JRKman Samba Member
Joined: June 21, 2011 Posts: 291 Location: Portland, OR
Posted: Thu Aug 22, 2013 10:51 pm Post subject: |
I'll just wait until I gather everything to take to my buddies house. He has all the proper tools to do it right. _________________ 1969 Type I
House paint red
1835cc single port:
Scat C25, ICT's, SVDA |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Wed Oct 16, 2013 6:15 pm Post subject: |
Any updates? _________________ 1965 Beetle sedan
Click to view image |
AggieZig Samba Member
Joined: March 10, 2013 Posts: 188 Location: Los Angeles, CA
Brian Anthony Samba Member
Joined: October 02, 2006 Posts: 215 Location: Longview TX
Posted: Wed Jul 09, 2014 3:56 pm Post subject: |
You can always make your own intake manifolds. These manifolds have a 35mm ID to match the modified 35mm ID intake port in the head.
_________________ 1965 Double Cab
1967 Bug, Sedan
1967 Bug, Convertible
I’m not old, but I once knew a man who was alive during the Civil War, and he once knew Revolutionary War veterans. |
JRKman Samba Member
Posted: Thu Sep 18, 2014 9:09 am Post subject: |
Hey everyone,
I have some updates. After a long waiting period I'm finally building this thing. Its in longblock form currently. Should be done and in within a week or two.
Here are the parts going into this thing. There are probably more I'm forgetting. Feel free to ask.
- Stock crank
- Stock flywheel
- Stock clutch
- HD pressure plate
- Scat C25 cam
- Scat lifters
- CB oil pump/filter cover
- Rotating assembly dynamically balanced
- 92mm thick walled cylinders/pistons by AA
- Rebushed OEM rods
- Single port heads ported/polished
- Windage pushrod tubes
- Weber ICT's (Jetted 60 idles??, 140 mains??)
- Port matched CB single port manifolds
- HD single springs
- Chromoly keepers/retainers
- Solid shaft rocker shafts
- Stock rockers
- Chromoly Pushrods
The deck height ended up being about -0.005 to -0.010. I'm going to go pick up some .060 cylinder shims today to fix this. Heads are cc'd to about 50-55cc's So I should get a compression ratio between 8.1:1 and 8.7:1
-Josh _________________ 1969 Type I
House paint red
1835cc single port:
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Thu Sep 18, 2014 9:20 am Post subject: |
0,040 shims would be plenty! and better. |
JRKman Samba Member
Posted: Thu Sep 18, 2014 9:47 am Post subject: |
Wouldnt that give me a deck hight of 0.030 possibly? Which would be 9.3:1 for the compression for the C25. Wouldnt I run into valve clearance issues here? _________________ 1969 Type I
House paint red
1835cc single port:
JRKman Samba Member
Posted: Sat Sep 27, 2014 9:00 am Post subject: |
Here it is all built up.
House paint red
1835cc single port:
Posted: Sat Sep 27, 2014 10:25 am Post subject: |
Sweet. Let us know how it runs. Pics / video would be cool too _________________ 1965 Beetle sedan
JRKman Samba Member
Posted: Mon Sep 29, 2014 10:38 am Post subject: |
I'll get a video of it for sure.
How does the jetting sound for the ICT's?
60 Idle, 140 Mains. Should be able to start it up for break in on these jets I'm thinking. _________________ 1969 Type I
House paint red
1835cc single port:
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1065 Location: Gilbert,Arizona
Posted: Mon Sep 29, 2014 10:45 pm Post subject: |
Your engine looks great,and just like my 1955cc singleport. Your 60 idles and 140 jets sound perfect. I think you will be close with that setup. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
JRKman Samba Member
Posted: Wed Oct 01, 2014 8:49 am Post subject: |
Thanks! How happy are you with your 1955cc single port? Hows it run? _________________ 1969 Type I
House paint red
1835cc single port:
GDOG57 Samba Member
Posted: Wed Oct 01, 2014 10:31 pm Post subject: |
Runs great. Just took it on a 400 mile trip to Jerome for the jamboree. Pulled the hills better than i hoped. Got excellent gas mileage. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
JRKman Samba Member
Posted: Thu Oct 02, 2014 8:31 pm Post subject: |
So I went to set the endplay today. Just pushing/pulling the flywheel I get .010" with no shims. If I slightly rotate while i push/pull I get between .035/.045
What measurement am I supposed to go by? .010" seems a little tight with no shims... _________________ 1969 Type I
House paint red
1835cc single port:
JRKman Samba Member
Posted: Tue Oct 14, 2014 4:17 pm Post subject: |
Getting close
House paint red
1835cc single port:
JRKman Samba Member
Posted: Sun Oct 19, 2014 8:12 pm Post subject: |
Engines installed and broken in. Can't get it to idle right now with the ict's (60/140 jets). Gonna have to work on that. The idle speed screws want to be over 3 turns out. Thoughts? _________________ 1969 Type I
House paint red
1835cc single port:
JRKman Samba Member
Posted: Mon Oct 20, 2014 8:19 pm Post subject: |
Any ideas? _________________ 1969 Type I
House paint red
1835cc single port:
1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Thu Mar 17, 2016 5:08 am Post subject: Re: 1835 Single port build! |
my slow progress
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
Posted: Fri Mar 18, 2016 4:40 pm Post subject: Re: 1835 Single port build! |
I see you switched carbs to Kadrons. Crank trigger + 019? _________________ 1965 Beetle sedan
Zundfolge1432 Samba Member
Posted: Fri Mar 18, 2016 5:00 pm Post subject: Re: 1835 Single port build! |
JRKman wrote: |
Anyone ever built a 1915 with ported single port heads, stock 8 doweled crank, 34 pict with machined venturi, w100/w110 cam, standard 1 3/8 header with hideaway, and an 034 distributor for a daily street driver?
Just curious since I have all the parts to throw one together but just don't see a lot on the forum on this type of combination.
What do you guys think?
-Josh
Edit:
running ICT's
92mm thick walls |
I did build this engine for a 71 bus a few years back and to make it worse I used a stock bus exhaust. As a few have said it runs out of steam early but it pulled hard off the line. I used a stock cam and dual relief Mexican universal case, if you need low end torque just to putt around its interesting and cheap to build |
