scirocco_crazy Samba Member
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Aug 20, 2014 10:11 pm Post subject: |
scirocco_crazy wrote: |
Great Job on the thread, I see some friends of mine have been following this build. Did you figure out the brakes? How about rear disks for about $150?
Nepenthe88 wrote: |
Need some help....
Today I started looking at all the parts I have to re-do the brakes. In the Rear hardware kit there's shoe retaining springs, swirly caps and two different sizes of pins. Are these necessary on a 78 bus? This post http://www.thesamba.com/vw/forum/viewtopic.php?p=7217762 says VW discontinued their use after 74 or 76 and then started re-using them again on the vanagons. Of course I bought new backing plates and they have a hole for insertion of the pins, BUT the stock backing plates on my bus DON"T have the holes for the plates.
What do do?
That and I tried dry fitting things in the living room and I can't get the cap on, even with the long pins. how difficult is it to get the bloody things on?
oh do tell...i want a set... with e brake setup? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Nepenthe88 Samba Member
Joined: September 03, 2010 Posts: 1320 Location: Colorado
Posted: Thu Aug 21, 2014 4:29 pm Post subject: |
Tcash wrote: |
Hi
The pins that come in the kits are too short. Guy's have had to use there old pins.
Good Luck |
Ugh! But I don't HAVE old pins to re-use F-my life.... (aka, I'm grumpy cause I got potentially REALLY BAD NEWS today AND found out my pins are too short. Story of my life )
Great Job on the thread, I see some friends of mine have been following this build. Did you figure out the brakes? How about rear disks for about $150? |
Like Stewart said... if it has a parking brake I'm all in. Gotta have that to pass NYS inspection. Wait! No... If it's the same CRAPPY EMPI disk setup as I put on the bug, I don't want anything to do with it. What junk. Their machining tolerances were so loose that I had to send 3 calipers back and a pair of rotors before giving up, mixing and matching parts, machining spacers and using various sized washers to just get things to work.
You sure you didn't miss a zero? I'd love to have me a set of Porsche rear disks with custom hubs + front bustangs from Wagon'sWest
http://www.wagenswest.com/partstore/index.php/disk...m-oem.html
http://www.wagenswest.com/partstore/index.php/disk-brakes/71-79-bustangs.html
OR...
the Subabrakes (Goodness only knows how much they're gonna cost)
http://www.subarugears.com/subabrakes/ _________________ a Black & Blue Su-BUS-aroo
Follow my adventures in the GoWAND'RLoST bus on Instagram:
https://www.instagram.com/gowandrlost/ |
Posted: Fri Aug 29, 2014 4:43 pm Post subject: |
Time for an update. First, I got a Hitch from Jamie Rivers at http://www.globalserve.net/~jrivers/latebayhitch.htm. It's a nice piece and installs pretty easily (hardest part is holding it and the bumper in place with your leg while you zip the bolts in). For me of course it took a little more effort since I had to cut away the hitch the previous owner welded on.. and boy oh boy did he use a lot of weld. Very little of it penetrated the brackets or bumper. Most was just laid on top of the original crappy welds. Fat lotta good that was gonna do! Regardless, I had to use an acetylene torch to get it off, and then grind everything away. Anyway... the rear part of the receiver is flush with the back of the bumper (or would be if I hadn't cut a square out of the bumper to get the old one off), so there's no shin crunching... unless I leave the ball on. Here's a pic pre install. Didn't interfere with the exhaust or anything.
Posted: Fri Aug 29, 2014 5:04 pm Post subject: |
And then I spent the past 2 days doing brakes... It's not as difficult as I expected (I've never done rear drums), and would have been pretty much a breeze... If I had all the parts and tools I needed
Anyway, here's what I started with on the drivers rear. The other side wasn't much better:
Goodness!!! I'm not even sure how the bloody thing stopped. I actually feel kinda silly having put 110 miles on the thing. At least no one's dead!!! Anyway, In order to change the rear backing plate, the hubs need to come off. I had planned on using the torque multiplier tool I have and used to take the rear axle nut off the bug (36mm), but.. um... Huge oversight on my part! The rear nut is 46mm?! Ugh. Turns out no one carries a 46mm socket. NO ONE. But fortunately, a 1-13/16" socket is within a 1000th of an inch. Bought that one. And it fits well.. Unfortunately my gun wasn't strong enough to get the nut loose (260ft/lbs). So I bought another one... which wasn't strong enough... so I finally went for the creme-de-la-creme of home mechanic impact guns. It's an Ingersoll Rand 231C. Max Torque 600ft/lbs, and a nifty little switch that lets you change the amount of torque you apply in the ON direction. Worked like a dream (though a larger compressor would have been nice)
All that running around cost me an entire day basically. Silly anti-efficient day because of a relatively small oversight. Drives me crazy.
So then this AM I assembled the rear drums Please take a look and tell me if you see anything missing or out of place. Hub off:
hub on:
and drum on w/ adapters:
Doing the rears took most all morning and into the afternoon. Not because it's really takes that long but because there's no horseshoe clips in the rear hardware kit. WTF?! It's a pretty innocuous piece. PUT IT IN THE KIT!!! Anyway...There's one trip to FLAPS. Then... when I was installing the anti squeeeel springs I shot a pair of caps clear across the driveway and into the lawn somewhere, lost forever. That necessitated a SECOND trip to FLAPS. Ugh. Here's the passenger side. Again, take a look and tell me if I did anything Dumb:
And since I have to re-bleed the entire system, I put new flexy lines in at all 4 corners:
Posted: Fri Aug 29, 2014 5:15 pm Post subject: |
Then I moved on to the fronts. Hope of a quick fix almost immediately dashed...This is the Passenger side caliper. The dust boot has been chewed almost completely away:
Sooooo.... That's probably why the bus dives to the left when braking. I'm not entirely sure that piston is working. To fix it, I bought a pair of caliper rebuild kits for (what I believe) are ATE calipers. Just gotta wait the week and a half for them to get here. The driver's side isn't much better, so I'll do both. And then there's this:
Hmmm... I THINK the water's getting in thru the speedometer cable hole. I hadn't noticed but there's no cotter pin on the cable end. The wheel bearings need changed here as well (obviously) as it's a bit lumpy when it spins. Thankfully I bought inner and outer bearings and seals for all 4 corners. This is the only corner I'm gonna do however as the other three corners all spun great and the grease still looked clean. I just re-packed a little more in there.
So. I'm at a standstill with the bus on jackstands slowly sinking into the asphalt while I wait for rebuild kits. _________________ a Black & Blue Su-BUS-aroo
Joined: January 01, 2007 Posts: 16881 Location: sticksville, ct.
Posted: Fri Aug 29, 2014 7:09 pm Post subject: |
honestly, I would cancel the rebuild kit and just order 2 new/rebuilt calipers. for the time you will spend screwing with them, and seeing how ugly they are, I personally wouldn't waste the time.
I think you will get them apart and get your feelings hurt by what you find _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Aug 29, 2014 7:36 pm Post subject: |
skills@eurocarsplus wrote: |
I think you will get them apart and get your feelings hurt by what you find |
x2 new calipers are WAY easier and MUCH better. just do it. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Fri Aug 29, 2014 8:43 pm Post subject: |
Stuartzickefoose wrote: |
x2 new calipers are WAY easier and MUCH better. just do it. |
X3 _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Tcash Samba Member
Posted: Sat Aug 30, 2014 10:41 am Post subject: |
Hi
Note how your upper springs are stretched out. Can't find it, but there was a post on the upper spring holes being in the wrong place.
It has been reported that the drums rub on the new backing plates. Seems easiest solution is to have some material cut off the drum on a brake lathe.
Good Luck |
Posted: Sat Aug 30, 2014 12:30 pm Post subject: |
Front bearings got done both sides today inside and out. Water was definitely getting in thru the speedo hole, someone had siliconed it in the past. I'll probably do the same after I send the speedo cable out for new ends and the ratio adapter. So, the backing plate was cleaned up. Spindles looked good. I also painted the grease cap to match the rims. Think it looks pretty good. Just waiting on calipers and a system bleed at this point.
Posted: Sat Aug 30, 2014 12:40 pm Post subject: |
Tcash wrote: |
Hi
Good Luck |
ugh. Thanks China! I doubt there's anything I can do about the spring, but I'll keep an eye on the backing plate issue. I'll go thru and re-adjust the rears again after I bleed the system. Um, so approximately how far out should the adjuster nut be with new pads? Cause they're different one side of the bus to the other, but equal within each assembly. It looks to me like the driver's side needed adjusted out about 1/4" away from the star spinner, while the passenger side is only out about 1/8". _________________ a Black & Blue Su-BUS-aroo
Tcash Samba Member
Posted: Sat Aug 30, 2014 12:54 pm Post subject: |
Nope. That grommet in the rear is intact and looks good. Water wasn't getting in there. Besides the inner bearings looked great, outer ones were a little tarnished. I think the problem was that there wasn't an e clip on the cable end and water got in thru there. The PO siliconed the cable in. Why? I dunno. Point is, I spent what like $30 for new bearings and seals? and now I'm relying on a 0.30cent e clip to protect those bearings by keeping the cable where it should be.... that freaks me out some, so I might dab some silicone on top of everything just in case. _________________ a Black & Blue Su-BUS-aroo
Tcash Samba Member
Posted: Sat Aug 30, 2014 1:52 pm Post subject: |
Can't find it, but I seem to remember finding an o-ring behind the "C" clip. |
GeorgeL Samba Member
Posted: Sat Aug 30, 2014 9:20 pm Post subject: |
Unless you immerse the front end, much water isn't going to find its way in through the speedo cable hole. How does the other side look?
If there is rust in the wheel bearings I'd be concerned about the bearings in the torsion beams. Pump some grease through them and see if rust comes out with the old grease. |
Posted: Sat Aug 30, 2014 9:21 pm Post subject: |
GeorgeL wrote: |
Unless you immerse the front end, |
somehow i suspect we...i mean he...might. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri Sep 05, 2014 10:22 am Post subject: |
GeorgeL wrote: |
somehow i suspect we...i mean he...might. |
um... the passenger side bearings were perfect. I just replaced them to keep things symmetrical. I'm not too worried about the beam, but I'll grease her up at some point.
Also... I ordered those calipers, what? Like a week ago? And today I get a call from them saying, "oops, we don't have them in stock". So I looked all over and couldn't find anyone who could source me calipers... except NAPA They are way cheaper than the BusDepot calipers, and have a lifetime warranty. Sounds good to me. _________________ a Black & Blue Su-BUS-aroo
Posted: Fri Sep 05, 2014 10:38 am Post subject: |
Nepenthe88 wrote: |
GeorgeL wrote: |
Also... I ordered those calipers, what? Like a week ago? And today I get a call from them saying, "oops, we don't have them in stock". So I looked all over and couldn't find anyone who could source me calipers... except NAPA They are way cheaper than the BusDepot calipers, and have a lifetime warranty. Sounds good to me. |
olympic brake supply had some good ones for about 100 each. thats weest coast though....
glad you found some _________________ Stuart Zickefoose
206-841-7324
[email protected] |
