TheGrafs Samba Member
Joined: May 07, 2012 Posts: 239 Location: Utica, New York
Posted: Thu Dec 26, 2013 10:57 am Post subject: |
Hope everyone had a great holiday!
Plan to post much progress in the new year!
Cheers Samba! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Youtube: GrafsGarage3
Instagram: GrafsGarage |
Posted: Wed Apr 02, 2014 5:59 pm Post subject: |
Long time, no update Samba! The dreadful north-east winter season is coming to an end! Much progress has been done, so stay tuned for updates! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sat Apr 19, 2014 8:34 am Post subject: Body Work |
Heres some pictures from last fall before packing the Square away for winter. Did some patch work on the front clip to cover up the bumper holes.
Ground down the welds and put some Duraglass over the work and it looks good!
Another skim coat of light weight over the whole clip to smooth it out, and itll look as good as new! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sat Apr 19, 2014 6:14 pm Post subject: Engine rebuild |
A lot of work went in to the build of my 1641cc! I painted the engine tins with Duplicolor engine enamel. Went with a darker blue than I plan to paint the car to offset it. We upgraded it with an Engle racing Cam.
We torqued the fly wheel down and checked the end play
We went with the 87mm Pistons
Put on our rebuilt heads, now its starting to look like an engine!
Also scored a set of 34ICT Webers I plan to run, Waiting to drop the engine back in to show final product. Did some brake work today, and plan to update again tomorrow. _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Bobnotch Samba Member
Posted: Sun Apr 20, 2014 12:01 pm Post subject: |
Looks like someone made themselves some "eggs" for Easter. Nice work on the body and engine. Hopefully you used some red loctite on those cam bolts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 20, 2014 5:17 pm Post subject: |
Thanks Bobnotch! Yes Loctite, gasket cement and Lucas assembly lube came in handy on this engine build, as well as a torque wrench! We cleaned up the transmission today, decided to get a few more goodies for the brakes while were doing them. Seems like one thing after another with this ground up resto, but my father always said, Do it right the first time! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sun Apr 20, 2014 5:24 pm Post subject: Brakes |
Well yesterday we decided to do some brake work. We had a box full of new parts we used! While going through we decided to be on the safe side and replace the rear steel brake lines, as we did the rubber ones of coarse. A few other odds and ends need to be ordered but Ill leave you with the nicely painted Drums and Calipers!
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sat May 10, 2014 5:33 pm Post subject: |
The whole car is finally in primer.. Chassis Saver tomorrow and getting blocked out for sealer, and color! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Mon May 19, 2014 5:18 pm Post subject: Ready for Paint |
Tomorrow will be an exciting day! I'll be painting the roof of my car. Im going with VW Pearl White for the roof in PPG Shopline Single Stage Acrylic Urethane.
This will look better 24 hours from now _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Tue May 20, 2014 5:29 pm Post subject: |
Here it is! after four nice coats of L87 Pearl white, this baby shines! More than enough material to color sand and buff, put still maintain a nice flat and glossy surface. Cant wait to get that Diamond blue on the body! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Tue May 20, 2014 8:02 pm Post subject: |
TheGrafs wrote: |
Here it is! after four nice coats of L87 Pearl white, this baby shines! More than enough material to color sand and buff, put still maintain a nice flat and glossy surface. Cant wait to get that Diamond blue on the body! |
Looking good. Nice job. Looking forward to seeing the blue paint. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
MonT3 Samba Member
Joined: January 07, 2012 Posts: 1988 Location: South Dakota
Posted: Mon May 26, 2014 1:53 pm Post subject: |
Thank you for all the kind words everybody! Happy Memorial day, thank you to those who've served Hope to be spraying blue within the next week or 2. _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
collinVW32 Samba Member
Joined: May 23, 2012 Posts: 186 Location: Wichita, Kansas
Posted: Wed May 28, 2014 5:37 pm Post subject: |
Cant wait either Collin! Thank you for your interest _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sun Jun 01, 2014 3:19 pm Post subject: |
Not the best day for the Grafs... 2 faulty harbor freight spray guns= Run in sealer... Block that out, run to HF for yet another gun.. one coat of color on shell+ hood and hatch and runs... Going to have to let that dry and block it out.. Hoping for better luck next time. _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Jun 01, 2014 7:43 pm Post subject: |
TheGrafs wrote: |
Not the best day for the Grafs... 2 faulty harbor freight spray guns= Run in sealer... Block that out, run to HF for yet another gun.. one coat of color on shell+ hood and hatch and runs... Going to have to let that dry and block it out.. Hoping for better luck next time. |
Are you using the correct reducer for your air temperature? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Jun 04, 2014 4:01 pm Post subject: |
Tram wrote: |
TheGrafs wrote: |
Are you using the correct reducer for your air temperature? |
Well we diagnosed that our gun wasnt receiving the correct air pressure. No biggie, as I will be respraying it this weekend with a Satajet 4000! Its good to know people! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sun Jun 08, 2014 2:59 pm Post subject: |
Got a whole car in paint! came out a lot better. still some sags/runs but have more than enough to shoot another coat if needed. Pictures to come, my hopes are to tow it to the Type 3 Invasion! We'll see! _________________ 1957 Oval Semaphore Beetle
1964 Notchback S
1966 Fastback
1970 Squareback
Posted: Sun Jun 08, 2014 5:01 pm Post subject: fresh paint |
looks good in these pictures!
1964 Notchback S
1966 Fastback
1970 Squareback
