Bad valve train noise, suddenly gone...what?
DirtyBlueVan
DirtyBlueVan is offline
PostPosted: Sat Jun 08, 2013 11:49 am    Post subject: Bad valve train noise, suddenly gone...what? Reply with quote
I changed the exhaust to fix a rich running problem, started it to check for leaks and it sounded fine. Started it the next day and it had the most horrendous sound coming from the valvetrain. The loudest tick I have ever heard in a vehicle. Drove it 20 min, still making crazy noise. I then parked it for 2 days, and then BAM gone, no more noise when I started it up to move it.
What could that of been? I'm not complaining that it went away.
1985 Crusty blue 1.9l 4 speed
Danwvw
Danwvw is offline
PostPosted: Sat Jun 08, 2013 11:57 am    Post subject: Reply with quote
Could have been a stuck valve or a loose valve seat! Is it air or water cooled?
1971 VW Sundial Camper with a Type 1 1800cc engine built in 2013.
Type 1 1800cc with Web-Cam 118 and L3 heads built in 2015 and Stock-ish 1679cc engine 2016.
djkeev
djkeev is offline
PostPosted: Sat Jun 08, 2013 12:33 pm    Post subject: Reply with quote
A collapsed hydraulic lifter immediately springs to mind.
If the engine stopped with lifter X holding open a valve and it is weak or dirty it bled down. The next time you parked it lifter X was at rest with a closed valve and had a chance to relax and regain its "shape". Hence noise is gone. It WILL happen again given time.
Make sure you are running detergent oil that will clean up deposits.
Try running some marvel mystery oil in your oil for a few thousand miles to clean out deposits.
Dave
86 Vanagon Westy "Weekender" 2.1 Auto
Karmann Ghia
nemobuscaptain
nemobuscaptain is offline
PostPosted: Sat Jun 08, 2013 2:50 pm    Post subject: Reply with quote
Detergent oil?
I think the last time I saw non-detergent oil was during the Carter years.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
http://www.fullmoonbusclub.com/plugins/forum/forum.php
djkeev
djkeev is offline
PostPosted: Sat Jun 08, 2013 3:46 pm    Post subject: Reply with quote
nemobuscaptain wrote:
Detergent oil?
Yeah......... I was well into adulthood during those years! I clearly remember non detergent oils and the sludge they would leave behind.
I just purchased some 30w Non Detergent..... Had to order it special! Was for a pressure washer pump.
Let me revise that to use a QUALITY NAME BRAND OIL. These most often are more reliable for their additive packages.
Dave
Karmann Ghia
DirtyBlueVan
PostPosted: Sat Jun 08, 2013 4:10 pm    Post subject: Reply with quote
Dave
It is already back to ticking, after I moved it again to give it a wash. Not nearly as bad though....How horrible is it to ignore it for 100-200 miles? I figure if it doesn't go away again it's about to bite it (258k stock motor)
djkeev
djkeev is offline
PostPosted: Sat Jun 08, 2013 4:35 pm    Post subject: Reply with quote
Many many MANY old Chevys with 283's 3o2's 307's 327's 350's etc ran for decades with stuck lifters!
As long as the valves are opening and closing you should be fine. You do have a physical clearance on the tappet where none was designed for..... Damage can result.
I always found stuck lifters to be annoying! I eventually replaced them on my 1968 307 Chevelle back in the early 70's just to get rid of the ticking!
Dave
Karmann Ghia
vw54john
vw54john is offline
PostPosted: Sat Jun 08, 2013 11:06 pm    Post subject: Reply with quote
A common issue with these engines. Mine will do it from time to time also. Mine usually goes away within 10-15 min. Have you tried adjusting your valves? Even though you have hydraulic lifters, the valves ARE adjustable. Instructions and clearances are in the Bentley manual.
Regards, John
'54 Strato Silver Oval
zeohsix
zeohsix is offline
PostPosted: Sun Jun 09, 2013 12:07 am    Post subject: Reply with quote
Dave
My Camaro had hellacious valve train noise with its 302 motor but I don't think it was because of collapsed lifters it had SOLID lifters for high RPM the better to win TransAm championships with. Same can be said for my wife's 70 LT-1 Vette.
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Jun 09, 2013 4:30 am    Post subject: Reply with quote
That clatter will return.
This is a good time to run some MMO through.
Change the oil too.
This is likely a lifter as above
Search on MMO to find out more......
1990 Multivan EJ 22 running well...
