tylergeddis Samba Member
Posted: Tue Jul 02, 2013 10:00 am Post subject: iPod to single speaker |
I was wondering if I could connect my iPod to the stock single speaker next to the speedometer in my bug. I want to keep the simple dash look without a radio. Not sure if the I pod would supply enough power to the speaker. |
philermonic Samba Member
Joined: November 09, 2010 Posts: 361 Location: Orange County, California
Posted: Tue Jul 02, 2013 10:24 am Post subject: |
The iPod will not "drive" the single speaker in the dash of your car. It's output needs to be greatly amplified and there are a number of different avenues you can take to achieve that.
I'm sure if you use the search feature on here you can get some direction. _________________ "A camel is a horse designed by a Committee" |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Tue Jul 02, 2013 10:32 am Post subject: |
Blaupunkt "Melbourne" stereo has an aux in jack and sells for less than a hundred bucks on Amazon. Plays SD cards and flash drives, too. No moving parts, no CD drive, no tapedeck.
If your bug is still 6V you can get a USB-powered iPod amplifier. Wire it right in to the fusebox, they're a nominal 5V. |
BerylGreen63 Samba Member
OLDveedubs Samba Member
pwmcguire Samba Member
Joined: January 30, 2011 Posts: 1108 Location: Kennesaw GA
Posted: Tue Jul 02, 2013 6:59 pm Post subject: |
Is it 12 or 6 volt? |
DHMaher Samba Member
Joined: November 16, 2009 Posts: 787 Location: Portland, Oregon
Posted: Wed Jul 03, 2013 2:36 pm Post subject: |
I used a small amp in the trunk with an 1/8 in wire hidden in the ash tray. Modern convenience with stock look.
Later I added a switch under the dash so I could switch between my Sapphire V radio and mp3 player. All in all it's very inconspicuous. _________________ Daniel
"POs, you gotta love them, because killing them is illegal." -Unknown Samba Member
1967 Beetle - Java Green
See my ads |
sinjefe Samba Member
Bugugly Samba Member
Joined: January 16, 2008 Posts: 321 Location: Carson City, Nevada
dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Wed Jul 23, 2014 11:30 pm Post subject: |
How do you hook up the wires to run only ONE speaker? Do you "bridge" the two channels or just run one channel? _________________ 1963 Karmann Ghia |
Posted: Thu Jul 24, 2014 6:41 pm Post subject: |
The unit runs on one channel. You totally bypass the radio. It's not even used. The unit has a master volume attatched to the box. It's simply a positve and negative type set up with either one or two speaker set up. I bought the single speaker set up. They sell both types. _________________ "When it rains...
It Pours" |
