alijonny Samba Member
Joined: November 01, 2007 Posts: 328 Location: Des Plaines, IL
Posted: Sat Jun 08, 2013 2:52 pm Post subject: My Syncro was hit while parked, UPDATE 4/1/14 |
So today around noon, some lady in a Chrysler Town and Country decided to do a u-turn in my shop's parking lot. She apparently didn't see my Syncro parked among the other cars and backed into it. I did not see the crash, but heard the thud. She almost drove off, but I was looking to see what she hit, then noticed my rippled rear bumper. SHOOT. She bent the rear bumper on the right and pushed the bumper bracket upwards. Both plastic ends are cracked and the strip is waved.
She then backed up and told me "I only bumped it", I said "You hit my parked van!" So I called the police and made a report, got her insurance info, the officer made it and the girl left.
Come 1:30ish, I get in my van to go get lunch, and press in the clutch and fire it up. All good. I go to put it in reverse, NOTHING. There are no gears, it seems stuck in 4th, or half way because if I pull the shifter back it will grind, otherwise it acts as if it's in neutral.
Now, I know I put the van in 4th after I parked it this morning at the shop, blame habit from driving my F-150 and shoving it into reverse when I park. I didn't think about it and threw the van into 4th, which my brain thought was reverse ( I didn't have coffee yet).
I drove the van about 1000 miles since I bought it with no problem. It drove fine yesterday, it drove fine this morning, but after the "bump" it will not shift right. I had it towed from my parking lot to my shop bay. I was planning to drivie it home tonight, but now I need to wait for a ride.
I checked the linkage, and nothing is bent, everything seems proper. What could this "bump" have caused? I am in a very depressed mood now. I have some money sunk into this van so far and now it's stuck. HELP!
Crankey Samba Member
Posted: Sat Jun 08, 2013 3:28 pm Post subject: |
sounds like something is wedged in the gearbox due to the impact. I'm no expert and I don't have a syncro but she is clearly 100% at fault imho.
if you can't drive in public without 'bumping' other peoples property get off the road.
good luck. hope you have a good shop in your area. and a lawyer to help if needed. |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Jun 08, 2013 3:34 pm Post subject: |
damn, sorry to hear about the problems....
How about some more details though.
Is it currently stuck in 4th, sounds like you say it might be in neutral, or maybe neutral and 4th are all that's available?
Will it shift into any gear at all with the engine running?
When you shut the engine off, does it shift into any gear at all? _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Sat Jun 08, 2013 3:35 pm Post subject: |
The good news is that it wasn't your fault and she has insurance. You may be without your van for a time, but if it's internal to the transaxle, you'll get yourself a rebuild for free. _________________ '90 Syncro Westy w/GW2.5L |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Jun 08, 2013 4:23 pm Post subject: |
Sounds like she got unlucky and cracked the 3/4 gear slider and her insurance co will be writing AATransaxle a $4500 check for a rebuild. I'd guess the impact pulled the transmission slightly out of 4th gear then the syncros drivetrain ran out of slack after a slight roll forward and the force of 9000lbs of combined vehicles crushed it. Pretty expensive 'bump' when the ins co also pays for a bumper n brackets too. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
r39o Samba Polizei
Posted: Sat Jun 08, 2013 5:06 pm Post subject: |
IdahoDoug wrote: |
Sounds like she got unlucky and cracked the 3/4 gear slider and her insurance co will be writing AATransaxle a $4500 check for a rebuild. I'd guess the impact pulled the transmission slightly out of 4th gear then the syncros drivetrain ran out of slack after a slight roll forward and the force of 9000lbs of combined vehicles crushed it. Pretty expensive 'bump' when the ins co also pays for a bumper n brackets too. |
Agree.... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Sat Jun 08, 2013 5:37 pm Post subject: |
Well, I can get it into fourth. It will bog down and die, of course. I can get it out of fourth and it just kinda whirs. Pull it back ever so slightly, and it grinds. So, it's in neutral and rolls, but it is not going into neutral. There is no shift pattern at all. Engine off is basically the same. I don't want to try and force the shifter at all. I put some force to see if it would break loose, but I could clearly see the shifter bending.
Funny thing is that I JUST called AA last night about third gear and talked for a bit to Daryl about pricing a rebuild. I'm just afraid the insurance co will play games with me since I own an auto repair shop. I will not allow anyone else to touch it besides someone specifically repairing these types of transaxles.
And down time... it's been my DD since I plated it. |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sat Jun 08, 2013 5:52 pm Post subject: |
That sucks. Sorry to hear about your Syncro. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
danfromsyr Samba Member
Posted: Sat Jun 08, 2013 6:07 pm Post subject: |
you should be able to specify the repair shop and if you can't then find a Trans shop that will pull it send it to an "Vanagon Syncro Transmission Specialist" and re install it.
her insurance &/or yours should cover a rental for your loss of daily transportation.
leaving a transmission in gear does put it at risk of this type of physical gear damage from impact.. especially if it was in 4th gear. that's alot of leverage that the impact has against the small gears (high ratio)
would have been better in 1st or Rev.. but that's not any guarantee either.
it essentially tried to turn the motor from the force of a dodge caravan in in 4th gear with the leverage of the tires/final drive.. if someone was good with compound math would be quite an impressive amount of force against the gears in a direction they're not designed to handle it.. if the force can't turn the gear it pushes out on it sideways.. and well the weakest link will break. _________________
Abscate wrote: |
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Sat Jun 08, 2013 6:31 pm Post subject: |
Don't try to drive and make the core not rebuildable.
Sucks but lucky.
Jeff _________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
Posted: Sat Jun 08, 2013 6:41 pm Post subject: |
No insurance can 'give you crap' cause you own a shop! Did they give you discounted premiums because you own a shop so later they could have the expectation you'd repair any mechanical claims at a discount to them? No. Its no different than if you had a Porsche trans cracked on a curb impact due to being hit. They dont get to insist it be repaired at a Sears Auto Center because its cheaper than the Porsche dealer. Your car is relatively rare and that trans requires special tools to repair that even VW dealers no longer have. The trans should go to the shop that will succesfully repair it, not to one that has never touched one. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
r39o Samba Polizei
Posted: Sat Jun 08, 2013 7:50 pm Post subject: |
Adjusters are aware that there can be drive train issues from parked collisions as well as moving ones.
Get your comps going lest they attempt to total it.
Get all receipts together....you rebuilt a lot already, right?
They WILL lowball you.
To them it is NOT a specialty vehicle.
Be nice, but stand your ground.
Don't let them just process you.
DO NOT SIGN ANYTHING RIGHT AWAY.
Review it ALL.
Be ready for a long ride.
This WILL be a pita.
Good luck...... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Jon_slider Samba Member
Posted: Sat Jun 08, 2013 10:15 pm Post subject: |
really sorry to hear about your down time, glad its got insurance coverage from the other paty
I dont park in gear for the reason you are experiencing
call Daryl back, describe your symptoms, and he will probably tell you what happened, and to send him the tranny
Insurance adjusters are paid to reduce their company losses, if possible get a lawyer instead of dealing directly with the adjuster, who does this every day, and will run circles around you.
Only problem, with no personal injury, a lawyer wont see any money in it for himself, there is no 33% take for him on mechanical damage, so expect to pay him by the hour. Though you may recover his cost on your claim.
Good luck, and look forward to your refreshed rebuilt tranny
The down time may suck, and the grief, but you just got handed a free rebuild, and a new bumper without needing chiropractic.. Consider the GoWesty Steel bumpers with a tow hitch, and stick a ball on it so the next fool bumping you eats it worse than you. And stop parking in gear, any gear. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Syncromikey Samba Member
Joined: September 19, 2012 Posts: 463 Location: Calgary, Alberta, Canada
Posted: Sun Jun 09, 2013 5:07 am Post subject: |
X2 ... sorry about the bad luck. That really sucks! Insurance should definitely cover it and I would INSIST tha Daryl at AAtransaxle do the work for you. He's the only one, many on here would agree, that I personally would trust to work on my Transaxle. When I had mine done I loaded it up in my car and drove 1300km to drop it off.
Best of luck getting it all sorted.
Mike _________________ Love my Westy ...
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=528954 |
SyncroGhia Samba Member
Joined: August 21, 2009 Posts: 2458 Location: Highnam, UK
Posted: Sun Jun 09, 2013 1:24 pm Post subject: |
If the van was in gear and then was hit, the impact has probably sheared the teeth off 4th gear and you're into a rebuild.
I've only just seen this but if I had seen it before, I would have said do not tow it as you'll do more damage.
I have seen this once before and it just takes all of teeth off and you have to replace both the shift and fixed gear along with anything else that has been damaged as a result.
MG _________________ T3 Syncro 16 S6 Westfalia Limey SOLD
T3 Syncro 6x6 SOLD
T3 RS6 Bluestar
T3 Tristar Syncro 16 SOLD
T3 Tristar Syncro RHD SOLD |
Posted: Sun Jun 09, 2013 3:30 pm Post subject: |
Since you mentioned AA, does anyone know if Daryl is personally rebuilding the transaxles or is his assistant(s) doing some of them?
Syncromikey wrote: |
Mike |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Jun 09, 2013 4:50 pm Post subject: |
Syncronoid wrote: |
Mike |
When I dropped by last summer it was Daryl and his son. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Sun Jun 09, 2013 10:06 pm Post subject: |
SyncroGhia wrote: |
MG |
Well, since it was facing nose in, I decided it would be okay to have the wheel lift tow truck come in, and for me to un-bolt the drive shaft. Only the front wheels moved, the rears stayed put. I really didn't want to leave it outside at my shop, thieves are into some stupid things nowadays and I don't want to find out...
I've been mentally preparing myself for the battle ahead. I just wonder how/if I will be compensated for the extra vacation/ camping time I made solely for the van...I don't want to lose that, but I wonder how pushy I should really be. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Sun Jun 09, 2013 10:16 pm Post subject: |
Don't forget to mention loss of use of vehicle. I got a check for a few hundred dollars for that when a lady decided to go through a red light and smash one of my vans. |
Posted: Mon Jun 10, 2013 2:48 pm Post subject: |
I sat on my phone for about an hour waiting to talk to someone, and finally got a claim number. There is supposed to be an adjuster coming out to look at the van, so I am now waiting for that. Also, they have to talk with the owner of the other van to determine who was at fault (WHAT!?).
They said I could rent a car and they would reimburse me for $21.95 a day if I needed transportation. I told them that this vehicle is a camper, would they cover me renting a camper van? They couldn't answer that. I mentioned the weekends I will be losing out on camping this coming up summer along with a trip my wife and I had planned to get out to Yellowstone Nat'l park. for the 4th of July, they gave no promises until they could figure out what was going on
So, for now, I have to commute with my dad to and from work , or have my wife come and get me. I live 35 miles from work.
Things could be waay worse I suppose... |
