norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Wed Apr 03, 2013 9:59 pm Post subject: AR-15 builders |
I was lucky enough to find a stripped lower for cheap. alloy, not poly
about to do my first build. anyone else here have a build? |
mrmarcdude Samba Member
Joined: December 15, 2005 Posts: 715 Location: Vacaville, Ca
Posted: Wed Apr 03, 2013 10:46 pm Post subject: |
I sold mine recently, but enjoyed building it.
Spikes Tactical Lower
DPMS lower parts kit
DPMS solid A2 stock
Prince 50 mag lock
Watsons extended takedown pin
Stag Arms 20" A4 upper w/removable iron sights
I will say that Stag Arms makes excellent quality pieces. I fired MANY rounds (including shitty Wolf rounds), and never had a single jam, short stroke, or extractor failure. It pays to have quality mags too otherwise you might run into feeding issues. Who made your lower?
_________________ - Marc M.
-65 Beetle -1600dp- |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Fri Apr 05, 2013 9:54 am Post subject: |
What's the point of building your own from parts? Is it cheaper, or just so you can get exactly what you think you want?
Gun amateur here so be nice |
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Fri Apr 05, 2013 12:38 pm Post subject: |
One reason is you can't buy one in some states, but you can build it as a kit. Second is the reason you mention. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Jimmy111 Samba Member
Joined: October 05, 2006 Posts: 2643 Location: Wyoming
Posted: Fri Apr 05, 2013 6:48 pm Post subject: |
Ive done one or two..
Not cheaper to build it yourself.
But try to find one for a reasonable price today. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Fri Apr 05, 2013 7:15 pm Post subject: |
Not having much need to actually kill anything or anybody, I have given some thought to building my own Taser. |
Posted: Fri Apr 05, 2013 7:33 pm Post subject: |
lots more people are killed by tasers than by AR's
But please do Id like to see that. |
Posted: Fri Apr 05, 2013 7:38 pm Post subject: |
Jimmy111 wrote: |
I haven't worked out the details yet, but the concept involves darts, a blow gun, and a very long 110v extension cord. |
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Fri Apr 05, 2013 7:44 pm Post subject: |
iowegian wrote: |
Jimmy111 wrote: |
Not a doubt in my mind the blow gun part will work perfectly with you on the business end.. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Apr 05, 2013 8:50 pm Post subject: |
I think this guys a bit if a tool but I think the concept is really interesting !
_________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sat Apr 06, 2013 1:58 am Post subject: |
Major Woody wrote: |
I decided to build my own for a number of reasons.
1. You can select exactly what parts you use to make it "your own".
2. I managed to shop around for the best deal on what parts I wanted, saving money.
3. I love building shit.
Now keep in mind that I purchased the entire upper receiver/barrel complete. The upper reciever is where all of the "real" assembly takes place. That's where you have the reciever, barrel, gas system, bolt/carrier group... ect. These parts must be assembled very precisely, and I'm not a gun smith.
My work consisted of installing the lower parts kit into the lower reciever(trigger group, bolt catch, mag release, grip, buffer stop..ect.), installing the buffer tube/stock, and then mating the upper/lower. The Stag Arms upper, and Spikes lower fit together perfectly; not a bit of play anywhere. It was smoooooth. _________________ - Marc M.
Zen Mechanic Samba Member
Joined: February 07, 2002 Posts: 158 Location: Murrieta, CA
Posted: Sat Apr 06, 2013 10:43 am Post subject: |
If you haven't already, get on calguns.net
A lot of calgunners do build parties together.
Like thesamba, but for guns. _________________ Beto
Murrieta, CA |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Apr 06, 2013 6:44 pm Post subject: |
I have a semi-local VW buddy that builds AR's, but I have not done so myself. I guess I am intimidated by the construction. Maybe I shouldn't be. _________________ nothing |
Posted: Sat Apr 06, 2013 9:00 pm Post subject: |
I built a kickass stungun-fired potato launcher but that's about as close as I have gotten to fabricating weaponry. It was a blast to make and is a kick to fire. Not sure I would feel comfortable building my own firearm. |
Posted: Sat Apr 06, 2013 11:24 pm Post subject: |
For those that are intimidated about building their own AR, don't be. If you can adjust your valves, you can build an AR. The hardest part that I remember was installing the roll pins for the bolt catch, and trigger well. I was just being careful and didn't want to scratch the crap out of the reciever. Buy the upper reciever complete, and everything will go together like cake. _________________ - Marc M.
Tracey Samba Member
Posted: Sun Apr 07, 2013 9:13 pm Post subject: |
Working on one as we speak.....way cheaper than what they are going for fully built. _________________ 1986 Westy Subaru 2.5 Syncro **SOLD**
1970 Westy camper
1965 split project
I love the Vans! |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Mon Apr 08, 2013 6:29 pm Post subject: |
Also no numbers-no registration. Not that you'd want that or anything...... _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Mon Apr 08, 2013 9:46 pm Post subject: |
Splitdog wrote: |
Also no numbers-no registration. Not that you'd want that or anything...... |
No numbers? When you buy a stripped lower it still has serial numbers. You buy the lower, ship it to your local gun dealer, and they handle the D.R.O.S./registration. Unless of course you buy it out of somebody's trunk . _________________ - Marc M.
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Mon Apr 08, 2013 10:03 pm Post subject: |
mrmarcdude wrote: |
Splitdog wrote: |
No numbers? When you buy a stripped lower it still has serial numbers. You buy the lower, ship it to your local gun dealer, and they handle the D.R.O.S./registration. Unless of course you buy it out of somebody's trunk . |
When you buy an 80 percent complete lower receiver and complete it yourself, there is no serial number required .
It is completely legal to do so as long as you do not sell the rifle to someone else. |
Posted: Mon Apr 08, 2013 10:25 pm Post subject: |
Ok, so after searching through several dealers, I have acquired all parts necessary. it wasnt easy, most places are sold out of everything but my tenacity has scored me everything i need to build a CA legal AR for under 900 bucks. im surprised i was able to do so in this time.
My lower is in FFL lockdown til the 15th. ( i actually bought 2 for future builds) my upper should be here in about 4-6 weeks and my lower kit is on the way as we speak. magazines and bullet button arrived this week.
Now i got to suck it up and crap a bunch of money for ammo. about 75 cents a round is the cheapest i found in bulk. OUCH!
My lowers: MAG tactical lightweight ( new company) and a palmetto state armory |
