SCRAF Samba Member
Posted: Mon Aug 26, 2013 1:54 pm Post subject: |
Took the body off again and adjusted the new nap hat. Put the body back on, bolted up the pans and tacked in the nap hat. Gave the pedal cluster some POR15.
Welding in the pans next. |
SCRAF Samba Member
Posted: Thu Apr 17, 2014 10:00 am Post subject: |
UK weather, holidays and loss of motivation behind me I continue with this project.
A nice easy weekend and the frame-head floor is tacked in place.
Which meant I could start welding in the pans:
If I can get this side finished and the other side welded in by the end of this weekend I will be happy. Aside from the mechanicals and a coat of paint that will be the chassis sorted.
Looking pretty good from underneath:
More as a motivational exercise than anything else I got some of the Marina blue paint out:
I like! |
TryToBeOriginal Samba Member
Joined: July 23, 2012 Posts: 266 Location: Georgetown, Texas
Posted: Thu Apr 17, 2014 1:06 pm Post subject: |
Glad to see you started back up watching you was my motivation for working on mine. Means ill have to start up again this weekend.
Thanks a lot
looking good keep up the good work. |
SCRAF Samba Member
Posted: Thu Apr 17, 2014 11:54 pm Post subject: |
I wont lie - I have been worried about getting back into it and how long this is going to take me. I have set a target of getting it painted by the end of the summer which I think is realistic.
After the pans are fixed I need to tackle the rear body mounts. I have no idea how I am going to sort them out yet! |
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Fri Apr 18, 2014 2:07 am Post subject: |
Hey,
don´t get lost and please keep up the excellent work, the result will be breathtaking! |
Posted: Fri Apr 18, 2014 11:52 am Post subject: |
SCRAF wrote: |
I asked a couple people about the same one one way I heard was to undo all the spot welds around the extra plate remove it then mark your cut. Then attach the body and remove the extra plate from the new one and bolt it on through the part on the pan. Then mark every thing up so you can get the alignment right and tac it into place with the body attached to the pan where you want it.
sorry that probably doesnt make much sense. Easier shown than said. |
SCRAF Samba Member
Posted: Mon Apr 21, 2014 1:25 pm Post subject: |
The pans are welded in, a little extra work will be required on the chassis before painting. Just the bits I couldn't get to while the body is still on.
Thanks for the info on the wheel arches Original. I will take a look around and see what others have done. Hope to make a decent start next weekend. |
beetlenut Samba Member
Posted: Tue Apr 22, 2014 9:15 am Post subject: |
Looks like you replaced all the same areas that I ended up replacing on my 74 Super. And you're right, sometimes motivation is an issue, and you just have to step away for a while and regroup. Sometimes just looking at the pictures of all the work you've already got behind you is all it takes. Being way past the point of no return, it get easier as you get closer since all the work at the end really begins to show the efforts of all the work. New paint can do a lot for that last final push of assembly. Keep up the good work!! _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
SCRAF Samba Member
Posted: Mon Apr 28, 2014 5:43 am Post subject: |
Thanks for the comments guys - its good to hear from others going through the same ordeal!
The third productive weekend in a row sees some more progress, RHS rear wheel well is repaired. A scary job because of how much metal had to be removed. Still need to fix the inside but the outer is good and solid. Also need to get the body mount on and fix the fender nuts.
Pretty happy with how it turned out. I may have developed a blue paint problem!
Before:
Not much under here but filler and rust:
Badly fitting repair panel in place:
Painted Blue for inspiration!
Whether any of this will fit when I drop the body again remains to be seen...
Inside still needs some patches and stitching up:
SCRAF Samba Member
Posted: Fri May 02, 2014 6:10 am Post subject: |
Just got some replacement engine tray sides from Hookys panel shop. Top quality and highly recommended.
http://www.hookyspanelshop.com/ |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
SCRAF Samba Member
Posted: Sat May 03, 2014 1:37 pm Post subject: |
Here are those engine sides I mentioned:
So crisp, neat and tidy compared to all the Klokkerholm I have been using!
Anyway, another decent day on the rear o/s quarter. Believe it or not my welding is improving. Butt welding in some patches for the fender nuts. 2 done and the 3rd one is made ready to weld in tomorrow.
Fitting the wing to make sure the new nuts are in the right position:
Almost looks like a bloody Beetle!
Cutting some patches:
2 down and one to go:
I assume these fender nuts rusted out a long time ago, any advice on what I can do to the sheet metal screw holes that the PO made to hold the wings on would be appreciated. I don't really relish the thought of another 5/6 tiny patches on each wheel arch... |
Posted: Sat May 03, 2014 5:50 pm Post subject: |
If your welding is really improving, time to just weld those tiny holes shut. Another technique to master. Lower heat and a light touch, and you should be able to close them up. _________________ scrapyards are for quitters
Wetstuff wrote: |
SCRAF Samba Member
Posted: Sat May 03, 2014 10:44 pm Post subject: |
Thanks beetlenut, I guess I knew the answer already. I will do a few more of these patches before I give it a go. Your build thread is a real inspiration btw. |
Posted: Sun May 04, 2014 5:17 am Post subject: |
SCRAF wrote: |
Yea, thanks. Been stuck in a bit of a rut myself after painting the body last Fall. Almost done wet sanding it. I've found out that amateur painting is like amateur welding, but instead of lots of grinding, it's lots of wet sanding! _________________ scrapyards are for quitters
Wetstuff wrote: |
SCRAF Samba Member
Posted: Sun May 04, 2014 5:35 am Post subject: |
Had a bit of a go with mixed results... and then Bees. Lots of Bees. I am 'swarmed' off until they settle down ^^ |
SCRAF Samba Member
Posted: Tue May 06, 2014 11:28 am Post subject: |
3 more fender nuts replaced:
Then my welder started playing up... hope it decides to play ball this weekend. If not I will probably do the front beam and ponder buying something a little more heavy duty. |
SCRAF Samba Member
Posted: Thu May 08, 2014 12:15 pm Post subject: |
A while back I made a little bracket for the washer button:
SCRAF wrote: |
Modified the washer switch with the button for the electric pump so that I don't have to have another hole in the dash:
And decided to polish this up a little.
Prototype:
Version 2:
Fitted:
Just need to shorten the brass push-rod a little and done. 3D printing is pretty handy. |
SCRAF Samba Member
Posted: Fri May 09, 2014 10:02 am Post subject: |
Can anyone tell me if the part outlined in green is just a repair panel? Can I just weld my new body mount [in red] directly in without this backing piece?
Thanks in advance. |
Dodgy Samba Member
Joined: January 30, 2006 Posts: 517 Location: Leicester, UK
