BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Mon Sep 15, 2014 12:31 pm Post subject: |
60vwnewengland wrote: |
How do I solve this? |
What are the taillights doing and which filament? |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1782 Location: District of Columbia & Cape Cod
Posted: Mon Sep 15, 2014 6:42 pm Post subject: |
2Pack wrote: |
j.pickens wrote: |
Post up your connection details for the relay. |
^^Agreed.
Also, is the relay one that is known to work for buses? Like from WW or something? |
So I have a WW relay, here is a photo.
I had the flasher wires and TS wires connected to the same terminal on the tail lights and they were flashing at the same time.
Moved one wire to the opposite side, and the results were what was posted in my second video. I'm going to reverse the wires and see if that fixes my problem.
After that I'm stumped. I cannot post results until this weekend... Stay tuned for more details! _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Sat Sep 20, 2014 2:32 pm Post subject: |
Got the turn signals working. Needed to run a ground off the top of the tail light housing bolts and ran it to the negative battery bolt. Work like a charm! _________________ 77 Westy - Cape Cod Sage
LLAP |
orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Wed Oct 01, 2014 4:51 pm Post subject: |
some progress while I came down for a weekend to help with the two man projects:
Needed engine install, fill tranny with gear oil, bleed the brakes, insert all windows, and install the rear hatch. Getting it prepped for a long shake down ride to Mass for paint next weekend.
Saturday:
Engine in
Classic Matt Cuddy Fill Up
Windows in for the trip. Then we are taking them back out again.
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Oct 02, 2014 7:59 am Post subject: |
Well rock on my swivel seat brethren! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9787 Location: Exit 7, New Jersey
Posted: Fri Oct 03, 2014 8:44 am Post subject: |
Must see it moving under its own power! Pix, please!!!! _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Mon Oct 06, 2014 5:02 pm Post subject: |
feast your eyes on this beast. |
Stanagon Samba Member
Joined: July 11, 2003 Posts: 4186 Location: Boston, MA
Posted: Mon Oct 06, 2014 6:56 pm Post subject: |
Stanagon wrote: |
Rollin north for Tfest? |
unfortunately no... now the front drivers side brakes are leaking. I gotta take the hub off and see what's happening. Word to the wise, nobody order busdepot wheel cylinders, so I've only had 2 of the four work.
I plan to czech out the front brakes one more time, get it registered and inspected this weekend, do some shake down runs.
Passenger side rgb is leaking too... not sure from where. Definitely not from the normal spot. Looks like it's leaking from behind the spring plate... can that be possible?
LLAP |
WM971252 Samba Member
Joined: September 10, 2004 Posts: 1781 Location: Franklin CT
Posted: Tue Oct 07, 2014 6:41 am Post subject: |
Yes... That circle is a press in plug that covers the inside nut for the stub. Most I have seen have some "goo" on them to help seal them (like a ton of orange permetex. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Tue Oct 07, 2014 9:03 am Post subject: |
unfortunately no... now the front drivers side brakes are leaking. I gotta take the hub off and see what's happening. Word to the wise, nobody order busdepot wheel cylinders, so I've only had 2 of the four work. |
Any brake part I get is torn down, cleaned, inspected, honed and reassembled before it gets near my truck.
This saves a lot of headaches down the road. |
Posted: Sun Oct 12, 2014 2:58 pm Post subject: |
I drove the van today! 6 miles to it's new home! I owe so much thanks to Russ (Rusbus), Lance (2Pack), Nick (Touch Nicks Thing), John (j,pickens), Jack (orangebug60guy), Cuddy, Colby, Aaron, Clay, Manny, and everyone else who I called every weekend for tips and trouble shooting.
Found a garage near my apartment, time to sit and relax for a little. Carb wont idle, and it seems to be running very hot! Here it is in it's new home.
So I need to find the vacuum leak, adjust the carb, maybe even buy a new one, and hit the road. Next weekend is DC inspection, only have to pass safety, which wont be hard.
Thanks to everyone, especially thesamba! You guys are the best![/img] _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Mon Oct 13, 2014 7:15 pm Post subject: |
Cool stuff and love that garage, quick shut the door before someone see's it! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
Posted: Mon Oct 13, 2014 9:14 pm Post subject: |
Not unlike the garage it emerged from nearly a decade ago.
Posted: Fri Jan 02, 2015 10:11 pm Post subject: |
Few photos of my travels in DC, MD, and VA this fall
LLAP |
Posted: Sun Jan 04, 2015 9:15 am Post subject: |
Goofy pose Mr.! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
JohnnyRingo Samba Member
Joined: October 22, 2011 Posts: 414 Location: United States
Posted: Sun Mar 01, 2015 8:02 am Post subject: |
Bought J Pickens other 59 swivel last year............maybe we can unite the twins someday. |
CaLiBus Samba Member
Posted: Sun Mar 01, 2015 8:28 am Post subject: |
Goofy pose Mr.! |
It's called "permanent swivel seat position syndrome" |
Posted: Thu Mar 12, 2015 8:56 am Post subject: |
made a new frame for a Z-Bed for the bus.
Headed to DC this weekend for install. _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2037 Location: M*ssholia
Posted: Thu Mar 12, 2015 11:14 am Post subject: |
Looks good jack. |
