65 Squareback Restoration in S.A.
Alastair 69
Alastair 69 is offline
PostPosted: Wed Jul 31, 2013 6:57 am    Post subject: 65 Squareback Restoration in S.A. Reply with quote
Hi All,
Been lurking around here for a while since I got my 65 square back in April of this year.
I got her half stripped and in primer from the previous owner.
I have slowly started restoring her, will post some pics shortly.
Alastair 69
PostPosted: Wed Jul 31, 2013 7:25 am    Post subject: Reply with quote
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Jul 31, 2013 7:32 am    Post subject: Reply with quote
Striipping paint is the worst job, so might as well pull all the windows out now to strip/primer/paint it. Put your new headliner in it before the windows go back in.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Alastair 69
PostPosted: Wed Jul 31, 2013 7:35 am    Post subject: Reply with quote
So far I have pulled out all the windows, old roof lining, stripped out the front suspension, cleaned it all up and painted it, and busy putting it back, will post some more pics.
Erik G
Erik G is offline
PostPosted: Wed Jul 31, 2013 7:43 am    Post subject: Reply with quote
looks like a good project, welcome
hentotheree
hentotheree is offline
PostPosted: Wed Jul 31, 2013 3:54 pm    Post subject: Reply with quote
very nice job so far, body looks in good shape!
Alastair 69
PostPosted: Wed Jul 31, 2013 11:10 pm    Post subject: Reply with quote
Here are some pics of the beam all cleaned up, busy putting it all back together. Dropped the front 2 splines (I think) while it was out.
yunazz
Banned
yunazz is offline
PostPosted: Wed Jul 31, 2013 11:20 pm    Post subject: Reply with quote
Looking good Sir. keep it up!!!!
What color will you be going for?
Alastair 69
PostPosted: Thu Aug 01, 2013 1:05 am    Post subject: Reply with quote
I see you also from S.A.
Thinking of going blue..
Alastair 69
PostPosted: Thu Aug 01, 2013 6:30 am    Post subject: Reply with quote
When putting the front beam back in place I have about a 10mm gap between the top of the bracket and the chassis of the car where the 2 bolts bolt straight up. the 3 bolts going through the front of the bracket into the back of the bracket line up perfectly. any suggestions??
yunazz
Banned
yunazz is offline
PostPosted: Thu Aug 01, 2013 12:20 pm    Post subject: Reply with quote
I'm not 100% sure but i believe theres a rubber spacer that needs to go there. You could just use metal washers ive seen them use that before thinks its called shims or something like that
Bobnotch
Bobnotch is offline
PostPosted: Thu Aug 01, 2013 8:30 pm    Post subject: Reply with quote
Yes, you're missing a rubber bushing in that spot. It's actually 1 of 2 parts plus a metal sleeve and bolt combo that goes there.
http://classicvw.org/gallery2/v/partsbook/Parts+Book/page+77.jpg.html
Parts 54 thru 57 in this picure.
Those parts are used with #19 in this picture.
http://classicvw.org/gallery2/v/partsbook/Parts+Book/page+66.jpg.html
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Alastair 69
PostPosted: Thu Aug 01, 2013 10:49 pm    Post subject: Reply with quote
These parts?
I think these go somewhere else??
Bobnotch
Bobnotch is offline
PostPosted: Fri Aug 02, 2013 5:11 am    Post subject: Reply with quote
Alastair 65 wrote:
These parts?
Yup,the bottom one goes into the gap. Then the sleeve is inserted from below with the upper bushing (in your pic) then the bolt and washer combo. The washer seats the sleeve against the body, so the bolt can be torqued to 18 ft lbs. This allows so movement of both the body and the chassis.
Tram wrote:
Tram wrote:
Riekert
Riekert is offline
PostPosted: Tue Aug 19, 2014 8:42 am    Post subject: Reply with quote
Nice one!
Glad the SA peeps representing Very Happy
Alastair, you don't know of a cheap sqaureback maybe? Very Happy
And I do realise that its a year old... Razz but hows the progress?
