davidsoc30 Samba Member
Joined: August 28, 2007 Posts: 17 Location: Branford, CT
Posted: Thu Jun 25, 2009 2:57 pm Post subject: Decklids |
Would a convertible decklid fit on a regular 63 beetle? I put a 2110 engine into my beetle and was looking for ways to get air in there without having to use standoffs. I thought maybe a convertible decklid with louvers would help. Any suggestions? |
Bart Dunn Samba Consiglieri
Joined: May 09, 2004 Posts: 2354 Location: Sea level (Mid Atlantic)
Posted: Thu Jun 25, 2009 3:23 pm Post subject: |
It should fit just fine all things being equal, provided the decklid latch will fit the catch on the apron. The only differences in the decklids are the vents and the rain trays.
From '58 - 63 with the T-handle latches, any should work fine, but, from '64-'66 with the square push button latch you'll need a little catch that you can attach to the apron. _________________ Not enough car seats fit into my:
'58 Beetle convertible
'58 Beetle sedan |
kahala46 Samba Member
Joined: April 16, 2007 Posts: 221 Location: Mesa Arizona
Posted: Thu Jun 25, 2009 4:14 pm Post subject: |
I think you will have to take off the rain tray if you have duel carbs |
akokarski Samba Member
TWD Samba Member
Posted: Thu Jun 25, 2009 5:10 pm Post subject: |
I don't know if Bill May still sells them, but I bought one from him a few years ago. It wasn't as "finished" looking as this one, but a lot less expensive. |
rezidu Samba Member
Joined: November 08, 2004 Posts: 197 Location: Fayetteville NC
Posted: Thu Jun 25, 2009 5:19 pm Post subject: |
use a tennis ball on the latch trick. |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3448 Location: Vulcania
Posted: Thu Jun 25, 2009 8:38 pm Post subject: |
Bart, 64 is the last year with the "T" handle.
Don |
willydozier Samba Member
Posted: Fri Jun 26, 2009 8:35 am Post subject: |
Yes a convertible decklid is a direct swap providing its a compatible year. In your case, 58-63. 64 would fit but be incorrect. I went to a 64 vert lid on my 64 w/ 1776- dual Kads. I am running the raintray but had to go with smaller aircleaners. Tray will not fit with many dual carb aircleaners and typical high set hex linkage, but you'd still get the added airflow just be aware of water on your motor. |
jhicken Samba Member
Joined: October 24, 2003 Posts: 9466 Location: Fallbrook, CA
Posted: Fri Jun 26, 2009 7:17 pm Post subject: |
You could run an earlier W decklid as well. If you're interested I can help you get one with or without rain trays.
-jeffrey _________________ Der Kleiner Kampfwagens |
Posted: Fri Jun 26, 2009 8:08 pm Post subject: |
How does the tennis ball trick work |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Fri Jun 26, 2009 8:10 pm Post subject: |
kahala46 wrote: |
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 27, 2009 6:27 am Post subject: |
There is nothing holding the deck lid closed except the spring at the top.Does it swing open a little when you start out. |
nazareth4 Samba Member
Joined: June 04, 2009 Posts: 24 Location: Nazareth PA
Posted: Sat Jun 27, 2009 10:40 am Post subject: |
Tennis ball works well. Don't think my decklid is bouncing much and temps have dropped. After an hour drive even the T handle was very hot forget about holding the dipstick for long. Haven't been on a long drive yet but went about 20 minutes yesterday without tennis ball measured 196 degrees. Same 20 minutes today measured 182. |
metalchomper Samba Member
Joined: June 27, 2005 Posts: 703 Location: Statesville, NC
Posted: Sun Jun 28, 2009 6:05 pm Post subject: |
jhicken wrote: |
-jeffrey |
Will a '58-'63 popes nose fit on these? I'm thinking about doing this on my '62 but the cost of early popes nose is making the cost of this conversion too high. _________________ Brett
Devil Dog Dubs
I live vicariously through me
'62 Beetle, "Zombie Mojo"
'68 Manx II "Conundrum"
'72 SB "Luftwaffle", 2270 T4
'75 SB Wizard Rodster "Olympias" (Mrs. Metalchomper's car) |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Jun 28, 2009 7:38 pm Post subject: |
A "pope's nose" will fit an early W (split era) decklid- as it should. However if you are referring to a '58-'63 license light- it will not. A "pope's nose" light comes to a rigid point at the top- matching the peak of the center of the decklid- and has curved, convex underside (hence the nickname). Besides, a later light on an early decklid is a travesty- and your friend count will plummet. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Jun 29, 2009 9:17 am Post subject: |
hitest wrote: |
A "pope's nose" will fit an early W (split era) decklid- as it should. However if you are referring to a '58-'63 license light- it will not. A "pope's nose" light comes to a rigid point at the top- matching the peak of the center of the decklid- and has curved, convex underside (hence the nickname). Besides, a later light on an early decklid is a travesty- and your friend count will plummet. |
Thanks for the info! How did you know my middle name is Travesty. _________________ Brett
Devil Dog Dubs
Posted: Mon Jun 29, 2009 10:22 pm Post subject: |
As noted, a "Pope's Nose" light is specific to split era cars, although the decks are similar, the mounting is different which is completely different from the '58-early '64 lids. For your application, you should use the 56/57 lid. The proper license plate light would be from a late '52-'57. Wolfsburg West makes a good repro for about $25 or you can find them easily on the Samba Classifieds.
Posted: Tue Jun 30, 2009 9:03 am Post subject: |
jhicken wrote: |
-jeffrey |
Thanks for the info. I've always wanted a vert W lid. I may even make an aluminum copy of it after I master the aluminum fenders. _________________ Brett
Devil Dog Dubs
glutamodo The Android
Joined: July 13, 2004 Posts: 26302 Location: Douglas, WY
Posted: Tue Jun 30, 2009 2:22 pm Post subject: |
I put a 62 convertible deckid on my 62 and it worked just fine, but mine has just the stock engine/carb on there. As mentioned the rain tray might have issues with different carbs.
And for the early T-handle style decklid, I've just used a sping clamp or two, attached at the bottom as and easy temporary bottom-standoff:
And the people taking about the "Pope's Nose" - they beat me to it, that's a term that annoys me as well and I would have mentioned it too - the license light they talk about is one that actually resembles a nose if you look at it from the side, and the 58-63 really do not in comparison:
