1915cc T Samba Member
Joined: May 09, 2013 Posts: 1 Location: Kelseyville Ca
Posted: Thu May 09, 2013 11:40 pm Post subject: 9-digit vin help |
I'm trying to look up the history on my newly purchased (69?) bug.Seller had no paper work for it,she said it is a 69 I think it is a 66,it has a 9-digit vin,all the dmv web sights that an invalid number,can anyone help with this,I also just bought a 73 with papers it has a 10 digit vin.Would like to look this up before I go to the dmv. Any suggestions. |
B52Gunner Samba Member
Posted: Fri May 10, 2013 5:23 am Post subject: |
The samba.com has everything you need.
Try looking in the Technical section up above (just below the banner ad).
9 digits sounds right for a 69. _________________ 1969 Beetle - "Olive"
Never featured in Hot VW's magazine |
cseay1 Samba Member
Joined: March 22, 2012 Posts: 1341 Location: Elkwood VA
Posted: Fri May 10, 2013 6:00 am Post subject: |
1969 model year Beetle used nine digit chassis number from January thru May production. The range of chassis numbers is
119565362 thru 119942556 (note third digit "9" for 1969)
Starting in June 1969 model year Beetle used a ten digit chassis number, and production continued with this sequence through July. This range of chassis numbers is
1191040194 thru 1191093704 (note third digit "9" for 1969)
Starting in August, the 1970 model year production began, starting with chassis number 1102000001 (note third digit "0" for 1970) |
cseay1 Samba Member
Posted: Fri May 10, 2013 6:04 am Post subject: |
Also check to make sure that your body plate (behind the spare under the hood) and chassis plate (on the hump under the back seat) match. If not you may have had a body swapped onto a different year pan.
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Fri May 10, 2013 6:07 am Post subject: |
B52Gunner wrote: |
9 digits sounds right for a 69. |
or, here:
http://www.thesamba.com/vw/archives/info/bugchassisdating.php _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Posted: Fri May 10, 2013 10:16 am Post subject: |
My original post was made using the "teach a man to fish..." principle. That, and I was in too much of a hurry to put the link there _________________ 1969 Beetle - "Olive"
LauraM Samba Member
Joined: May 07, 2015 Posts: 3 Location: High River Alberta Canada
Posted: Fri Aug 21, 2015 11:55 am Post subject: VIN on my ’65 Convertible |
It seems to be missing a second “1” at the beginning. I am assuming from the notes here that it should be 1155711577 instead of what I see actually on the plate which is 155711577.
On this plate, the “15” at the beginning is embossed and the rest of the numbers are punched on top.
Am I figuring this out correctly? My best guess, from your VIN section, is that it was made in March 65.
Anyone want to check my work?
Laura |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
LauraM Samba Member
Posted: Sat Aug 22, 2015 12:09 am Post subject: VIN check |
Thank you!
I was popping off the assembly line in April ’65 as well!
I guess she (my Beetle Ruby) and I were meant to be a pair!
Laura |
LauraM Samba Member
Posted: Mon Aug 24, 2015 4:19 pm Post subject: Another VIN Check |
Thank you! Very much!
Could I ask for your help on one more? I just picked up what I thought was a ’66 bus, but it appears to be a ’65.
The VIN is 225010590
Could you help me figure this one out too? Please and thank you!
Laura
High River, Alberta |
busdaddy Samba Member
Posted: Mon Aug 24, 2015 6:17 pm Post subject: |
3rd digit says 65, the M plate behind the RF seat will solve all the mysteries. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
nevets7 Samba Member
Posted: Mon Jun 18, 2018 9:53 pm Post subject: Re: 9-digit vin help |
i have a 10 digit code on my super beetle 1342531094 need some help decoding. looked at the in formation in technical area and pardon the expresion its all greek to me. any help woulb be greatly apreciated. thanks steve |
janerick3 Samba Member
Posted: Mon Jun 18, 2018 10:03 pm Post subject: Re: Another VIN Check |
LauraM wrote: |
Laura
1965 model year buses have emergency flashers, so they are often mistaken for 1966, as Type 1 and Type 3 VWs didn't get them until 1966. _________________ Thanks,
Jan K. |
Posted: Mon Jun 18, 2018 11:14 pm Post subject: Re: 9-digit vin help |
nevets7 wrote: |
This looks normal to me
13 = model #. 13 = Super Beetle
4 = 1974
2 = 2nd generation of VIN #s
531094 - Car # 531094 off the 1974 production line _________________ How to Post Photos
Jerkstore Samba Member
Joined: May 08, 2019 Posts: 19 Location: Washington, DC
Posted: Thu May 16, 2019 2:42 pm Post subject: Re: 9-digit vin help |
EverettB wrote: |
nevets7 wrote: |
4 = 1974
531094 - Car # 531094 off the 1974 production line |
Resurrecting this thread to decipher a new arrival: 1582033852. Using the above crib sheet, it would be
15 = model (convertible)
8 = 1978
2 - 2nd generation of VINS
033852 = Car 33,852 off the 1978 production line
? Thanks!
Pete |
Posted: Fri May 17, 2019 11:27 am Post subject: Re: 9-digit vin help |
Thank you. |
Sean Paul Samba Member
Posted: Sun Oct 11, 2020 9:46 am Post subject: Re: 9-digit vin help |
I'm new here. So I'd like to say hi. Hi. I read the post, went to the link, and I'm still a bit confused. I'm looking at a bug with a 9 digit vin#. Simple, yes? The 3# prefix is 114. According to everything I've read on here, and other sites, indicates that this would then be a 64. But that doesn't fall inline with the chart, which shows that it should either have a 7 digit vin or have a prefix of 115. Can anyone shed a little light on this, please? |
h~moto Samba Member
Joined: November 19, 2008 Posts: 317 Location: Northern Virginia
Posted: Tue Oct 13, 2020 3:48 pm Post subject: Re: 9-digit vin help |
I don't believe that there was ever a 9 digit VIN that started with 114.
VIN's with the third digit indicating the year did not begin until the 1965 model year which started in August of 1964. |
Abscate Samba Member
Posted: Thu Oct 15, 2020 8:16 am Post subject: Re: 9-digit vin help |
Sean Paul wrote: |
Post your VIN AND PEoplecwill tell you what you have.
I don’t get why people try to hide their VINS, wIerd. _________________ .ssS! |
