karmann1st Samba Member
Joined: September 12, 2010 Posts: 93 Location: Florida
Posted: Wed Jun 11, 2014 9:56 am Post subject: |
nice!!!!
any news about the custom service and your box? _________________ Questions? Email me, I always answer all emails, same day or next. |
DorianL Samba Member
Posted: Wed Jun 11, 2014 10:07 am Post subject: |
yes - stuck in customs few a week so far. I e-mailed 'em a few hours ago. Standby |
Posted: Wed Jun 11, 2014 11:42 am Post subject: |
wow man! what a mess with the customs... even if you received on time the delay is imminent ,,,WOW
Engine looking good!!!!!
do you know the temperature of the engine when is running? just to know if standard paint will be ok for the engine tins... I do not like the BBQ paint because is mate.!!!! _________________ Questions? Email me, I always answer all emails, same day or next. |
Posted: Sun Jun 22, 2014 1:47 pm Post subject: |
gauges came in… they look sharp!
First, let's warm up the headliner…
Apologies for being out of focus - I did not realize it at the time. I clipped the entire headliner in there, and section by section, I glued it in there, I haven't yet used the hairdryer, but there will be very little to do. It went in there easier than I expected.
Seal went on easily enough. The T trim - need to preform the metal as much as possible. Some white grease and it pops right in.
I used some wire and again white grease to pop the windows in - it worked quite well except for some sort of issue i nthe rear - I'll try to salvage this, but I might have to start over.
Overall it's not that tough. I like the results.
Posted: Sun Jun 22, 2014 2:23 pm Post subject: |
WOW... did you fix mine? or is a new one???
I will read everything in your post later with time... this is good stuff my friend and I want to have the time to do it and enjoy it... thanks . alex _________________ Questions? Email me, I always answer all emails, same day or next. |
RHough Samba Member
Posted: Sun Jun 22, 2014 9:03 pm Post subject: |
DorianL wrote: |
Right… on to the rear. The rear axle? Seems strange to call and IRS rear axle…
WRONG!!! There was no clear reference to this in the Bentley service manual. I had this thrust washer/ring (?) on reversed. This way, as I tightened the bearing cover bolts, the ring threatened to push the seal out - it certainly was distorting the seal. UGLY! So off it came… and flipped around BEVELED SIDE OUT it went.
THIS is the way it goes on Problem now was that it was distorting and pushing the spring out. I solved that by pressing the thrust washer through the seal while in my hand rather than on the axle.
I had better start torquing everything to spec before I miss something... |
This is not quite right. Notice the outer dust lip on your seal is not making contact on the spacer? Look closely on the photos to see where the outer edge of the seal was on the spacer before.
You are right that putting the seal holder / bearing retainer on with the spacer on the stub axle will distort the seal.
Put the tapered side on the bearing side. Put the spacer in the seal then install the seal and retainer as an assembly.
When you are done (and the seal is seated correctly) the outer lip of the seal will seal to the spacer and the square shoulder of the spacer will show outside the dust lip.
The brake drum is soft compared to the bearing race and spacer. The small contact area of the tapered side is meant to go on the inner race of the roller bearing and the large contact area to the brake drum.
The small area can cause the brake drum to fret on the spacer and lose torque on the axle and take out the bearings, drum and hub. Not to mention that the open area of the seal will allow water/dust into the bearing.
I love your build. I wish I had the commitment to my '72 to restore it.
Cheers,
Randy |
Posted: Mon Jun 23, 2014 12:18 am Post subject: |
WHOA, WHOA, WHOA!!!! You are saying I have the thrust washer on backward???? The bevelled side should be facing in and riding on the inner race?????? That makes MUCH more sense
THANKS for catching that!!!!
Alex, I fixed yours AND this is a new one (those are your window trim). As I wasn't sure that there repair wouldn't distort the headliner, I decided to go with a new one. It's an ACME, of all things. I never heard of the brand… but it is nice. |
Posted: Thu Jun 26, 2014 7:19 am Post subject: |
For some reason I've been looking forward to installing this seal. I think because it's bringing me closer to finish $40
Hmmmm - my tank isn't this big…
Better
Voilà
I am VERY impressed with the quality of Classic Instruments build. Another good point - they sent me the wrong oil temp sender. Immediately sent me another one out. Great Company! |
Posted: Sat Jun 28, 2014 10:21 am Post subject: |
Went to get the flat four - I'll post the specs in an hour or so… but in the meantime, I took it home
Wow, picked this baby up alone - these things are light!
Replaced the seal. The old one was gone
As high as I could get her - blocking the front tires.
The skateboard is your friend…
I lifted it in with the floor jack. The studs lined up all right. I put the parking brake on and put it in first. Then I cranked the alt and it engaged no problem.
Posted: Sat Jun 28, 2014 10:46 am Post subject: |
Just writing down what I see - I really have little clue what the specs mean. I'm told to expect between 100-120 HP. I'll have it dyno tuned in a few months.
Crank: 69mm DPR
Rods: reman
Cam: Engle W-110
Oil pan: additional 1.4 liter CBP
Cylinders: 94mm x 69mm Mahle forged?
Heads: DRD L5 CNC 40 x 35.5 94mm doubled valve springs
Pushrpds: chromoly Manton
Tubes: Scat
Carb: Weber 40 IDF
Alt: Bosch 55Amp, 08/74
Intake manifold: 40mm CSP
Exhaust: Stainless steel CSP 38mm
Coil: MSD Blaster |
Posted: Sun Jun 29, 2014 1:22 pm Post subject: |
Right - made progress today…
Putting in the rest of the fuel line.
That exhaust pipe is going to burn right through that rubber…
Raintray - I love that thing
Put in the starter as well - WOW, that was easy. |
RHough Samba Member
Posted: Sun Jun 29, 2014 1:56 pm Post subject: |
DorianL wrote: |
Yep it takes about 15 minutes for the header and the seal to "self clearance" ... then you stare at it every day and realize that installing the seal the other way up would fix it ...
Like this:
How do I know ... don't ask ... |
Posted: Sun Jun 29, 2014 10:24 pm Post subject: |
Lololol. YES!!!! I was suspecting that. The seal is upside down.
I hope flipping it with the engine in Wong be that tough. |
TheFop Samba Member
Joined: February 03, 2014 Posts: 302 Location: Auckland - New Zealand
Posted: Mon Jun 30, 2014 1:54 am Post subject: |
Happy 1st anniversary.....I can't believe how much you've achieved in just 365 day!!!!!! If I achieve 1/2 as much in a year I'll be a happy man. _________________ Rusty 61 RHD Karmann Ghia Coupe - Resto in progress....slowly
Stock 69 LHD Karmann Ghia Coupe - Driver
67 New Zealand Spec Beetle - Being rebuilt
63 New Zealand Spec Beetle - Going Baja!
86 T25 Westfalia - Family Fun car |
Posted: Tue Jul 01, 2014 2:15 am Post subject: |
Holy XXXXX!!!!! You are right! It has been a year! Wow, I guess I did move along fast. THANKS!
Sooo, the cat thinks it'll be an easy job…
Hmmmm, even I think it'll be an easy job… The exhaust is clearly very good kit. I'm impressed.
After one VERY STUPID mistake that I shan't share (involving drilling out threads - 'guess I am used to Chevies) I propped up the left muff. Leveled it out with a jack stand... One hole drilled to hang it.
The other side was less straight forward - in order to achieve the same exhaust tip out… I need to hang the muff higher.
A bolt, some washers and a locking nut was the solution.
Looks all right - I still need to tighten and tweak here and there. The bumper needs a bump up on left side…
Happiness is in the small things…
The electronic speedo requires a pulse generator. I needed to adapt this cable to fut…
The cable tube will not insert beyond this sleeve in the spindle - so I had to trim the cable tube back 115mm (Think metric!)
Apologies for the slippers
Now where did I put that #$%^#$% C-clip?
As tempting as it is, I will not yet mount it. I need the wiper motor and everything else settled before I do that… So it's still a bird's nest… Grrr!
So far so good-
I hope to fire things up this weekend, but I am still missing a couple of fittings for the oil filter and the carbs. I can figure out a way to run it without the fittings, but hopefully the parts will get here in time. We do a BBQ on Sunday with some friends, and we fire it up. …hopefully! [img][/img]
Posted: Tue Jul 01, 2014 2:30 am Post subject: |
Note, the rear of the car has come down some and it is getting more sluggish to push back in to the garage… think it's getting heavier? |
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2877 Location: Auckland, New Zealand
Posted: Tue Jul 01, 2014 2:35 am Post subject: |
DorianL wrote: |
Shouldn't be a problem for a body-builder. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Tue Jul 01, 2014 3:03 am Post subject: |
With the exhaust you are using, you have seemed to done away with your heater boxes ( I didn't see them ). Will you have heat in the car? |
Posted: Tue Jul 01, 2014 3:27 am Post subject: |
Heh - well, I am an old Brother in Iron
No, no, the heater cans are still on there. You can glimpse them in grey here:
Again, this is to be a near daily driver. I think heating is necessary we wouldn't want the windshield to mist up
The brand is CSP 38mm super competition… at least that is what the bills says. |
Posted: Fri Jul 04, 2014 2:05 pm Post subject: |
I guess this is as good a place as any…
AN-8. Did I already say that I love working with steel braid and AN fittings? It feels so positive.
Heat shielding…
So ti comes down to this… I need to enlarge this by 7mm.
Hmmm, I could use the cardboard of the box as a template.
Grind, grind, grind…
Hmpf! It worked…
Temp sensor…
Oil pressure sensor AND idiot light. I'm that kinda guy…
