AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 294 Location: Saskatoon, Sk Canada
Posted: Sat May 18, 2013 1:43 pm Post subject: IDing a pre A 2pc case. |
How do I I.D and pre-a 2pc case.I was given one by a friend getting rid of all his 356 stuff and he claimed this case was really early 356.It looks 36hp vw to me but theres some differences in the sump area and uses trapped trough bolts instead of studs.The case also appears to be clearanced and very proffesionally. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
janerick3 Samba Member
Posted: Sat May 18, 2013 5:22 pm Post subject: |
According to Harry Pellow's book, Secrets of the Inner Circle, this case is for an early 1954, Type 546 1500 Normal engine. _________________ Thanks,
Jan K. |
Steve Heinrichs Samba Member
Posted: Sat May 18, 2013 6:01 pm Post subject: |
I will try to figure out the chassis number tomorrow.
Steve Heinrichs |
Posted: Sat May 18, 2013 6:52 pm Post subject: |
32760 went into chassis 60473 which finished production 8 March 1954.
Steve Heinrichs |
roy mawbey Samba Member
Joined: May 21, 2012 Posts: 397 Location: Sussex England
Posted: Sun May 19, 2013 3:43 am Post subject: |
Everett is correct you need the crankcase number. The very early plain bearing engines like the 1100cc and 1300cc had a range of numbers. My brothers 51 1300cc had engine P 20620 and our 1952 1500 cc had P30988.
The very early 1950 1100cc cars had engine numbers between 0101 - 0411 according to the listing I have.
As far as I am aware? the 2 piece crankcase ran up to late 1954.
Roy _________________ Roy
RHD356A super75 106954 |
Braukuche Samba Member
Posted: Sun May 19, 2013 6:04 pm Post subject: Re: IDing a pre A 2pc case. |
AirCooledClassics wrote: |
How do I I.D and pre-a 2pc case.I was given one by a friend getting rid of all his 356 stuff and he claimed this case was really early 356.It looks 36hp vw to me but theres some differences in the sump area and uses trapped trough bolts instead of studs.The case also appears to be clearanced and very proffesionally. |
It will have a "P" before it. Those things are worth some serious money BTW. Nice score. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
fcampbell356 Samba Member
Joined: December 15, 2007 Posts: 217 Location: Pensacola, Florida
Posted: Sun May 19, 2013 6:33 pm Post subject: 2pc case |
You just never know what will turn up. I have a pre-A Porsche look-a-like
engine I got out of a junk yard, that was said to be a 36 HP VW engine. So I bought it and tore it down, (kinda funky carbs -2) to be a VW.
Found a 74mm crank, early 356 rods, alloy cylinders(80mm) & pistons
with 356 heads and the older cast iron rocker assembly.
Here is the question, did someone build this engine with older 356 parts using a VW case. The engine number is 1 315 696 which puts it some where at Dec. 1951 and Oct. 1952. All indications seem to think this might a replacement engine, or rebuild for a early 356.
I intend to rebuild it when I get the time. Would post some pics, but I
to dumb.
Thanks
Frank |
Posted: Sun May 19, 2013 10:30 pm Post subject: Re: 2pc case |
fcampbell356 wrote: |
The engine number is 1 315 696 which puts it some where at Dec. 1951 and Oct. 1952. |
For VWs:
-1-0315696 is June, 1951
1315696 is Feb., 1956
From your text, I'm guessing it's the latter.
Post a pic if you want further verification...
Sounds neat. _________________ How to Post Photos
Posted: Mon May 20, 2013 10:15 am Post subject: ID |
Yes, rechecked engine number and that is where it fits. Starts Dec. 1955
thru Dec. 1956. Hope that some pics will show up.
Frank |
Unobtanium-inc Samba Member
Joined: April 07, 2007 Posts: 345 Location: Upstate NY
Posted: Tue May 21, 2013 4:36 am Post subject: |
Here are some pics of Frank's motor
Posted: Tue May 21, 2013 5:51 am Post subject: Id Engine |
Thanks to Adam Wright for posting pics. Gotta learn how to do it.
Frank |
savaden Samba Member
Joined: May 03, 2012 Posts: 83 Location: North Carolina
Posted: Tue May 21, 2013 2:31 pm Post subject: |
That looks like a lot of potential woof for that scrawny little bottom end.
SV |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Tue May 21, 2013 3:39 pm Post subject: |
OT Alert!
Did the early 2-piece engine have any particular weaknesses? The only reference I've ever seen to them was in a book written by Duane Spencer. He opined that they handle much HP, but he didn't reference any specific problems.
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Tortie Samba Member
Posted: Tue May 21, 2013 9:40 pm Post subject: |
Hard to tell from pictures, but those heads look like they've had "work" done on them. Intake ports look a little funny. Most harry homeowner type intake mods are not very good,...done by seat of pants thinking and often result in diminised velocity and efficiency. The rods look like the later (better) ones. Definitely a mixed bag of things. _________________ Steve Harrison |
Posted: Wed May 22, 2013 8:02 am Post subject: |
Steve,
Yes, the heads have been worked on. One head is a Normal 1500 and the other is a Super 1500S. They will get a professional match porting to the
intake manifolds later.
Frank |
Tortie Samba Member
Posted: Wed May 22, 2013 9:46 am Post subject: |
Normal and Super heads are all the same from the factory. More individual owners took it upon themselves to alter the heads on their Super so more of the heads on Supers are modified. So when people find a Super motor and look at the heads, the instinct is to believe the heads are factory different. They're not. Factory only had one type of heads for normals and supers.
Supers were achieved with a cam change (and in some cases, different lifters), increased compression, and bigger carbs, That's it.
Port matching to the manifolds, (and gaskets) is a good practice but I'd stay away from enlarging the ports further down in their travel toward the valves. Increased size there decreases velocity in most cases. You've made a great find there with those parts and are well on your way to getting an engine together. You didn't happen to get the rear engine tin did you? The one without carb heat holes? That's the hardest piece of tin to find,...unless you count the "lap seam" fan housing. Forget that,...it's unobtanium. Speaking of Adam,...if you want to go with the Super carb seat up,..the 40MM solex and special steel manifolds,..I have it on good authority that he's got a set, and they may be for sale. _________________ Steve Harrison |
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
Tortie Samba Member
Posted: Wed May 22, 2013 10:44 am Post subject: |
Ah yes,..the old roller crank. Forgot that one!
Guess because they're all just about out of service now. _________________ Steve Harrison |
