lsilverman11 Samba Member
Posted: Sat May 08, 2021 8:26 am Post subject: Exhaust Pipes/Air Hoses |
Hello,
Looks like the aftermarket exhaust system that PO put on my bus is blocking the pathway for the air hoses that run to the heat exchangers. They had hoses in there but they were squished and mangled to fit around the exhaust system. Any suggestions?? Do I need to take this whole mess off and put the proper muffler on? See picture.
Thanks,
Larry
Posted: Sat May 08, 2021 11:47 am Post subject: Re: Exhaust Pipes/Air Hoses |
Maybe recut the hole in your rear tin to get better alignment. These tins are pretty plentiful if and when you go back to a stock style exhaust.
Once you have the new holes, an exhaust shop could probably make you a pair of ducts to go from the heat exchangers up through the tins for pretty cheap. |
consvws Samba Member
Joined: April 07, 2009 Posts: 949 Location: Roseburg, OR
Posted: Sat May 08, 2021 2:43 pm Post subject: Re: Exhaust Pipes/Air Hoses |
I'd find a stock muffler for it. They sound & look much better plus no hacking would have to occur.
Conrad |
crownline Samba Member
Joined: September 10, 2010 Posts: 589 Location: Northwoods of WI
Posted: Sat May 08, 2021 3:26 pm Post subject: Re: Exhaust Pipes/Air Hoses |
If you google stock muffler you will see the connection from upper hose to lower. Maybe you could make something like that to replicate. Make it in 2 halves to wrap around pipe. I agree a stock muffler would be the way to go. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
