theDrew Samba Member
Posted: Thu Aug 08, 2013 10:38 pm Post subject: VDO tach wandering |
Hey folks,
I put in a VDO tack and the needle will wander around a bit. the higher the rpm the more it wanders
thoughts?
heres a pointless video of it in action. The bug is just cruising, so no RPM should be changin.
_________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Randy in Maine Samba Member
Posted: Fri Aug 09, 2013 3:17 am Post subject: |
From e-guages FAQs...
Quote: |
TACHOMETER GAUGE QUESTIONS:
Will VDO tachs work with points ignition or Pertronix?
Answer: Yes, with diode in line on the signal lead. Instructions are as follows:
Purchase a diode #1N4005 from a local electronics store such as Radio Shack or Circuit City. Cut both ends of the diode so each is approximately 3/4” long. Crimp 1/4” female spade connector on the end of the diode with the silver band. Crimp butt-splice connector on the other end of the diode. Crimp the opposite end of butt-splice connector to the wire connected to the ignition signal source. Connect 1/4” female spade connector used in #3 above to terminal #4 on the back of the tachometer.
Connect a ground (-) wire to terminal #3. Connect a switched 12-volt power wire to terminal #2. Set switches for appropriate amount of cylinders.
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
Gonzo1970 Samba Member
Joined: July 10, 2013 Posts: 178 Location: Belleville, IL
Posted: Fri Aug 09, 2013 8:52 am Post subject: |
It will work. Have to do that with Motorcycles all the time.
-Gonz _________________ Sometimes the lights all shining on me
Other times I can barely see
Lately it occurs to me
What a long, strange trip it's been |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Aug 09, 2013 1:21 pm Post subject: |
Having a brain fart - basically put a diode in series between the coil - and the lead to the tach with the stripe end of the diode connected to the tach lead? _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Fri Aug 09, 2013 1:41 pm Post subject: |
My understanding is that the VDO tach is quite sensitive to "stray voltage" or "electrical noise".
I don't know if it is worse with a points replacment module or not, but the diode seems to fix the problem. |
camaroboi13 Samba Member
Joined: February 22, 2013 Posts: 902 Location: San Bernardino, CA
Posted: Fri Aug 09, 2013 6:49 pm Post subject: |
theDrew wrote: |
you guys rock. put in the diode and its rock steady. onto the next problem! |
Best quote of the day lol. Glad you got it worked out, I will most likely be doing the same this weekend if I can figure out how to get a day off work! _________________ 69 bug 1600sp buckpack ceramic header w mondo muffler, riviera wheels, 185/65 front 205/70 rear, dual baby webers, big stereo in the works.
2001 Yukon Denali 6.0l AWD 24s TVs surround sound playstation 6 disc dvd etc etc.
2005 Nissan Maxima 3.5l stock mama's car
FFL GUN DEALER! PM ME FOR SOCAL TRANSFERS! |
