1967 Beetle Original Tires Size
2067Bug
2067Bug is offline
PostPosted: Wed May 08, 2013 3:35 pm    Post subject: 1967 Beetle Original Tires Size Reply with quote
Hi - What is the stock (original) tire size for a 1967 beetle? Also, please let me know where to buy new ones. Thanks
DuaneL
DuaneL is offline
PostPosted: Wed May 08, 2013 4:15 pm    Post subject: Reply with quote
original as stated in the 67 owners manual wich can be found uneder technical at the top of the page was 5.60 x 15 wich are not easily found most people use 165sr15 or 165/80/15 wich are also not stocked everywhere but can be found as this post discusses http://www.thesamba.com/vw/forum/viewtopic.php?t=286556&highlight=tire
____________
1971 std bug, 1776, ACN Super Stock 34-3, dvda dist, 27x8.50 14 tires
61SNRF
61SNRF is offline
PostPosted: Thu May 09, 2013 7:54 am    Post subject: Reply with quote
Here's one choice...
http://www.americastire.com/dtcs/tires/kumho/size/...amp;cs=165
-Bruce
An ounce of prevention is worth a pound of cure.
oldPSUguy
oldPSUguy is offline
PostPosted: Thu May 09, 2013 12:13 pm    Post subject: Reply with quote
That is a very good price. I have those tires but paid substantially more for them in the LA area.
jhicken
jhicken is offline
PostPosted: Thu May 09, 2013 12:24 pm    Post subject: Reply with quote
Coker has many to 560/15's to choose from.
http://www.cokertire.com/catalogsearch/result/?yea...p;q=560-15
Personally, unless you are producing a concourse restoration that won't necessarily see much drive time, I'd pick up a set of 165/15 radials. Stock appearance but better handling than the bias plys.
-jeffrey
Der Kleiner Kampfwagens
Central Jersey Volkswagen Society
2067Bug
2067Bug is offline
PostPosted: Thu May 09, 2013 5:36 pm    Post subject: Reply with quote
Really appreciate the responses - thank you.
crvc
crvc is offline
PostPosted: Fri May 10, 2013 9:07 am    Post subject: Reply with quote
http://www.walmart.com/ip/Nexen-11766NXC/19473481
I had to order a set from Walmart. Took three days to get here. I haven't driven enough to get a feel for whether they're better than the baldies I had.
crbv
