MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 485 Location: Milwaukee Wisconsin, US
Posted: Fri Aug 16, 2013 1:00 pm Post subject: |
Really coming along! Keep up the good work and the updates, always enjoy seeing your progress!
Cheers! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
ernie norley Samba Member
Joined: September 27, 2009 Posts: 170 Location: nambour australia
Posted: Fri Aug 23, 2013 2:08 am Post subject: |
G'day all. here are some pics of the 1st rear brake set up getting other 1 next week engineer has been busy on major job to start |
Posted: Fri Aug 23, 2013 2:15 am Post subject: |
g'day all. follow up to rear disc set up this what has been achieved
the pajero caliper bracket had less than a mm machined of the inside to allow it to slide over vw carrier hub. 1st to go on is the diff housing flange followed by caliper bracket then the backing plate & hand brake assembly then the disc & vw axle hub. the pics show the work involved.I still have to get a locating ring machined up to go between the disc & the hub.
the components
the machined caliper bracket
all the bits
outside
side on
from axle side
all for now
ernie |
Posted: Fri Aug 23, 2013 10:35 pm Post subject: |
assembled unit to check location of backing plate
Posted: Fri Aug 30, 2013 4:54 am Post subject: |
G'day all. Spent 1/2 hour today welding up engine transmission cradle pretty simple in construction & design
Posted: Thu Sep 12, 2013 1:31 am Post subject: |
g'day all. Spent an hour today sorting out the shifters & handbrake lever.
the middle is tarago the handbrake lever is hi ace & the transfer case is Mitsubishi L300 shifter stripped out of it's housing. all for now more next week
ernie
This is the final location of the engine sitting on cradle. The gearbox will mount from from the original mounting holes on top of housing
Posted: Fri Oct 04, 2013 3:44 pm Post subject: |
G'day all. spent some time on front spindle set to check for clearance on cv joint & caliper on full lock alls good. Here's what It will look like once on ECLECTIC.
ernie
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Oct 04, 2013 3:52 pm Post subject: |
Think it would be fun to build a motor box that mimics a reefer.
You have been busy- looks great- can't wait to see it in action Ytube any body?? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Oct 04, 2013 4:17 pm Post subject: |
G'day williamM. good to hear from you. what's a reefer the names associated with a funny plant. show me a pic or aim me at a site so I can check it out. I hope to have ECLECTIC running by august next year for our big vw meet at valla park. This is held every 2nd year at a camping grounds minutes to a beach & first class social event for families as well
ernie |
Posted: Sat Oct 05, 2013 8:18 am Post subject: |
reefer- (n0t the weed) but a refrigerator box. So when you open the fridg door there is the dip stick, power steering and coolant levels. Would make a great sight gag.
Find a nice Dometic or Coleman door for authentic look. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Tue Oct 22, 2013 1:31 pm Post subject: |
G'day all. Had a month out of the shed. Back yesterday here's where I'm up to. sat the tool box come console insitu to see where I need to cut it 6 inches of the back the slice the lid back the same & relocate the lock into it but pics will give you an idea of how it will look. The shifters will be in a good spot along with the handbrake lever. Set up the front spindle I will have to spread the beams looking at the angle the bottom arms sitting at. will bolt hub & tyre on today to see what happens with load on it. I have beam set up that has an adjuster in the top I may be able to use that will have check it out so here are the pics
the spindle note the angles on the arms any suggestions if the arms need to be parallel
this is the engine mount brackets need to tidy up then weld 2in x 2in angle between them & the top of the cradle the angle will bolt to top of cradle to ease removal
this is how high It sits standard so pic later with set on to see if it lift's it
Posted: Thu Oct 24, 2013 3:27 am Post subject: |
G'day all couple of the front assembly I'm thinking I will have to spread the beams & flip the lower arms. So back to the shed to look into what needs to be changed as the lower arm is under load on ball joint because of the angle
Posted: Mon Oct 28, 2013 6:42 am Post subject: |
G'day all. been working on the front drive & beams. I have to spread the beams to fit the longer spindles between the ball joints. looking at the 1 built by VW as a mule for the syncro they did the same as it has 2 bump stop arms coming of the bracket that bolts beam to the chassis. here are some pics to give you an idea of the amount to be spaced out with new plates to replace the pressed factory units
Grand_Pooh-bah Samba Member
Joined: December 19, 2006 Posts: 2171 Location: MIAMI V-DUBville, Florida
Posted: Mon Oct 28, 2013 12:59 pm Post subject: |
Great Work!
You can maybe try to swap the lower control arms (left one on the right and the right one on the left) so the head of the ball joint is on the bottom of the spindle and the nut is on top. you will need to re taper the hole for it to mount properly.
Just a thought _________________ http://miamivdubs.com/
They say MONEY don't buy HAPPINESS, BUT!, it buys me VW'S and lots of other SHIT and that makes me HAPPY!!!!!!!
MIAMI V-DUBS |
Posted: Mon Oct 28, 2013 4:48 pm Post subject: |
That looks great Can't wait to see the pics of it all mudded up.
Are you near all those fires down there?? We're getting some pics of Sydney burning to the ground. _________________ some days I get up and just sit and think. Some days I just sit.
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Mon Oct 28, 2013 9:45 pm Post subject: |
You are F-n batty, mate!
Amazing previsualization
Aren't Aussie MOT inspections & safety standards some of the toughest around?
You are not expecting any issues licensing the vehicle?
IDK, just thought I'd ask...
Can't wait to see the roo bar on this bitch _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Tue Oct 29, 2013 3:00 pm Post subject: |
G'day grand poo-bah wiiliamM borninabus. thanks for dropping in
1st grand poo bah I tried flipping the lower arms but this increased the amount the beams were split by
williamM good to hear from you again. we are well away from the fires we have friends in Sydney who were in the zone but luckily their home was left unscathed unlike the homes 3 streets away If you google Nambour on the sunshine coast it's not a big town but it's a great place to live after living in Sydney
grand poo-bah welcome. yes your right about our rego laws I have to apply to the dept of transport for an approval to start the build then engage a authorised engineer who then does checks at different points in the construction up to the final approval certificate then it goes for a roadworthy certificate then to the transport for registration which depending on the person doing it I amy have to get it inspected again by them so it has to be right to get on the road but that the price you pay for this 1 off type build |
Posted: Tue Oct 29, 2013 3:01 pm Post subject: |
Posted: Wed Oct 30, 2013 4:14 pm Post subject: |
is Nambor where the little casino is on the way to the murky swamps for shrimp??? Now THATS an adventure Ya never know if its a big shrimp or a small gator. (they both taste like chicken )
I registered my Kombi in Canberra and then put the camper stuff in there. But DOT there has had 35 years to write more regs sense then. Least when your on the road- you kinda know the thing is set right. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Tue Nov 05, 2013 3:30 am Post subject: |
G'day williamM. good to hear back from you. Nambour is famous for 2 icon's the big cow & the big pineapple. We are about 20 minutes to some of the best beaches in OZ. If you ever make it over this way I would be happy to show you around.
ernie |
