stever70 Samba Member
Joined: October 30, 2009 Posts: 302 Location: california
ernie norley Samba Member
Joined: September 27, 2009 Posts: 170 Location: nambour australia
Posted: Mon Mar 24, 2014 7:17 pm Post subject: |
G'day Stever70. thanks for still being out there I been off the job with a torn rotator cuff in right shoulder. Back into IT now moved the bus home to my place 3 weeks a go. So far I have set up the engine cover now I just have to line it with a 2nd skin to fill with expanda foam for sound & heat still have figure out the front of the cover for around the timing case area between the seats. I had to get the rear drive shaft shortened more so little things falling into place. I have the biggest part of everything in need now to complete the mechanical side no room for seats in middle row. So will have to be a 5 seater. Will post some pics next week |
Posted: Wed May 21, 2014 3:54 am Post subject: |
G'day all. Bit of an update. been running around sorting out & adapter plate template to bolt a v6 Holden motor same as your GM v6 I think Pontiac to a Subaru 5 speed for the blokes out here with that motor in their bay's. I have fitted the rodeo rear bar with tyre carrier had to modify it to move the tyre to the centre. The bar brackets fit between the bus chassis rails just have to notch the brackets to lift the bar 2 inches to bring it closer to the original bar height & more ground clearance. I had the beam plates cut by waterjet for the spread font beams to spread the beams by 31/4 inches to allow the rodeo spindles to fit. run out of room on the front of motor for alternator so mounting it on brackets on the rear of the right hand head & running 3/4 inch aluminium round bar in caged bearings with the rover pulley mounted on the front & a rubber steering column donut between the shaft & alternator for alignment.
rack before
after
chassis
alternator set up
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed May 21, 2014 10:40 am Post subject: |
You need to clean the lens on your camera. It looks like you're shooting in a fog. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Wed May 21, 2014 2:29 pm Post subject: |
G'day Steve & jtauxe. thanks for the fog comment you were right about the lens I thought it was because I dropped the phone & shattered the touch screen that maybe impact had rattled the camera side of it. Steve where are you up to on your project. I have obtained 2 power board boxes to use as the engine cover they lock together will post some pics next week our vw national are on this weekend in Sydney 30th anniversary so of to that tomorrow. talk to you soon
ernie |
77 Riviera Owner Samba Member
Joined: January 16, 2003 Posts: 117 Location: Seattle, WA
Posted: Wed May 21, 2014 5:08 pm Post subject: |
I love that back bumper. This will be one cool 4x4. Looking forward to seeing the finished rig. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed May 21, 2014 10:24 pm Post subject: |
that rear tire carrier is cool! i have to get something similar soon...
...tell me thats a wheel from another car though... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu May 22, 2014 1:32 pm Post subject: |
G'day 77riviera & Stuart. thanks for dropping in the rear bar is bolt up after drilling chassis rails but I need to lift it up about 3inches just to give exit clearance like I said it's off our Holden rodeo but I think you probably call them Isuzu rodeo or chev google it came of about a 99 model
ernie |
Posted: Fri May 30, 2014 5:08 am Post subject: |
G'day all. have the front beam plates on the beam tubes now to assemble & give the tubes a slight twist of about 1/4inch to give lift instead of fitting adjusters to tubes then fit to bus & spot weld take to tailshaft guys to weld up. Don't think it will bend at 12mm thick.
ernie
Posted: Tue Jun 10, 2014 1:37 am Post subject: |
G'day Stever70. how's the conversion going on yours just had a look at your blog have you had it running any video. I'm slowed down with the shoulder so about 6 months behind so need to start to bolting stuff together little bit at a time
ernie |
Posted: Sat Jun 14, 2014 8:44 am Post subject: |
Ernie, I don't expect that you need it, but here's some off road inspiration for you. Skip to about 19:05 in this video...
A bit of over the top, but fun regardless.
Posted: Fri Jun 20, 2014 12:57 am Post subject: |
G'day all. I have partially assembled beam need to fit the hub & disc then mount it up to the bus with wheels to suit may get away with 16inch rims I'm thinking of making it adjustable but not in the usual method will put up some pics of what I'm looking as a design instead of the 1 in the middle of the tubes. the steering rack will mount brackets bolted to beam plates. looking at using the bus adjustable tie rod's on both sides
ernie `
Posted: Sun Jun 29, 2014 2:32 pm Post subject: |
G'day all. spent some time with a hole saw drilled into the front bar & crushbar to fit this bar. I don't know what it came off but another freebie. hope you area all well over there. A mate just had 2 months over there he bought me back a t shirt from Sedona Arizona with a split bus on it good for my collection If anyone on here lives in Sedona let me know what you towns like
ernie
Posted: Wed Jul 09, 2014 4:17 pm Post subject: ECLECTIC IS GOING INTERNATIONAAL |
Good morning all. I have been invited to do a story in the garage /project pages of ULTRA VW MAGAZINE. So thanks to all that have dropped into my build. onward.
ernie |
ratherb-buggin Samba Member
Joined: January 30, 2005 Posts: 986 Location: Shawnee, KS
Posted: Thu Jul 10, 2014 4:24 am Post subject: |
This bus is going to be sweet! Keep up the good work! |
Posted: Fri Jul 11, 2014 2:12 am Post subject: |
G'day Ratherb. Thanks for dropping in I have to start fitting the front beam on Monday so will put up some pics I hope my calculations are right it should give me 2 to 3 inches lift. then I have to load up the rear compartment with bags of concrete to get it sitting on suspension to check the level front to rear it currently sits 1/2 way between the travel on the arms because of the loss of the drive train. be back next week with updates take care out there
ernie |
77VWBusDude Samba Member
Posted: Fri Jul 11, 2014 4:50 am Post subject: |
Lol wow, that roo bar leaves no doubt your Bus means business _________________ '77 Bus auto EFI(stock)
WendyArmbuster wrote: |
Oh man, I had forgotten the smell of a running bus. Sort of like a combination of old things and burning dust. Smells like... victory. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Jul 11, 2014 6:52 am Post subject: |
That is really coming together- good work. Like that roo bar and the tight fit Those big Reds always scared the shit out of me when I was there. Rounded a corner once and was in the middle of hundreds of greys running like mad. SO- money well spent.
Only suggestion is search forums for expando foam and "foam of death". Seems that shit gets wet and won't dry out.- I didn't know about it either till after I sprayed it in an adventurewagon hightop mating surface.
Keep up the good work look forward to a video of it running the red mud. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Sun Jul 13, 2014 2:00 pm Post subject: |
G'day williamM your right about the xpandafoam a mate used some on his bus it rusted the area in less than 12 months but in ECLECTIC it will be sealed to the outside moisture & it's only going in the engine cover so if it does the heat will soon dry it out. because of shoulder I'm making a jig today to attach to the hole in the floor jack so I can lift the beam out & put the modded 1 in phots of new front end Wednesday
have a good day over there
ernie |
