Porsche60 Samba Member
Joined: December 27, 2007 Posts: 210 Location: Far East
Posted: Tue Nov 24, 2015 10:35 am Post subject: Re: CB Performance black box |
cranking timing would be lower than 10 degrees.
25 is too much.
btw, how can you tune without the cable? |
rubenski Samba Member
Joined: December 03, 2014 Posts: 100 Location: belgium
Posted: Tue Nov 24, 2015 11:03 am Post subject: Re: CB Performance black box |
Hmmmm, or was it 12?? Youre making me confused.....
I didnt tune the engine, i leave that to my builder.
He has the cable at his shop.
It went on a dyno to tune fuel and spark. But now i cant get it going when its cold.
When the engine ran and was hot, it started verry good.
He sent me a map from whilst on the dyno. But he made a few changes.
So kow i have the map but i cant open it without the BB being connected...
Otherwise i could show you guys. |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Tue Nov 24, 2015 5:15 pm Post subject: Re: CB Performance black box |
You should be able to open a map without the Black Box being connected. I've tweaked maps away from the car a number of times, then flashed them onto the BB later.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Tue Nov 24, 2015 5:31 pm Post subject: Re: CB Performance black box |
Changing the ignition advance at your 400 and 800 bins will not make it start any better.
You more than likely have other problems than a few degrees more or less advance at idle.
I have started my engine anywhere from 6 Degrees BTDC to 18 Degrees BTDC and there is no noticeable difference. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Nov 24, 2015 8:13 pm Post subject: Re: CB Performance black box |
i think clonebug is right.
rubenski, if you have the problem related to the temp, especially when it's cold, it's not black box.
it might be carb or intake heat problem. |
Posted: Wed Nov 25, 2015 12:13 pm Post subject: Re: CB Performance black box |
I got the engine running today, started after a few cranks and after i re-plugged the plug wire that came loose.
I just got a new set and the round tabs that go in the cooling tins are still a bit non-flexible..
Alltough i got it running, starting was not easyand will need some fine tuning. Eirher in fuel and or spark table....
I also emailed cb perf, Mark got right back at me, said the table looked verry good. No problems there so glad we're in the right direction.
He only said we should check the timing while cranking with a timing light. But i dont have one so a trip to my builder's shop it is. If only it stopped raining.... |
Posted: Fri Dec 04, 2015 10:17 am Post subject: Re: CB Performance black box |
THE PROBLEM IS SOLVED!
Talked to my builder about what could be the problem, came to the conclusion that it had to be something with the ignition.
Only thing left was the coil. We changed plugs and new sparkplug wires. Carburation was great to so no pproblems there.
But then:
I changed the pertronix flamethrower 3.0 ohm epoxy coil with my old blue bosh coil and it started right up.
Emailded Mark about it. Wainting on his reply.
So 2 options left:
- I have a bad pertronix coil (wich we are going to send back to the manufacturer)
- The blackbox has problems with the pertronix coil....
To be continue! |
Posted: Fri Dec 04, 2015 10:23 am Post subject: Re: CB Performance black box |
i had a same pertronix 3ohm coil before, and had some misfire problem.
after i replaced the coil with 1.5ohm mallory, it got better.
i'm not sure if the pertronix coil was bad, though. |
Posted: Sat Dec 05, 2015 2:17 am Post subject: Re: CB Performance black box |
What could be the reason that the BB has issues with high Ohm coils? |
Posted: Sat Dec 05, 2015 3:13 am Post subject: Re: CB Performance black box |
this is just my guess.
higher ohm coils need more time to charge the spark energy.
i guess that BB decides the charge duration depending on the ohm.
longer charge duration means more heat created in the coil, thus overheat. |
Posted: Sat Dec 05, 2015 5:10 am Post subject: Re: CB Performance black box |
Sounds reasonable,
Could also explain why it started fine when warmed up.... must be some left over energy in the coil.... |
tvrgeek Samba Member
Posted: Fri Jan 08, 2016 5:13 pm Post subject: Re: CB Performance black box |
I know I am dragging up an old thread, but many of the comments here peaked my interest. I am running a CB Black Box on my MGB. I have been attempting to get a complete answer from CB on their charge time management and if they can safely drive a lower impedance coil. They implied to me to "use the one you have" I think I am a bit shy of the optimal 2.5mS or so charge time needed for a Bosh Blue, so I wanted to hear others experiences before I put in my buffer-inverter, TFI driver and coil. If they used some new fancy HEXFET, I can see how they could switch that much current, but with no heat sink, and thin wires, I have my doubts it can deal with a 1.5 Ohm coil.
BTW, permeability varies with temperature, so the optimal charge time is not constant. Joy! |
Posted: Sat Jan 09, 2016 4:54 am Post subject: Re: CB Performance black box |
Another BTW, I tested a Lucas , Bosch, generic, and Pertronix 3 Ohm coils at idle. I found virtually no difference. If I were to give a tiniest edge to any, it would actually be the Pertronix. I do have a bit more long term confidence in the Blue. |
Posted: Sat Jan 09, 2016 5:17 am Post subject: Re: CB Performance black box |
i'm running 1.5 ohm Mallory coil for 1-1/2 year and i haven't noticed any problem so far.
what would be possibleproblems? |
bugeyesprite Samba Member
Posted: Sat Jan 09, 2016 8:38 am Post subject: Re: CB Performance black box |
I have an ignition coil on mine. No idea what ohms or brand it is. Works great.
What ohms does CB recommend? Ballast/no ballast?
Try a little test; First, to eliminate any bias you might have, paint all your coils black, shuffle them then try them one by one and note any difference. If you find any... I'll eat my hat. |
EVfun Samba Member
Posted: Sat Jan 09, 2016 10:16 am Post subject: Re: CB Performance black box |
Porsche60 wrote: |
When the coil primary is switched on the current quickly heads for 9 amps. With a 3 ohm coil the current would only be heading toward 4.5 amps. _________________
Wildthings wrote: |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Fri Jul 13, 2018 9:43 am Post subject: Re: CB Performance black box |
Guys.
I have a turbo bug and I'm trying to improve my launch. I'm using a locked dizzy at 24* and use a DVDA vac can to retard timing.
I want to be able to rev the throttle to a rpm of my choosing, and then only have the clutch pre load and hand brake drop to think about , will the Black box be the best and easiest way to achieve this.
p.s I want to keep the dizzy. |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Fri Jul 13, 2018 10:07 am Post subject: Re: CB Performance black box |
GARRICK.CLARK wrote: |
Guys.
I believe you need a fuel controller to do this. I think the Black Box is spark only. Are you using a Carb or Fuel Injection?
I know Megasquirt, because that is what I have. Go Megasquirt, it has launch control like you desire. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7216 Location: Videbaek Denmark
Posted: Fri Jul 13, 2018 10:43 am Post subject: Re: CB Performance black box |
rubenski wrote: |
But then:
So 2 options left:
To be continue! |
Hello.
I have seen a few of the Pertronix coils go bad. Ditto with Bosch. Only the Bosch tends to just get worse and worse over some time before they quit completely. If it runs nice with a blue Bosch. I would personally say stuff it and buy another Pertonix. The reason is that it has approx 20% better spark performance than the Bosch. Also the Pertronix makes the plugs less likely to foul and easier starts on warm engine.
Next, check the voltage coming to the coil from the key. Often the system eats up 1 up to 2V which makes the coil less efficient and the BB more likely to make kick back at starts because the voltage drops too much. I recommend using the key wire for treigger only and get power directly from the battery via a relay.
T |
Posted: Fri Jul 13, 2018 12:59 pm Post subject: Re: CB Performance black box |
I'm using a HS8 su carb. My set up is very mechanical in how it all works. No electric gizmos.
I have found an Omex Clubman 2 step rev limiter that wires straight to the coil, think I'll give it a go. The 1 step is button activated so I can fit that to the handbrake, 2nd step is the high up rev limiter . |
