Guys! I ordered the inners left ends from Lucas some time ago (forgot I had two!!) and the rest from Rock Auto...I will order an additional set from bughaus just to be sure.... _________________ Cheers, David
1969 Bug
1972 Bug
Bobnotch Samba Member
Posted: Mon Mar 14, 2016 8:03 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Bumpin this to see if anyone has an answer to the clutch disc question... |
Yes, that clutch disc will work for your application. I prefer Sachs clutch assemblies, but lately they've been making the throw out bearing pretty cheap (has plastic in it), which is something I'm not a fan of in that location. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Mar 22, 2016 7:32 am Post subject: Re: 1970 Fasty Danish barn find |
Just read this whole thread. Very nice work. A+ _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Tue Mar 22, 2016 12:46 pm Post subject: Re: 1970 Fasty Danish barn find |
Mr.Duncan wrote: |
Just read this whole thread. Very nice work. A+ |
Thanks man! Just realized i'm actually 3 years into this restoration. Getting close slowly but surely. Looking forward to the new lights! _________________ Cheers, David
1969 Bug
1972 Bug
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Thu Mar 31, 2016 6:26 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Mr.Duncan wrote: |
Thanks man! Just realized i'm actually 3 years into this restoration. Getting close slowly but surely. Looking forward to the new lights! |
Any updates?? _________________ MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild |
Posted: Tue Apr 05, 2016 3:38 am Post subject: Re: 1970 Fasty Danish barn find |
MonT3 wrote: |
Dlglobal1 wrote: |
Mr.Duncan wrote: |
Any updates?? |
Soon. I am preparing a bunch of photos of progress...met with a painter yesterday
I have run into a problem I hope you guys can help with. I purchased a new set of Mahle 85.5's, and it seems the cylinders will not sit flush with the case register...case was decked 0.40mm. The OE VW cylinders sit perfectly.
What are my options here since I want to use the new set of P&C's??
OE fit:
Mahle Fit: Note I tried fitting with and without studs in place, so the cylinders are not hitting studs. There is a .016in gap between the base of the cylinder and case. Do I need to get the cylinders machined? Should the case register have a chamfer edge?
1969 Bug
1972 Bug
Posted: Tue Apr 05, 2016 6:05 am Post subject: Re: 1970 Fasty Danish barn find |
Will these fit my '70 1600? I'm told they are off a 68-69 type 3 Karman ghia...
http://www.thesamba.com/vw/classifieds/detail.php?id=1707755 _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Tue Apr 05, 2016 11:33 am Post subject: Re: 1970 Fasty Danish barn find |
Those will fit David. I'm not sure I'd believe the T-34 spec on them, but they're priced about the same as here in the US for regular T-3s. I'd probably strip off the outer layer of insulation, and finish sandblasting them, then paint them. Keep in mind that shipping might cost almost what he's asking due to their weight.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Apr 05, 2016 11:59 am Post subject: Re: 1970 Fasty Danish barn find |
Bobnotch wrote: |
I hope this helps. |
Thanks Bob. He gave me a good deal on shipping so I bought them. What do you make of the cylinder issue I posted about earlier? The 3/4 side of the case seems ok so I'm stumped. _________________ Cheers, David
1969 Bug
1972 Bug
Posted: Tue Apr 05, 2016 1:18 pm Post subject: Re: 1970 Fasty Danish barn find |
Dlglobal1 wrote: |
Bobnotch wrote: |
Thanks Bob. He gave me a good deal on shipping so I bought them. What do you make of the cylinder issue I posted about earlier? The 3/4 side of the case seems ok so I'm stumped. |
I don't know. I'd probably do a full mock up, and see if the volumes are the same (might need shimming to get the deck heights even). If so, you could do a light turn on the jugs that match up with your spacer shims. Clatter could do an excellent tutoral on it, as he showed that exact operation when he was building that "sweep the floor" bus engine last fall. Keep in mind that most engine builders don't really use just the paper gasket any more, but rather use high temp silicone (sparingly) to seal the case to barrels. It just works that much better at preventing oil leaks. I like ultra copper myself for doing that job.
Wait and see what others here recommend before getting to far along with doing any machining. It might save you a few bucks. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
