lightice Samba Member
Posted: Fri Jun 14, 2013 10:53 am Post subject: Koni 80-1349 & 80-1350 |
Has anyone tried these shocks on their stock splits?
Any reviews on them?
These are available at my local spares shop.
Based on ratwell:
http://www.ratwell.com/technical/Koni.html
They are for split front/rear. |
Sniperx Samba Member
Posted: Fri Jun 14, 2013 1:52 pm Post subject: |
I have a rebuilt (I rebuilt them) set on my bus. They are much nicer than KYBs and seemed to make my bus stop sooner and flatter rather than nose diving. I've also cornered them pretty hard and never had a "here we go" feeling. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Fri Jun 14, 2013 2:30 pm Post subject: |
i have always used the konis up front and the Bilstein gas shocks in the back.
And, yes, they are awesome, and comfy. quite possibly the most signifact ride improvement you can just "bolt on"
i can go back and forth between bias ply and radials, but i would never run stock shocks as long as the koni's and bilsteins are available _________________ regards
Uli
GTV Samba Member
Posted: Fri Mar 27, 2015 5:40 am Post subject: |
Not so much of a question as an observation...
I ran Koni's on my last IRS Beetle and absolutely loved them. Vowed to use nothing else on an ACVW. So I was searching on Koni's website just now and I see that they use the same shock for link pin (1349) and swing (1350) T1's, T2's and T3's. I'm surprised to see this as there is obviously a huge weight and spring difference (and I would assume compressed and extended length as well?) between a type one and type two... _________________ EMPI Power Rules! |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Fri Mar 27, 2015 10:46 am Post subject: |
Where can I buy Koni's for my 61 bus? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
dawerks Samba Member
Posted: Fri Mar 27, 2015 10:53 am Post subject: |
eshocks.com has Koni's and Bilsteins.
I prefer the Bilsteins (usually in stock, whereas the Koni's are not, and they are not listed bus specific). _________________ "There is only one sin; disconnection from self." |
GTV Samba Member
Posted: Fri Mar 27, 2015 11:08 am Post subject: |
Cheapest Koni's I found were on eBay, $91 each shipped. Worth every penny. _________________ EMPI Power Rules! |
Homeresque Samba Member
Joined: November 11, 2013 Posts: 90 Location: Hippy-Dippy Fruitcake Land
Posted: Sat Mar 28, 2015 11:30 am Post subject: |
Unbelievably I found my Koni/Bilsteins thru Summit. The Bilsteins they had in stock under a different PN than I was looking for but it cross-refs to the new # they have, and the Konis drop-shipped from the factory. |
bullifecal Samba Member
Posted: Tue Apr 07, 2015 1:31 pm Post subject: koni shocks |
Are the 80-1349 shocks adjustable? _________________ Lardy beaners like lowriders and Cerveza
NOBAMA |
Posted: Fri May 29, 2015 9:42 am Post subject: Re: koni shocks |
bullifecal wrote: |
Are the 80-1349 shocks adjustable? |
the konis are are adjustable, rebound that is. Never needed to do that, though _________________ regards
Uli
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Fri May 29, 2015 3:40 pm Post subject: |
Sniperx wrote: |
I have a rebuilt (I rebuilt them) set on my bus. |
How do you rebuild a shock? |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Sat Jun 06, 2015 8:01 pm Post subject: |
Those of you Koni users, are you running the red Special D's? _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
curtis4085 Samba Member
Posted: Sat Jun 06, 2015 8:52 pm Post subject: |
Mr. Electric Wizard wrote: |
Those of you Koni users, are you running the red Special D's? |
Not sure what a special D is but they are red in color. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
SCZ9-1-1 Samba Member
Joined: May 20, 2003 Posts: 716 Location: Santa Cruz, CA
Posted: Sat Jun 06, 2015 9:59 pm Post subject: |
Running them on my bus front and rear and love them. |
Posted: Tue Dec 01, 2015 2:33 pm Post subject: Re: Koni 80-1349 & 80-1350 |
I have a question for those running the Koni's up front on stock suspension. I recently decided to upgrade my shocks to Koni's. Upon installing the front shocks I noticed that the top portion of the shock hits the mounting plate making it impossible to bolt it down. See below
Anyone ever experience this? And if so what was your fix?
To give clearance I added a 7mm shim in between shock and mounting plate and used longer bolts.
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Tue Dec 01, 2015 5:15 pm Post subject: Re: Koni 80-1349 & 80-1350 |
brettsvw wrote: |
The shocks I bought recently came with similar spacers, they were not Koni shocks. |
These spacers were out of another set of shocks. Not Koni's! You would think at $104 a shock it would come with shims. _________________ Special Thanks to:
