mudchicken Samba Member
Posted: Sun Apr 21, 2013 11:26 am Post subject: Narrowed beam, how much will I need?? |
I'm sorry as I know this has been gone over before but I cant seem to find anything that answers my specific question. I will be lowering my 71 Ghia with 2.5" drop spindles and link adjusters. I will be running the factory wheels and tires. How narrow of a beam will I have to go with for this set-up? I am not sure how low I want to go with the adjusters yet but no matter what I will be running stock wheels and tires. Let me know what you all think.
Thanks!!! |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Sun Apr 21, 2013 2:34 pm Post subject: |
Talk to the guys over at Airkewld, they will set you up _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Ace Samba Member
Posted: Sun Apr 21, 2013 3:00 pm Post subject: |
There are inexpensive 2" ones out there just for this. You are basically compensating for dropped spindles which is widening your track about 1" to 1 1/2". Even empi has ones with bearings installed. Doing a whole assembly and just swapping is the best way to go instead of robbing your complete front end. |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Sun Apr 21, 2013 3:14 pm Post subject: |
There just isn't a quick answer to this since there are lot of variables.
How low do you want to go? Disc brakes or not? What rims (offset)? What size of tires (how wide)?
Make a specs wish list and then talk to a specialist, like Airkewld for instance. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Ace Samba Member
Posted: Sun Apr 21, 2013 3:59 pm Post subject: Re: Narrowed beam, how much will I need?? |
mudchicken wrote: |
I will be lowering my 71 Ghia with 2.5" drop spindles and link adjusters. I will be running the factory wheels and tires. |
Posted: Sun Apr 21, 2013 4:39 pm Post subject: Re: Narrowed beam, how much will I need?? |
Ace wrote: |
mudchicken wrote: |
Thanks Ace.
I am not sure how low I want to go as I will use the adjusters to dial her is to the just right stance. The Ghia came with disc brakes so yes I have disc brakes. I will also be using factory 15" wheels and stock tires on them 15" wheels.
I wasn't sure a 2" would be enough but if it is that works. The reason I am asking is because I am thinking of narrowing my beam when I install the adjusters. I just wasn't sure how much to go. Thanks for the info but more would be helpful. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2576 Location: The Real NDK So Cal
Posted: Sun Apr 21, 2013 6:14 pm Post subject: |
with stock 165/85 15 with just a decent drop not in the weeds you will rub my steering radius is very limited and I dont have the spindles just a drop the cheap 2 inch would help me alot |
dubulup Samba Member
Joined: November 13, 2008 Posts: 387 Location: Earth People
Posted: Mon Apr 22, 2013 8:11 am Post subject: |
stock tire height of the side wall is huge...big part of the comfort of a stock (old) VW.
If you drop with spindles and have beam adjusters...you'll have to raise it back up so those tall tires don't rub.
As others have stated Airkewld will be able to answer how narrow you need to go, for how low you want to be |
Ace Samba Member
Posted: Mon Apr 22, 2013 9:54 am Post subject: |
I guess that there is only one opinion that matters around here for some. Do what is best for you. |
Posted: Mon Apr 22, 2013 12:33 pm Post subject: |
Ace wrote: |
Hey Ace, thank you for the information I appreciate you helping me out. I did not want to offend you in any way. I am just on a small budget and don't have the money to make the mistake of doing it wrong. I just need reassurance that I will be okay with 2". If I mess mine up in the process I know I can buy a 2" for a decent price but anything over that can get pricey. I would LOVE to use an Airkooled set-up but again I am on a tight budget. Thanks again for the help. |
Ace Samba Member
Posted: Mon Apr 22, 2013 1:05 pm Post subject: |
Why would I be offended? Heck, you learn the most doing it yourself and the factory used some of the best parts. For me, that is what these cars are all about is doing the work yourself and understanding what is going on. Take a look at your shock towers against the body and you will see how much clearance you have. People section the back and weld in a plate for more clearance. There are even precut shock towers for doing it yourself for even more clearance. |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Mon Apr 22, 2013 1:31 pm Post subject: |
mudchicken wrote: |
I am on a tight budget. |
If you're on a tight budget, the cheapest way is to keep your stock spindles and install adjusters on a stock width front beam. Or, use drop spindles and buy smaller diameter front tires. If you go with a 2-inch narrowed beam and drop spindles, you'll also have to factor in the cost of narrowed torsion leaves, narrowed sway bar, and narrowed tie rods. _________________ 1966 Karmann-Ghia convertible |
Posted: Tue Apr 23, 2013 5:09 am Post subject: |
sactojesse wrote: |
mudchicken wrote: |
If you're on a tight budget, the cheapest way is to keep your stock spindles and install adjusters on a stock width front beam. Or, use drop spindles and buy smaller diameter front tires. If you go with a 2-inch narrowed beam and drop spindles, you'll also have to factor in the cost of narrowed torsion leaves, narrowed sway bar, and narrowed tie rods. |
Good info as well. |
Jeromerino Samba Member
Joined: February 28, 2013 Posts: 209 Location: Colorado
Posted: Tue Apr 23, 2013 11:23 am Post subject: |
Ace wrote: |
I've been looking around to see if anyone does a non-adjustable 2" narrowed beam and can't seem to find anything. All I really want to do is add the drop spindles, so the adjustable factor on the beam is not really needed for that. If that's not happening, I'll probably just go with Airkewld for a complete front end even though I have no trepidations about building my own properly. _________________ 1964 Karmann Ghia Coupe
1971 Beetle Sedan |
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
Posted: Tue Apr 23, 2013 11:47 am Post subject: |
CB Performance bare 2" narrow non-adjustable bare beam is $249 .. their adjustable PUMA beam is $269 .. seems like it would be worth $20 for all of that extra adjustability to fine tune the ride height to perfection (or if you change wheel/tire diameters down the road).
* EDIT: I was looking at part number 6286 66-on ball joint beam $249.95 .. oops I ASSumed it was 2" narrow but looking closer it seems to be a stock width beam part number 6299 is the 66-on ball joint beam adjustable but stock width as well $224.95 .. part number 6277 is the 66-on ball joint beam 2" narrow and adjustable for $364.95
Of course that is a BARE beam .. you still need to add narrow leaves, etc.
If your beam is solid and you have some welding skills, read this:
http://www.thesamba.com/vw/forum/viewtopic.php?t=338179
You may want to try to narrow your original beam, leaves, etc yourself to save a dime and be able to say "I did that"
Posted: Tue Apr 23, 2013 2:25 pm Post subject: |
Thanks for the heads-up on the CB Performance beams and other tips. I don't have a welder right now, but do have welding skills. I'll peep around a little more before making a decision. _________________ 1964 Karmann Ghia Coupe
1971 Beetle Sedan |
soopaman Samba Member
Posted: Fri Apr 26, 2013 11:43 am Post subject: want to build my own |
Read the responses on this thread. I'd like to build a BJ beam from scratch. I have the tools and materials, but don't have the measurements to cut the tubing to length. Anyone know the length of a 2" narrowed BJ beam? I read somewhere that the stock BJ beam measures 34 1/4", so 2" narrowed should be 32 1/4" does that sound about correct? Thanks. |
bluedot Samba Member
Posted: Wed May 01, 2013 10:44 pm Post subject: Adjusters |
Just want to pipe in here, and give a full body hell yeh for adjusters to fine tune my ride height. You would too! |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3149 Location: Goodyear, AZ USA
Posted: Sat May 04, 2013 6:56 am Post subject: Re: want to build my own |
Airkewld wrote: |
soopaman wrote: |
Correct. |
Thanks Airkewld. I've had a chance to browse your site and really like your beams, but unfortunately they're a little out of my budget. I haven't ruled out purchasing one though. I figured I'd take a stab at trying to build one. The shock towers will be a challenge though. I looked at the ones that comes with your beams and love your attention to detail. What gauge sheet metal are the made from? I have 1/4" sheet metal I planned on using for my towers. Will that work? Again, thanks for the responses. |
