qwerty8669 Samba Member
Joined: January 07, 2012 Posts: 231 Location: kentucky
Posted: Tue Jan 10, 2012 5:11 pm Post subject: everybody else has a baja thread here's mine |
bought the car as is ....but gonna do some "mild" things to it...
heat is not as good as alot of guys are getting. and since this is gonna be a daily driver i need to get the heat better. thermostat and flaps are gone along with preheat hose ( though i can't find where to hook it up on mine ?)
will eventually step the displacement up a little not want ing to go bigger than 1904cc
has cheap coil overs on it right now.....need to find a reasonably priced replacement for those...
31x10.50 on the back.
factory seats out of something ....can't identify them right off hand if anyone else could it would be nice as i might try to cram another set in the rear
want to add a light bar and rack on the roof along with a winch
more than likely i will have the entire car sprayed with rino liner
rancho tranny being order to put in in the spring
currently swing axle but i see that you can change it to irs without replacing the transmission just changing out parts
:::::::pics::::::::
interior....like i said gotta figure out where those seats came from
you can see the "heater hoses" in this one they are shop vac hoses the one on the passanger side is long enough that i added one of my vac hose attachments to it and hung it on the factory grab handle for a temp defrost
want to move the light on the bottom of the bar possibly flipp them upside down since the main beams are right behind them
enigine closer up
one i took this morning after dropping the kids off at school
STOICH Samba Member
Joined: November 26, 2004 Posts: 1100 Location: Fallbrook
Posted: Tue Jan 10, 2012 6:51 pm Post subject: |
STOICH wrote: |
my! that's quite a light setup on the front of that thing... |
well like i said gotta figure out where im gonna move the bottom two (if i move them ) gonna add rack on top.......now that i think about it i might add two in the back ....
any suggestions on affordable shocks? |
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Tue Jan 10, 2012 7:44 pm Post subject: Re: everybody else has a baja thread here's mine |
can you get a picture under the front that shows how the front is cut and filled? fun looking car but too clean. |
bossride Samba Member
Joined: September 10, 2008 Posts: 204 Location: Top of Mississippi.
Posted: Tue Jan 10, 2012 9:43 pm Post subject: |
If that's a '68, that's a good, one year only swing axle (with 4 lug).. save it for something else or sell it. _________________ '59 Beetle.
'66 Beetle.
Yellow rail buggy. |
Posted: Wed Jan 11, 2012 8:06 am Post subject: Re: everybody else has a baja thread here's mine |
pafree wrote: |
once it quits raining
bossride wrote: |
yeah i found that out last night about it being a one year car...(thanks to some reading i was doing on this site so much good info here)..was telling my buddy how i hate it was cut up and all...... so im kinda in limbo about it now. i really don't think i will sell it unless i get a really nice offer on it
problem with selling it is that here in kentucky not many people think they are worth much..... guy offered to buy it from me at a gas station once "was gonna give me top dollar" for it $2200. yeah .....right.
when i say mild i mean like stepping up to Bilstein Shocks shocks instead of the cheap coil overs that are on it and replacing / upgradeing bushings trans mount maybe a 1904 to put in it later.....gonna keep the motor and trans thats in it and "shelf them" for later
this bug will not be jumped ....mudded...or the likes. when i get off road it will be slow going easy trails to get off the black top and see things that would take you forever to hike to.
""Black Mountain is managed by the Harlan County Outdoor Recreation Board Authority and has over 6,000 acres of mountainous terrain (elevations up to 3,300 feet) with over 200 miles of marked and rated trails. They have beginner, intermediate and extreme rated trails available for the riding enthusiast. Trail maps are available and there is primitive camping. Best of all, there are no fees or permits required to ride. The riding area is open all day year-round.""
somewhere like that where the trails are kept up and one could keep from tearing up your vehicle....buddy of mine grew up near one close to here and said they took a 2 wheel drive ranger out there and said some trails where basically gravel roads...... |
Posted: Wed Jan 11, 2012 8:27 am Post subject: |
For what you are wanting to do with it, it's perfect. Plenty of guys run swing axles, it's just when you get into wanting more travel and stuff the IRS starts to be a better choice.
I'd raise the front end a little, and go play..... _________________ '59 Beetle.
'66 Beetle.
Copernicus Samba Member
Joined: November 22, 2011 Posts: 244 Location: Sandy, Utah
Alex Patterson Samba Member
Posted: Wed Jan 11, 2012 9:00 am Post subject: |
Is your engine a 1600? Them tires are 31's? |
Posted: Wed Jan 11, 2012 2:09 pm Post subject: |
Alex Patterson wrote: |
1500 or 1600....guy i bought it from didn't know anything about the car...nor did he try to find out and 1600 pistons can be bolted on a 1500 its hard to tell
31x10.50 r15 ProComp on back and 215/65 r15 BFgoods on front |
Posted: Wed Jan 11, 2012 2:14 pm Post subject: |
Well, if that's the car's original engine, which it kind of looks like with the dual snorkle air cleaner, and it's not a dual port, and the intake diameter is fairly large, it is at least based upon the 1500. You could check the numbers below the generator stand and see.
1600 pistons will fit, but it's probably a 1500, if I had to guess... _________________ '59 Beetle.
'66 Beetle.
Posted: Wed Jan 11, 2012 2:56 pm Post subject: |
bossride wrote: |
1600 pistons will fit, but it's probably a 1500, if I had to guess... |
yeah i looked into all that when i got it. runs strong and looks like the guy that put it together replaced a bit of stuff.....kid i bought it from got it and just started it up in the driveway and drove it around the neighborhood every so often....for a year and a half.
i would say 1500 also but i add the / 1600 because it might be stepped up. need to measure the pistons, but i have no desire to take it apart since it does run so well _________________ 68 swing axle baja ( making 4x4s look stupid )
67 F100 Big Block ( loud gas eater )
97 civic hatch ( grocery getter )
90 t-top 300zx 5speed ( ticket monster )
looking for swap meets and places to ride in ky and tn
my build ( gonna be slow ) can anyone tell me what my seats came out of....???
http://www.thesamba.com/vw/forum/viewtopic.php?t=495087&postdays=0&postorder=asc&start=0
car's facebook page ... like it !!
http://www.facebook.com/68bajabug?ref=hl |
Posted: Wed Jan 11, 2012 4:35 pm Post subject: |
Ok. I was just curious. I got a similar setup in the frankenbaja and been thinking of going to a 30 inch tire. Wondering how's the performance. |
Posted: Wed Jan 11, 2012 4:53 pm Post subject: |
not bad i would say..... 4th is about the only issue i drive it to work daily and it slows down for the hills but i don't have to down shift on the highway _________________ 68 swing axle baja ( making 4x4s look stupid )
Posted: Wed Jan 11, 2012 7:20 pm Post subject: |
Thank you. I was told id be fine with 235's, but I found a good deal on some Mastercraft mud tires in 30's.
Ok. Sorry for the hijack.
I like your baja by the way. |
Posted: Wed Jan 25, 2012 5:23 pm Post subject: |
well things took a turn for the worse....no running lights all of a sudden checked all fuses they are good..........
4th went out also, so it looks like i am going to start pulling the trans axle, i knew this was going to happen and have already looked into getting something from rancho...
i'm going to trace down the wiring issue while it is out and clean up the trunk compartment, the guy that put it together added another fuse bus and relays for the head lights and such but has it looking like a rats nest of wires.
also while working on it as the sun was going down i done something, and the generator isn't powering the car anymore, when i turn the battery disconnect off behind the passenger seat the car dies now.
that something was seeing if i could run a wire from where the gen connects by the firewall (picture 5 the block that is on the fire wall driver side in pic) to power the running lights when the gen is working.....basically i ran it straight off the gen to the lights and it done nothing when i started the car, so i removed it and left it as it was before i started fooling with it and now the gen doesn't seem to be putting power back into the system.......
will take photos for Pafree while i have the truck opened up
the four way connectors that just hand inside the engine compartment on either side of the motor kind bother me.....need to find a way to mount them or get rid of them altogether.
any advice on adding more relays or better ways to wire it up would be welcomed. i know it is a simple system as is but want to make it easier to trouble shoot if an issue arises again. and less wires in the system makes it cleaner and easier. _________________ 68 swing axle baja ( making 4x4s look stupid )
Posted: Fri Jan 27, 2012 3:21 pm Post subject: |
Got running lights on for the moment seems the original fuse box is shot......gen started working.......got to get some wire and relays.......and gonna replace the bulb holders _________________ 68 swing axle baja ( making 4x4s look stupid )
Posted: Tue Feb 07, 2012 5:13 pm Post subject: |
Ordered new boots for axle along with new air filter ( original was randomly chocking car out even after cleaning it)
Wait time on rancho transmission is 3 weeks......order has been put in just got to wait it out..
Powdercoated candy blue
Anything I should do while I have the trans and motor out ....? _________________ 68 swing axle baja ( making 4x4s look stupid )
larryvance66 Samba Member
Joined: January 27, 2009 Posts: 731 Location: Virginia
Posted: Tue Feb 07, 2012 6:14 pm Post subject: |
Quote: |
Anything I should do while I have the trans and motor out ....? |
Solid mounts. Check clutch wear or upgrade. _________________ I got a Volkswagen for my wife....Best trade I ever made! |
Posted: Tue Feb 07, 2012 6:46 pm Post subject: |
larryvance66 wrote: |
Solid mounts. Check clutch wear or upgrade. |
was thinking of putting in rhino mounts....
or fabbing something up....or is there a reasonable solid mount kit out there?
stock 1600cc
clutch feels real solid at moment going to newer style T/O , Mike at Rancho actually talked me out of the kennedy 1700 clutch and pressure plate. was thinking about replacing / upgrading while i had it all apart. but his advice was to leave the stock clutch in till i go up in displacement......
should i have went ahead and gotten it anyways ? seems odd that he advised me not spend more money was going to add hd hockey stick and new input shaft and clutch to order, but given my current application he felt it would be wasted money at the time....of course i took his advice _________________ 68 swing axle baja ( making 4x4s look stupid )
