CarreraRS2.7 Samba Member
Joined: October 27, 2005 Posts: 688 Location: Woodstock, GA
Posted: Tue Jun 25, 2013 10:07 am Post subject: CB Gas Saver engine kit |
I noticed CB has added a 1904cc Gas Saver kit to their Builder's Choice engine kits. Has anyone built one of these or have any opinions on this kit?
http://www.cbperformance.com/ProductDetails.asp?ProductCode=1179 _________________ If at first you don't succeed, skydiving is not for you.
Gigi: Saturn Yellow 1974 Karmann Ghia Cabriolet
El Barto: Rosso 2017 Fiat 500 Abarth |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Tue Jun 25, 2013 9:00 pm Post subject: |
It's just an engine. There's no magic in there. You could find out the specs and build with whatever parts you choose. The upside of the kit is that the homework is done for you. Just assemble.
I wonder if a Bug would be more drive able with a longer stroke and smaller pistons. Say 82x85.5 B. a little less ccs, but possibly more bottom end to move the vehicle through that final gear easier. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
mark tucker Samba Member
Posted: Tue Jun 25, 2013 9:05 pm Post subject: |
how would a 82x85.5 make a bug more drivable? |
Posted: Tue Jun 25, 2013 9:44 pm Post subject: |
I mean more go with less pedal. Not driveability. I'm thinking a longer stroke/similar cc engine will develop more torque in the 3000 rpm range than the 74 crank. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Tue Jun 25, 2013 10:55 pm Post subject: |
82 or up to 86 x 85,5 or up to 88 mm bore has been done plenty. And the end result is still the same, - for street engines, not the best set up, due to a very uneven the power/torque curve. For race engines with limitations in bore it is a solution it is a different matter.
74 or 76 x your choice of bore can work very well.
T |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Wed Jun 26, 2013 4:15 pm Post subject: |
Here we see the problem with dyno data (real or software) versus real world.
An undersquare (or just squarer than stock in our VW case) engine can perform well when torque and economy are the goal if it is built correctly, but the WOT curves are not what are desired for drag racing which is what Alstrup is noting. They are even better for constant speed applications such as aricraft and stationary engines.
The throttle response at lower engine speeds is certainly better when you get it right. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Thu Jun 27, 2013 6:08 am Post subject: |
Low end torque and fuel economy are my primary concerns. My current plan is to build the small-bore stroker motor from Aircooled.Net's mileage engine article, but the simplicity of CB's all inclusive kit is very appealing. _________________ If at first you don't succeed, skydiving is not for you.
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6621 Location: Houston, Texas
Posted: Thu Feb 23, 2017 3:58 pm Post subject: Re: CB Gas Saver engine kit |
Did you build this engine? I was looking into this one as well and wanted some opinions. |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Thu Feb 23, 2017 8:39 pm Post subject: Re: CB Gas Saver engine kit |
Would be So tempting to spend 30% more cash and get 100% more Torque/Power With one of the larger kits. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
heimlich VWNOS.com
Posted: Thu Feb 23, 2017 8:49 pm Post subject: Re: CB Gas Saver engine kit |
I hear you. I'm just looking for a stock setup.
I'm just thinking about it all right now anyways. A new engine is expensive. |
