airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Aug 05, 2015 7:18 am Post subject: |
c705ncp wrote: |
I know this an old post but does anyone know where I can advance and retard springs for Bosch distributors that fit type 1 VW Beetle.
I've got a couple of part numbers 059 998 211 or 1237 010 007.One is VW and the other is Bosch. I live the other side of the pond in UK but I'm quite happy to get in touch with supplier in USA
Robert |
I'm not aware of anyone selling the correct springs. Do you have a good swap meet you can visit to pick up an old dirty distributor core? With a good cleaning, those springs might be as good as you can get. There's no telling how the weights of an aftermarket spring might compare to the Bosch original. Glenn or tasb will know for certain if you could buy a spring, but I always prefer dirty parts made in West Germany to anything made new.
www.airschooled.com |
Tcash Samba Member
Posted: Wed Aug 05, 2015 8:23 am Post subject: |
c705ncp wrote: |
Robert |
The 059 998 211 comes up as a distributor shim kit, with no springs.
http://www.texasaircooled.com/catalog/BOSCH-Distri...8-211.html
Maybe post the vw and bosch numbers off the distributor?
I could only find pictures of a return spring.
NOS 021 256 255 Return Springs 1
Good Luck
Tcash |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Wed Aug 05, 2015 8:49 am Post subject: |
Tcash wrote: |
c705ncp wrote: |
Robert |
Good Luck
Tcash |
Those are NOT distributor return springs... they are HUGE. _________________ Glenn
Member #1009
#BlueSquare |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Aug 05, 2015 9:02 am Post subject: |
Those look like #55 here: (73+ throttle return on PDSIT)
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Aug 05, 2015 1:04 pm Post subject: |
Hey man! Glad your thread popped back up, I saw it a while back and forgot about it.. I's just gonna say,
asiab wrote: |
Somehow it has to be pressed out. I tried a 10-ton shop press and couldn't get it aligned enough. Eventually I had my dad hit it with a few hammers on a flat-nosed chisel. I held it steady and kept the shaft from turning from the inside. This did the trick, but I forgot to take a picture. |
you were so close... soooo close.. Next time you do one, grab an arbor plate off the press and use it to rest the drive tang on, to keep the shaft from spinning when you knock the pin loose.
also.. you can use a bench vise to press the pin back in place. Once the pin is seated as far as you can go with the vise, put a BB or ball bearing between the vise jaw and the pin to push it in all the way. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Tcash Samba Member
Posted: Wed Aug 05, 2015 1:29 pm Post subject: |
Glenn wrote: |
Tcash wrote: |
c705ncp wrote: |
Robert |
Good Luck
Tcash |
Those are NOT distributor return springs... they are HUGE. |
That's funny. I don't know what the heck that spring fits.
Thanks Glen
Tcash |
Posted: Wed Aug 26, 2015 9:06 pm Post subject: |
scrivyscriv wrote: |
You ever get your mystery retard figured out? |
Yeah, a few pages back. The distributor drive gear play was obtuse, AND I didn't have the spring installed correctly. I smashed the spring down so hard by hand that it got caught compressed in the drive gear. The distributor is rocking in Hambone's second pastel white '69 Westy at the moment. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Wed Aug 26, 2015 9:54 pm Post subject: |
I missed seeing where you had found the issue. I'm putting together a Bosch version of the 205Q for my own bus - did the vac can have anything to do with your timing problem or was it all mechanically related? _________________ Robert in Memphis
Posted: Wed Aug 26, 2015 9:55 pm Post subject: |
I missed seeing where you had found the issue. I'm putting together a Bosch version of the 205Q for my own bus - did the vac can have anything to do with your timing problem or was it all mechanically related? |
My issue was purely mechanical, though my vacuum can pictured ruptured in about a week of hard driving. The used one I put on is still going strong.
And you didn't miss it; I can't find it either! During this thread I got tired of a lot of BS info on this site and I moved my technical questions over to the IAC forums.
http://www.itinerant-air-cooled.com/viewtopic.php?f=46&t=11791
(Top of page 2)
Posted: Wed Aug 26, 2015 10:12 pm Post subject: |
No doubt about that bro!
Did you ever replace the dist drive gear? I've been unhappily watching my timing scatter with my 205T SVA - never thought about that spring being part of it like Amskeptic mentioned over there. Good info. _________________ Robert in Memphis
Posted: Wed Aug 26, 2015 11:49 pm Post subject: |
Did you ever replace the dist drive gear? I've been unhappily watching my timing scatter with my 205T SVA - never thought about that spring being part of it like Amskeptic mentioned over there. Good info. |
As I built up my current engine mocked up the assembly over and over, it became painfully obvious how important drive pinion to gear mesh is. Unfortunately, it can only be set perfect with the case split. Now, you could fully seat the drive pinion, measure it with a depth micrometer, then measure your distributor bottom-to-clamp distance. I err on the small end of the tolerance, because the magnesium case buttress that holds the pinion will wear over time. The drive pinion itself is made of significantly harder metal, so it won't wear fast enough for anybody on planet earth to work about.
The old engine got wonky on me around the time that I fixed this issue, and I realized on teardown that I had been driving for months with a dropped intake valve seat. (Note: throw those damn aftermarket cylinder tins away.) So I never got a chance to run this distributor on a perfect dual port after the first month I drove with it before the problem showed up. But damn, it drives sooooo smooth!
Does your timing scatter at idle, speed, or both? Vertical play in the distributor shaft combined with a loose drive pinion tolerance can cause a small version of what I found on the old engine. A radially worn bushing or two in the distributor shaft will absolutely cause scatter as well. If the radial play is perceptible, I won't use the core for a rebuild. Cores are cheap right now, so I have a box of 205Ts for the future when they're scarce…
The funny thing is, these are all problems that electronic points replacement zealots tote around as being fixable by the modules. Nope, just bad advertisement lies; fix 'yer cars.
SGKent Samba Member
Posted: Thu Aug 27, 2015 9:56 am Post subject: |
timing scatter is often
1. a bad gun or inductive pickup. Sometimes reversing the direction of the pickup helps.
2. wobble in the shaft - usually shows up as fluctuations in dwell too
3. bad or worn points. Sometimes the pivot can be sticky and the spring not strong enough to bring them back so they float.
4. If electronic ignition the magnets or optical wheel can be loose.
On a VW it can also be a loose, damaged, or missing spring between the drive gear and distributor as you found out. Basically anything that allows the points or electronic ignition to fire at slightly different times - or delays in the timing light due to electronic failure there. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
GusC2it Samba Member
Joined: June 23, 2005 Posts: 1376 Location: Orlando, Florida, USA
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Thu Nov 12, 2015 10:16 am Post subject: |
GusC2it wrote: |
What kind of tool do you guys like for pushing the split snap ring onto the shaft? |
Find an old writing pen with a metal body. Unscrew it (remove the inside), and use half of the body as your tool. The diameter of the body should be just slightly larger than that of the snap ring. Use a dab of grease to hold the snap ring in place on the open end of your tool, then tap it on to the shaft with a small hammer.
I used this method and it worked perfectly. _________________ Mike B.
wcfvw69 Samba Purist
Posted: Wed Feb 17, 2016 9:17 am Post subject: Re: Refreshing a DVDA or SVDA distributor - my photographic tale |
Robbie stopped by my place a few weeks ago when he picked up the bug for his buddy. He saw this NOS Bosch 853 vacuum can and suggested I post some pictures of it since it's missing the dimple in it that was so heavily talked about in this thread.
It's marked 853 on the arm.
This distributor which is very close the 205Q in curve had this non-dimpled, 853 can on it. I bought it to rebuilt it and try in my bus. I'm currently running a bug DVDA 043C in it which works nice. I'm just curious to know the difference in drivability between these two distributors.
It appears that the can pull range is adjustable on it? Anyone know for sure? _________________ Contact me at [email protected]
The Samba member since 2004.
Tcash Samba Member
Posted: Wed Feb 17, 2016 9:46 am Post subject: Re: Refreshing a DVDA or SVDA distributor - my photographic tale |
Can you get a good pic of the other side of the adjustment screw. Inside the dist. where it would contact the actuating arm?
Thanks
Tcash
Or better yet, pull the vacuum can and takes some pix. |
Posted: Wed Feb 17, 2016 9:23 pm Post subject: Re: Refreshing a DVDA or SVDA distributor - my photographic tale |
Tcash wrote: |
Thanks
Tcash
Here's the further pictures. I'm not sure how much that adjustment would effect anything? It looks like the pull arm hits the can and the peg before the adjustment would have any effect? Maybe what I'm viewing as an adjustment is how they assembled it? _________________ Contact me at [email protected]
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Thu Feb 18, 2016 12:53 am Post subject: Re: Refreshing a DVDA or SVDA distributor - my photographic tale |
Maybe thru some error the can brackets were originally made without the stop, and they did that instead of chucking the lot? _________________ '67 bug: seized by the authorities
