Kman1983 Samba Member
Posted: Mon May 27, 2013 4:06 pm Post subject: |
I went through the shed at my dads yesterday. I do have a 6 volt starter but I couldn't find a 6 volt generator The only down side I can really see to running it as 6 volts is that I won't be able to use the little winch I was going to mount on the front. Any idea on the cost to rewire a 6 volt generator to 12 volts? I have also considered mounting a 6 volt generator to spin the fan and fab some brackets to mount a GM alternator...although I didn't really look at the engine to see if this would be possible, it's a thought anyways. _________________ Veni, vedi, vici...I came, I saw, I conquered |
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Sun Jun 02, 2013 6:57 am Post subject: |
With the fixed generator stand I'm stuck running the small 90mm generator so my options are limited for a 12v generator. Looks like it would be $400.-$600. for a 12v small diameter generator. I bought a 6 volt generator off the classifieds here. It should be here tommorrow and the order from SoCal should be here Wednesday. I bought my wife an Eastwood tubing notcher and that arrived the other day so I can get some additional supports fabbed up. I'm headed to North Carolina for a few days, there should be a nice little pile of stuff here when I get back!
Normankt84 Samba Member
Joined: January 22, 2013 Posts: 15 Location: Centeral Indiana
Posted: Sun Jun 02, 2013 7:31 am Post subject: |
If your ever passing through Indiana again make time to stop in Brian's its a great place and great people. I do not shop anywhere else. |
Posted: Mon Jun 03, 2013 7:19 pm Post subject: |
Normankt84 I am supposed to go back to teach another class there this fall and I will definatley stop by Brians! _________________ Veni, vedi, vici...I came, I saw, I conquered |
Posted: Mon Jun 03, 2013 7:32 pm Post subject: |
The 6 volt generator arrived in Vermont today! Can't wait to see it when I get back. I ordered a pair of 10x900 fan belts and read that I may need to buy a different generator pulley to work on the 36HP engine...I still need to round up a 6 volt coil but I may be able to get it fired up this weekend! Driving to Ohio Sunday for classes next week, Bellefontaine and then on to Akron. I'm also scheduled to drive to Ohio in July the weekend this is going on http://www.jimscustomvw.com/18anbugejuca.html _________________ Veni, vedi, vici...I came, I saw, I conquered |
Posted: Fri Jun 07, 2013 4:03 pm Post subject: |
Picked up some floor mats, seat covers and an air freshener today...LOL!
Posted: Fri Jun 07, 2013 4:17 pm Post subject: |
Seriously though, I did get some parts this week. New throttle cable and housing, clutch cable, cable shortening kit and clutch cable tube.
Posted: Fri Jun 07, 2013 4:20 pm Post subject: |
New throw out bearing, 22mm master cylinder with reservoir,axle boots and in the bag there is a pair of HD T-O brg clips, trans mainshaft seal and clutch cable wing nut.
Posted: Fri Jun 07, 2013 4:23 pm Post subject: |
6 volt generator and fan assembly I bought from a member here in the classifieds. Thanks Mike McComb!!
Going to have to do a search and figure out the fan spacer positioning.
Posted: Fri Jun 07, 2013 4:38 pm Post subject: |
While I was on the road I also ordered a pair of 10x900mm fan belts and this afternoon I stopped by NAPA and picked up a 6 Volt coil.
Posted: Sat Jun 08, 2013 8:52 pm Post subject: |
It's ALIVE!! My dad helped me today, we changed the trans input shaft seal and installed the new throw out bearing. Installed a 1964ish 40HP shroud and the generator/fan assembly I had bought on the classifieds here. His 6 volt tractor battery was dead so when we bolted the engine up we didn't wire the generator. We just ran 3 wires to the switch and used a 12 volt battery. It sounds pretty good! If I can figure out how to load a video off PhotoBucket I'll add it to the thread.
Posted: Mon Jun 10, 2013 8:06 pm Post subject: |
A short video of the 36HP after we first got it fired up. I am REALLY excited to get this buggy back on the trails!!
Posted: Sun Jun 16, 2013 6:58 pm Post subject: |
Didn't go back home this week end so I didn't work on the buggy. I went to Butler, Pa for the Bantam Jeep Festival. I did , however, order a set of 22mm Super Beetle front wheel cylinders to use in the rear. _________________ Veni, vedi, vici...I came, I saw, I conquered |
Posted: Wed Jun 19, 2013 4:47 pm Post subject: |
I bought a replacement NOS tranny nose cone here on the Samba, I had tried to heat the old one with torches to free it up and POOF...I freed it up alright...
The Super Beetle 23.8mm wheel cylinders also arrived, hoping these are going to balance out with the 22mm master cylinder I got from SoCal. Planning on running '68 17mm rear cylinders up front. My wife sent me the photo of stuff that came! Hmm....I am going to have to either get a back up light switch or a plug to plug that hole in the nose cone.
Posted: Sat May 17, 2014 12:24 pm Post subject: |
Well life has been happening, 44 weeks on the road last year. I am starting my third week in Seattle. Hoping to fly back east and go to my dads and work on the buggy next Monday, Memorial Day. It will be May 26th, 35 years to the day that I bought it! _________________ Veni, vedi, vici...I came, I saw, I conquered |
DSTMULE Samba Member
Posted: Mon May 19, 2014 6:17 am Post subject: |
Keep us posted, looking forward to seeing how it turns out. |
dustymojave Samba Member
Posted: Mon May 19, 2014 9:09 am Post subject: |
The brake cylinders are NOT swap anywhere pieces!
The spacing from the backing plate to the centerline of the cylinder is different for different applications. Some ARE interchangeable. Some are NOT! There are differences in length too. It would be good to compare these aspects before trying to just bolt them in place. _________________ Richard
SoCalBajas Member
plotch Samba Member
Joined: December 22, 2004 Posts: 537 Location: jeffersonville, vermont
Posted: Mon May 19, 2014 7:15 pm Post subject: |
Cool, would love to see the buggy. Where in vermont are you? |
Posted: Mon May 19, 2014 7:57 pm Post subject: |
When I do get home I live in the Rutland area. I read a bunch of stuff on the wheel cylinders before buying them. I will have to go back and re-research them apparently. I bought the master cylinder before reading up and it may be to big. It's the 22mm version if I remember correctly. _________________ Veni, vedi, vici...I came, I saw, I conquered |
