andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Jul 18, 2013 6:39 pm Post subject: |
Thanks - coming from you, that means a lot. Just was hoping to be at this point late last year. Then I wouldnt have screwed up....I mean modified our dune buggy _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Aug 23, 2013 8:01 pm Post subject: |
Quick update - will post some pics in a couple days once I get a panel installed that I screwed up.
Been working on sheet metal for the engine compartment and "inner fenders". Realized that this is the best time to wire the rear of the car. What I then do is splice the harnes at the rear of the cab.
Something that changed things was that I am going to do a "gag" coffin which will have sound and light effects and possible animation. Will be on a remote, so I can give some folks a charge at a show or halloween parade. But I can swap out the coffin with a "normal" one easily.
Now, since I am doing that and may play with the effects a bit, the concern is that I will kill the battery. A buddy suggested a dual battery setup and I went that route. Of course I cant keep things simple, and I decided to add a 4 fuse sub panel and a couple relays to isolate the batterys. Just got the last part I needed today, so I should have this phase of it done in a couple days.
I also need to make the car "drivable" since I have to move it up to my storage garage a couple times to make room for 2 other project I need to get done over the next couple weeks. Not hard to do, but just sucks up time.
Thank God I pretty much retired a couple years ago - between family, the cars and a motorsporst complex that I am helping a friend put together, I wouldn't have time to work.... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Tue Aug 27, 2013 1:16 pm Post subject: |
The car moves under its own power now. The inner fenders, engine compartment metal and the wiring for the rear is pretty much done. Tested all the circuits and everything works. Batteries charge - the whole shooting match seems good.
This is a shot of the ductwork and dual 5" fans for aux cooling. 6" flex pipe will go to the space between the cab and the box to draw in clean fresh air. There will be a curved sheet metal engine cover that will get hidden by the coffin
1/2 of the dual battery set up.
Posted: Fri Sep 06, 2013 3:27 am Post subject: |
Got sidetracked - decided to upgrade alternator since the voltage was a little low for my dual Odyessey AGM batteries. Also threw one of the new Empi 34 PICT carbs on that I got swapping some parts. Am actually imperssed with it. Looks well made and tuned well. Also installed a mex SVDA instead of the cheapy SVDA that I was testing.
Figured its better to get everything dialed in and fixed first. Did some test driving as well. But now seeing an oil leak - Gonna drop the engine - most likely crank seal. Sometimes I do well and sometimes not. Hopefully going to get the actual tool this weekend and get it fixed over the weekend.
Then Monday or Tuesday helping my cabinetmaker buddy move some stuff out of the space that car is giong to occupy for the next couple months and take it over (another reason to fix the leak - he doesnt like puddles on his floor). Should start mocking things up later in the week. _________________ D-Dubya Manx clone - 63 Short pan,1914.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Sep 06, 2013 5:48 am Post subject: |
Looking good... keep bangin' _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Tue Sep 10, 2013 6:34 pm Post subject: |
And after runing it a bit - had a bit of a leak - dropped the enging and turns out the O ring in the flywheel was toast - I had already messed one up and replaced it. So looking for why - already deburred the end of the crank, Did it again and polished the flywheel. When putting it back together, I notice that the aluminum gasket that goes over the crank end might be the culprit.
Made a quick call - turns out I dont need the gasket - cool. Throw it back together new main seal installed with my new home made seal tool. Was starting to get pretty warm outside though and the sun is beating down on my back. But gonna get this done. Anyway - real fight getting the engine back in - even with my wifes help. Went to rotate the crank a little - wont budge. Son of a bitch. Leaving out the gasket now brought the flywheel in 0.010" Went through my stash of shims. - No way to get what I need from what I had. Took about 0.040" off the OD of the gasket and put it back together. Dry as a bone. Now I am ready - The plan is to take it tothe wood shop Saturday evening - then get started on Monday. _________________ D-Dubya Manx clone - 63 Short pan,1914.
speedaddicted Samba Member
Joined: October 22, 2011 Posts: 10 Location: Wisconsin,USA
Posted: Tue Oct 29, 2013 5:46 pm Post subject: |
Lovin' you're build. Great creativity and fabrication! Keep crankin on that bone hauler. |
Posted: Tue Oct 29, 2013 6:07 pm Post subject: |
Wellllllll - FINALLY getting to work on it. Been tied up with other projects - lots of good and cool stuff, just not on this car. The plan for tomorrow is to mock up the hearse body and get a handle on the general dimensions of the box - in particular the width. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Oct 31, 2013 3:49 pm Post subject: |
And now everything has changed. The concept was a "tweener" design - between the 20's style and the mid 30's style, but the hearse box was going to pertty much be that - a box.
Well when mocking up, my cohort in crime, Jeff the cabinet maker, starts sketching on a scrap of cardboard. Tapered the top in at the beltline. Looked like a "Brubaker Box" to me and I hated it. BUT the more we tweaked and explored how the trim, rails and posts would be done, it makes more sense.
If you see the initial concept sketch atthe beginning of this thread, the problem is that the area from the beltline up has too much sticking out from the back of teh cab. Has that "box truck" look. If taperred in, the mass goes away. But now that changes everything - woodwork needs to be simpler and cleaner. Its gonna work really well, but now taking a different direction.
Anytime you are doing something radical - looking at drawings is one thing - but stepping back and looking at it full scale from various angles is a whole nother thing.....Thats why car manufacturers do/did full size clays. _________________ D-Dubya Manx clone - 63 Short pan,1914.
TheGrafs Samba Member
Joined: May 07, 2012 Posts: 239 Location: Utica, New York
Posted: Mon Nov 11, 2013 7:40 am Post subject: |
Very impressed with the amount of fabrication in this build! Looking good so far! Keep up the good work _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Youtube: GrafsGarage3
Instagram: GrafsGarage |
Posted: Mon Nov 11, 2013 1:25 pm Post subject: |
Thanks - just waiting on some material to get in and then back to it. _________________ D-Dubya Manx clone - 63 Short pan,1914.
dingoid Samba Member
Joined: November 07, 2013 Posts: 5 Location: Lawrence, KS
Posted: Fri Nov 15, 2013 2:29 pm Post subject: |
I am incredibly curious as to how this turns out!
Best of luck to you and your build (what's left of it!) _________________ Don't Cup The Mic! (sound all sound guys everywhere) |
Posted: Sat Nov 16, 2013 5:23 am Post subject: |
Thanks - hoping to get some work done this week - have been busy with other stuff lately. _________________ D-Dubya Manx clone - 63 Short pan,1914.
don't_bug_me Samba Member
Posted: Sat Nov 23, 2013 6:46 am Post subject: |
Cool project, I'm not all into the "hearse phenomenon" like some are, but I think the project as it sits would make a great stake bed truck look. _________________ 70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
"Necessity is the mother of invention" |
Posted: Sun Nov 24, 2013 1:23 pm Post subject: |
The guy that is helping me do the hearse box had suggested that more than once (stake bed). And then we'd make a bunch of wooden casks.
But not what the wife wants. Whats kind of funny is that I could almost have "interchangable" rear bodies since it will litterally slip on from the top. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Nov 24, 2013 2:52 pm Post subject: |
andk5591 wrote: |
But not what the wife wants. |
Wait a sec....the wife wants a hearse...make sure none of the boxes are YOUR size _________________ 70 Street Baja http://www.thesamba.com/vw/forum/viewtopic.php?t=566113
Posted: Sun Nov 24, 2013 4:00 pm Post subject: |
don't_bug_me wrote: |
andk5591 wrote: |
Wait a sec....the wife wants a hearse...make sure none of the boxes are YOUR size |
LOL - Well - I would fit in the coffin that I am building for it.....Hmmmmm maybe she has been watching too much Law and Order..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Thu Nov 28, 2013 9:07 am Post subject: |
My brother and I have been drawing your car in different styles. Wish I knew what the back is going to look like. |
Posted: Thu Nov 28, 2013 8:04 pm Post subject: |
About my 4th post will help you understand what I am doing. Dont have a good sketch - think curio cabinet (curved glass) - But you will have about 8" of flat on each side (running vertically). Below the beltline is a curved metal engine cover with stock license plate light from about a 65 bug. Has same radius as a stock engine lid. The glass doors above it match the curve and thats how you put the coffin in.
I think that I had said a little bit ago that the basic box has evolved since we mocked it up. Had issue with the areas just behind the cab being too much like a "box van" and so its going to get a little closer to a sedan delivery than originally planned. Havent really got anything done on it lately, but since the snow is flying here, I can start to concentrate on it again. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Dec 16, 2013 5:01 pm Post subject: |
Finally getting back to work on it. Now that we have mocked things up, I know where my mounting points are. Ordered some more square tubing and am picking it up in the morning. Hoping to get the bottom framework finished this week. Then after the holidays get started on the wood. We have the MDO ordered that will be used for the bulk of it. Since the exterior is all to be painted, I don't need the wood grain.
Will be just using 1/4" veneered plywood for the inside of the box. Still up in the air on what we are using, but probably something simple like mahogany. Understated, elegant and traditional. But will use something more exotic for the coffin itself.
Once we get the box layed out (beltline and roofline in particular), I can get the cab body back to the body shop to get finished up.
Will post some pics later this week. _________________ D-Dubya Manx clone - 63 Short pan,1914.
