Odyssey PC 1500 does it fit in Aux Battery Box
Westified
Westified is offline
PostPosted: Thu May 02, 2013 4:17 pm    Post subject: Odyssey PC 1500 does it fit in Aux Battery Box Reply with quote
I have been searching the forum and unable to find if anyone has installed an Odyssey PC 1500 under the drivers seat in the Auxiliary Battery box. I am in the process of installing an auxiliary battery in my 1984 Westy Wolfsburg and would like to fit the largest Amp Hr. battery in the battery box. By my measurements it will just fit but, maybe there is something I am not accounting for. I first considered an Odyssey PC 1200 which I know will fit but is 42 amp hr versus 68 amp hr. Any suggestions would be helpful.
Californio
Californio is offline
PostPosted: Thu May 02, 2013 4:29 pm    Post subject: Reply with quote
I don't know about that particular battery, but an important measurement is between the top of the posts and the bottom of the battery. There are some you can cram in there, but if the positive post hits the battery box lid...
Also, never saw the posts off a battery to get it to fit. I tried that trick with an Optima, wrecked the battery.
I've had much better luck putting a small car battery in the aux. spot, then wiring two other ones in the compartment behind the fridge.
Westified
PostPosted: Thu May 02, 2013 5:52 pm    Post subject: Reply with quote
I am concerned about hitting the lid. I was planning to install the battery on its side. It does not use posts but has studs for bolts which are a lower profile. The Dimensions L x W x H (in) 10.85x6.99x7.12. I measured my Aux battery box and it is 11 7/8 wide 7 deep 7 1/4 wide. The width of the battery box is actually 12 1/4 but there is a stud on the right side that supports the lid which reduced the clearance to 11 7/8. I was hoping someone has installed one of these to confirm if the studs would clear the lid.
Westified
PostPosted: Thu May 02, 2013 6:09 pm    Post subject: Reply with quote
I am not sure what i did wrong my photo did not show up here. It is in my gallery. Oh well. Rolling Eyes
Westified
PostPosted: Thu May 02, 2013 6:12 pm    Post subject: Reply with quote
Here it is. Laughing
plysaker
plysaker is offline
PostPosted: Fri May 03, 2013 6:11 am    Post subject: Reply with quote
Did it fit? Let us know!
[email protected]
john@aircooled.net is offline
PostPosted: Fri May 03, 2013 7:22 am    Post subject: Reply with quote
as soon as I know if it fits I'm buying one for the same reason.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
whynotvw
whynotvw is offline
PostPosted: Fri May 03, 2013 7:30 am    Post subject: Reply with quote
I've had Odyssey 1700 under my driver seat without any problems.
Summers420us
Summers420us is offline
PostPosted: Fri May 03, 2013 7:36 am    Post subject: Reply with quote
http://www.odysseybatteries.com/battery/pc1700series.htm
Hmm... 68 Amp Hour... $alty price tag though...
Got a pic of it installed? You know the rule... pictures or it isn't true.
1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.)
IrideWheelies
IrideWheelies is offline
PostPosted: Fri May 03, 2013 7:37 am    Post subject: Reply with quote
You can save a lot of money at sears.
http://www.thesamba.com/vw/forum/viewtopic.php?t=508148&postdays=0&postorder=asc&start=0
The 1750 fits with ever so slight of a modification to the battery lid. I have two of these now, one under each seat. The passenger side battery is upright like the stock one. I had to tweak the door to make it fit.
89' Dove Blue Syncro Hightop
syncroid
syncroid is offline
PostPosted: Fri May 03, 2013 9:41 am    Post subject: Reply with quote
Iride, can you describe the tweaking? Is that a modification to both driver's and passenger lids?
IrideWheelies
PostPosted: Fri May 03, 2013 11:08 am    Post subject: Reply with quote
I didn't modify the drivers side because the battery is laying on its side and fits perfectly. I modified the passenger side with one firm smack from the round side of a ball peen hammer to make room for the positive post and clamp.
I have a syncro, if you have 2wd you might not have to make any mods at all. I've heard the syncro battery box has a little less room on the bottom outside corner to clear the tires under full suspension compression. I haven't verified if this is true, maybe someone else here can.
IMHO, the die hard P2 is the best choice for the factory battery box in a vanagon. The warranty is outstanding, it's powerful and robust and the price is great.
syncroid
syncroid is offline
PostPosted: Fri May 03, 2013 1:20 pm    Post subject: Reply with quote
But the P2 requires a cut lid around the terminals and the sears group 65 (aka Odyssey 1750) does not, correct?
http://www.sears.com/shc/s/p_10153_12605_02850065000P?prdNo=4&blockNo=4&blockType=G4
IrideWheelies
PostPosted: Fri May 03, 2013 2:05 pm    Post subject: Reply with quote
I think the P2, odysee pc-1750 and group 65 are all names for the same battery.
Search the archives, I think 2wd folks can fit it upright with minimal or no modification. It will fit on its side with no mods for sure.
sanfordphoto
sanfordphoto is offline
PostPosted: Mon Oct 28, 2013 8:31 am    Post subject: Question Odyssey 1750 or 1700 or Sears group 65 battery????? Reply with quote
So, after owning my syncro camper for 14 years and going through about 5 yellow top Optima batteries I'm moving on to the Odyssey brand. Question is, should I go to the 1700 or 1750 for the cleanest easiest fit? Thoughts?
Btw., I spoke to the factory tech and she said the battery requires at min 14.1 /14.2v constantly from the alternator. I have a bostig conversion that I do indeed read 14.2 at the battery ports.
Lastly, is the less expensive sears battery really the same and does it fit???
Thanks,
Sanford
ThankYouJerry
ThankYouJerry is offline
PostPosted: Fri Nov 08, 2013 7:59 pm    Post subject: Reply with quote
Does anyone have a photo of the 1700 or 1750 mounted under the front seats?
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
Lapprentis
Lapprentis is offline
PostPosted: Sat Nov 16, 2013 7:35 pm    Post subject: Reply with quote
According to Odyssey measurements: the 1750 seem too high to get in without modidications to the lid. Is there anyone that succeded with the 1700 ? they are 13 inches long.....How could they fits in there ?
Keep us in touch guys.
Lapprentis
rotaecho
rotaecho is offline
PostPosted: Tue Jul 15, 2014 7:00 pm    Post subject: Reply with quote
Anyone have an update or even better of a photo with the 1700/1750 in a Westfalia with swivel seats?
As for the battery lid, I'm removing it and putting thick honker insulated boots for the connectors. A metal lid just doesn't sit well with me Smile That and I want fast and quick access to the terminals as a safety.
-Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com
rotaecho
rotaecho is offline
PostPosted: Mon Jun 01, 2015 10:15 pm    Post subject: Reply with quote
I have the 1750 under each seat.
http://www.thesamba.com/vw/forum/viewtopic.php?t=602412&highlight=
Kicks fucking ass 73ah next best is Lifeline at 100ah.
You pay for what you get.
Sure Diehard platinum sears is available. But you "really" don't know if it's an Odyssey.
Odyssey if treated right will last a LONG LONG time.
-Will
thatvwbusguy
thatvwbusguy is offline
PostPosted: Tue Jun 02, 2015 3:55 pm    Post subject: Reply with quote
Looking through this thread and the specs on www.odysseybattery.com , I am coming up with the following data for the Odyssey PC1700:
Capacity: 68Ah @ 20 hour rate
Price: $270.00 (cheapest price I could find online)
Warranty: 2 Year with the following verbiage:
"Overcharging, undercharging, charging or installing in reverse polarity, improper maintenance, allowing the Battery to be deeply discharged via a parasitic load or mishandling of the Battery such as but not limited to using the terminals for lifting or carrying the Battery. Trickle chargers that do not have a regulated trickle charge voltage between 13.5V and 13.8V (no lower than 13.5V and no higher than 13.8V) will cause early failure of the Battery. Use of such chargers with the Battery will also void the Battery’s warranty.For applications where an alternator is present, the alternator must deliver between 14.0V and 14.7V when measured at the Battery’s terminals. Consult the ODYSSEY battery technical manual or owner’s manual for any necessary temperature compensation. Alternators that do not have a regulated charge between 14.0V and 14.7V (no lower than 14.0V and no higher than
14.7V) will cause early failure of the Battery. Use of such alternators with the Battery will also void the Battery’s warranty".
Requires installation of an adjustable voltage regulator to meet battery manufacturer warranty specs in an otherwise stock Vanagon.
Does not fit in the factory battery box without modification (confirmed via dimensions on battery manufacturer website).
With all of these factors in mind, this seems like one of the most expensive, least desirable options available for Vanagon auxiliary power in my opinion.
This is not meant to be critical of anyone's choice to install this (or any other) battery, only an observation of the typical cost vs. benefit analysis that many people would apply when choosing an auxiliary power source.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
