311 905 205 T setting
FreeBug
FreeBug is offline
PostPosted: Tue Jul 02, 2013 9:37 pm    Post subject: 311 905 205 T setting Reply with quote
I'm away from my books, can't find info on this distributor, for type 3, not sure if correct setting is 5° ATDC with hoses on, or 0° with hoses off. It's DVDA, I think 1973 ish...
It's one way till a certain engine N° U........., then the other...
Not sure if distributor changes, so if anybody knows....
Thanks!
Slow 1200
Slow 1200 is offline
PostPosted: Wed Jul 03, 2013 2:28 am    Post subject: Reply with quote
if I recall correctly thats a 71-72 carbed manual distributor, it's supposed to be set at 0º with hoses ON, as long as the retard side is not leaking (which it always is), the vacuum canister is totally unavailable
I'd check the total centrifugal with hoses off and adjust to 32º
Alpha_Maverick
Alpha_Maverick is offline
PostPosted: Wed Jul 03, 2013 5:59 am    Post subject: Reply with quote
http://www.oldvolkshome.com/ignition.htm
I'm not seeing a 311-905-205T... if it's a 113-905-205T, then you set it to 0° static
There's a bunch of 311-905-205 dizzies with various letter suffixes, but I didn't see a T
Alstrup wrote:
hmm well, wiggly Laughing I like 5,5inchers in the rear at least.
rickycox
rickycox is offline
PostPosted: Mon Oct 13, 2014 10:15 am    Post subject: Dizzy Reply with quote
Can anyone recommend a suitable replacement for the 311 905 205 T ? It's for a stock type 3 twin solex engine.
Changing to a single vac can type is fine... any suggestions ?
The Wonky Donkey Emporium
Classic Volkswagen & Porsche Restoration
www.wonkydonkeyemporium.co.uk
Follow us on Twitter - www.twitter.com/thewonkydonkey
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
HRVW
HRVW is offline
PostPosted: Mon Oct 13, 2014 3:09 pm    Post subject: Reply with quote
Idea On your T3 use a 009 dist as there is absolutely nothing wrong with them. The pully will have (3) timing marks... use the middle one... (3000 RPM) to the pointer
