p.e.i.vw Samba Member
Joined: February 18, 2005 Posts: 144 Location: Edmonton Alberta
Posted: Thu Apr 24, 2014 7:51 am Post subject: |
Where is the best place to buy new seat guides? |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
VADave Samba Member
Posted: Mon May 05, 2014 5:54 am Post subject: |
Thanks Guys! |
frydaddy96 Samba Member
Posted: Mon May 05, 2014 9:29 am Post subject: |
We got some new seat foam from WW, the wires were NOT running(fore-aft) in the channels like the old foam was. They were running side to side. We cut the foam layed the wire in like the old and glued the foam together, but did not attach them to the seat cover. We were afraid the foam would tear due to the pressure needed to get the two wires close enough to get the hog ring in there and closed.
Another note on our '79 vert, the center rail guide is a different style/design than the one shown here. I think I have some pictures of it. I'll try to post them. |
jerrybromley Samba Member
Joined: August 06, 2016 Posts: 124 Location: Michigan
11Bravo Samba Member
Posted: Sun Oct 15, 2017 5:34 am Post subject: Re: 1974 and newer Seat Guides, How to Install |
Instead of starting a new thread I thought to leave this info in one place. What you see below is what a PO had done to stop that unwanted front seat travel back, when you don't have the retainer springs.
_________________ 75 Le Grande with a 72 1600 DP
Air cooled 1000cc mud motor on a 18 footer
Air cooled 500cc flat 4 VW style, Military generator
Click to view image |
ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Tue Dec 19, 2017 1:27 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
Thanks. Had a frustrating day with wiring. But took a break and did this on my 74 SB and felt like I made some progress! _________________ 1973 chassis + 1974 body = super beetle saved |
67vetteal Samba Member
Joined: July 29, 2017 Posts: 98 Location: Long Island
Posted: Tue Dec 19, 2017 3:23 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
I'm grateful to find this great article. One of my winter projects is to install new padding and Track Slides in our 74 Super Cabriolet. Car was stored for 36 years in a Heated Garage and the "Horse Hair" just disintegrated. I was in for a surprise the first time I vacuumed under the seats! I have learned so many things that seemed a big mystery from reading this Post! Thanks. |
jdnizzle Samba Member
Joined: April 10, 2015 Posts: 57 Location: North Port, FL
Posted: Sun Aug 18, 2019 8:44 am Post subject: Re: 1974 and newer Seat Guides, How to Install |
Great walkthrough - I was looking for something else but this answered questions I hadn't started to figure out yet.
Thanks!!! |
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Fri Jan 03, 2020 4:49 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
djkeev wrote: |
There seems to be a lot of anguish over installing 1974 and newer seat guides.
If your seat is loose and rocking..... Most likely the guides are worn or missing.
It is also likely the tracks welded into the chassis are bent as well and it would do you good to look at them and make any needed repairs so they are straight.
Also take a wire brush and scraper and clean the tracks of old grease and dirt. Even go so far as to sand them until they shine! Not the outside, the inside of the U.
These are dirty and need cleaning......
Note that The reproduction bits you can purchase today are not shaped poorly or inferior to the original design.
Here are various views of Genuine VW guides and after market guides........
KEEP IN MIND THESE ARE MADE OF A HARD PLASTIC AND THEY WILL BREAK IF TREATED ROUGHLY..........
Notice the "teeth" on the new Pedestal guide but they are missing from the old Black original VW one, these teeth break easily but are needed for proper installation...... They clip over the Pedestal bracket and hold the guide in place.
Here is a view of the Passenger (right) seat pedestal......... Top looking towards the rear........
Looking from the door........
Here is the new Pedestal guide starting to be installed, you need to move the seat adjustment lever to pull to locking pin back so it can be inserted. The pin will end up passing through the round hole in the Guide.......
The bottom "tail" of the guide goes into the slot below the pin hole and sticks out..... Push down firmly until the guides "teeth" click over the mounting bracket........ Release the seat adjust lever and allow the pin to protrude through the new guide.......
THERE! That was easy! Now on to the rear seat guides, this is the fun part!
Here are the tools I used to fix the lower seat guides.
Knipex Adjustable Plier Wrench,
a Square to use as a straight edge,
a File to even up the repaired guides,
a Screw Driver to bent the tabs back into alignment and
a Hammer..... a small Ball Peen to gently encourage the metal to go where I want it to go!
I realize not all may have a pair of the Knipex Plier Wrench but it would be worth the investment! This has become one of my "Go To" tools! They grip metal firmly as well as having parrarel jaws and without damage allow me to bend and manipulate metal into shape...........
Here is the front single track, it's in great shape and no repairs are needed......
Here are the rear guides, inner and outer......
He is a close up of the inner rear seat guide...... Notice how straight the metal is....... This is a GOOD thing!.......
Here is a close up of the outer guide...... NOT so pretty.........(sorry it's out of focus) .... you can see the curve the guide has from years of abuse. A new plastic guide will NOT clip onto this curved metal and stay on. It will keep falling off and will drive you absolutely nuts while you fight trying to install the seat!..........
I used my tools to reshape the guide until it was flat, or as flat as I could get it. I then used the file on the flat surface to smooth it out and remove any burrs or imperfections that would hinder the guide bushing from effectively snapping on.
See how much straighter the guide is after re shaping? ........
Here are the results of using the file on the straightened guide...... The shiny spots were high imperfections removed by the file, perfection isn't required, just close to perfect is fine............
The guide is just starting to slide on, I install them so the slit it toward the top when installed...... It works for me..... Maybe they go down? I've never seen documentation on how they go..... .........
Here is an edge view showing the retaining Tab that snaps into the squarish hole stamped in the metal seat guide.......
I use a very small screw driver to encourage the tab to depress and slide over the steel. I tap the edge of the guide very gently with a plastic hammer to slide it on.......
Here is the Plastic Guide fully installed on the repaired metal seat guide. See the Tab is firmly snapped into the squarish hole provided for it........
Both guides firmly attached to the seat. Now make sure the tracks are ready for the seat and install it!......
I use a smear of white grease in the tracks. Not a lot for it will come off onto any clothing left on the rear floor, just enough to help it slide.......
Dave |
It's the end of 2019 I got a set from J Bugs . Let me tell you they are not as well made as the ones you posted. All sorts of casting flash to trim off and they are not shaped well. I hope they work since they are the same on my 73 type 3 . |
shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Fri Jan 03, 2020 5:42 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
djkeev wrote: |
Dave |
My 74 Super Beetle has these along with the ones you have shown. They fit inside of the seat guides at the very back of the guide. Part # 311 881 349 for the inner rail and 311 881 347 for the outer rail
_________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Fri Jan 03, 2020 5:55 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
Shakers, where did you get those rear—end—pieces?
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Fri Jan 03, 2020 7:40 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
Tim Donahoe wrote: |
Tim |
There was one pair in the car when I bought it. I finally found a used pair for the other side @ https://www.bugcity.com/shop/shop.lasso?pquery=seat+track _________________ shakers73
'74 Super Beetle
'67 Beetle
Posted: Fri Jan 03, 2020 8:08 pm Post subject: |
So that's why my seats will just keep going back until they fall off the track.
I'm missing that piece, apparently.
Tim |
This is what stops the seat from sliding out the back of the seat rail guides. You have to press it down with a flat screwdriver to let the seat slide out the back of the guides.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=333288 _________________ shakers73
'74 Super Beetle
'67 Beetle
Posted: Sat Jan 04, 2020 1:16 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
Shakers, I found the flat seat retainer springs in a coffee can that the PO had given me, and installed them. So, the seats no longer slide off the tracks.
The end caps seem more likely to keep people that are getting in the back seat, from catching their shoes (or bare feet) on the rear edges of the track.
Richard O'Brien |
sjbrice Samba Member
Posted: Mon Mar 23, 2020 7:58 am Post subject: Re: 1974 and newer Seat Guides, How to Install |
Hello!!
I would love to hijack this thread since I have searched the entire world on google. I know someone in here has done this repair before.
It's called the Seat release pull cable on the back rest. (1975 error seat) My passenger seat will not fold forward when you pull up on the back rest release. So I took my seat out and then separated the top from the base. If you look in the side channels towards the bottom, you can see the release cable attached to a camber. So pulling on the release latch I notice one side is working better than the inner side.
How in the world does this mechanism work, and how do you adjust these cables to rotate the chamber properly? Feel free to email me, call me.. lol I am lost for instructions since I have not found any online. My manual will be here today hopefully for the car, but not sure if they cover this problem.
I am also open to purchasing someones 75 passenger seat if that's less of a hassle than repairing this. |
Posted: Wed Mar 25, 2020 4:02 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
sjbrice wrote: |
Hello!!
Have it all fixed! Pulled the cover and removed the slack in the long cable!! |
Posted: Mon Mar 30, 2020 3:16 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
I am in the process of restoring my 75 beetle. I just completed this task on my seat rails. I sanded them down and cleaned everything up. I ordered a set of seat sliders from jbugs and tried installing the seats today. Here is the problem I am having with the replacement sliders. They fit on the inner rails close to the hump totally fine. However both outer rails by the door appear to be slightly shorter in height so the slider does not fit. I noticed on my 75 bug that the OEM ones are a much thinner material and the clip was a two piece style verse this replacement as one piece.
Does anyone know if there was a change on the 75+ seat rails? I thought about sanding down the outer sliders clips but I would need to take out about 2mm in the height.
Below are the OEM two piece sliders that were in my 75 beetle. Much thinner than the ones sold now as the replacemen and not as tall when installed.
Pollock74Super Samba Member
Posted: Fri Dec 10, 2021 11:40 am Post subject: Re: 1974 and newer Seat Guides, How to Install |
The seat guides you posted are stock and fit a little better than the replacements. I had to sand the rectangle replacements down a little to fit in my 74 super. |
Windisch Samba Member
Joined: October 30, 2014 Posts: 361 Location: Sacramento, CA 95822
Posted: Sat Jul 09, 2022 3:58 pm Post subject: Re: 1974 and newer Seat Guides, How to Install |
Reference all of the above topic discussion: I am using it to reupholster and reinstall the seats in my 73 Standard Bug and find all of it VERY helpful, especially the images! Thanks to all for helping make this otherwise perplexing procedure so much more 'understandable'! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Der Volkswagen ist ein Ausdruck der deutschen Kultur der Allrad Art ...
[The only irrefutable evidence we have that intelligent life truly exists elsewhere in the Universe is the fact that so far it has NOT contacted humanity...] |
