coolparts Samba Member
Posted: Mon Sep 16, 2013 6:42 pm Post subject: |
Yes but once you go black you never go back ! |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Dennis74 Samba Member
Joined: May 03, 2009 Posts: 17 Location: Südküste Luftwaffe, Finland
Posted: Tue Sep 17, 2013 7:20 am Post subject: |
My 16 Oct. -51 11C tank is also dark gray, not black _________________ VW 1300 Sedan (6/-74) German Look 2110cc
VW De Luxe Sedan 11C (10/-51) Project "original"
VW 181 -72 Military |
roymartian Samba Member
Posted: Thu Sep 19, 2013 7:33 pm Post subject: |
About to take shell off any tips welcome, please bit nervous about any potential shell twist or movement especially as ragtop
Heater channels are solid and from and back solid...
1. Leave doors on?
2. Add extra brace?
3. How to support across heater channels ok?
Or am i being a drama queen as I'm told shell is light no issues...? |
58deluxerag Samba Member
Posted: Thu Sep 19, 2013 7:38 pm Post subject: |
roymartian wrote: |
Yes.
Just take it off, you'll be fine. _________________ -Corey
'58 Binz
'58 Beetle Ragtop
'65 Sundial |
BUGBOY1976 Samba Member
Joined: August 21, 2004 Posts: 278 Location: Australia
Posted: Fri Sep 20, 2013 3:25 am Post subject: |
Shouldn't you be putting it together so you can work out whats missing? Then make a list and then pull the rest to bits. |
Posted: Fri Sep 20, 2013 6:50 am Post subject: |
Ok, thanks guys for advice no worries, looking forward to one day soon adding new hood badge - very cool.
Posted: Sun Nov 24, 2013 2:58 pm Post subject: 25Hp Heads |
Just starting messing about with 25Hp I have for car, although case looks like a later replacement, under rocker covers heads are stamped
VW 04 02 5
Any ideas... |
Posted: Mon Nov 25, 2013 4:02 am Post subject: Re: 25Hp Heads |
roymartian wrote: |
VW 04 02 5
Any ideas... |
Not 100% sure but I have quite a few heads with that.
Posted: Mon Nov 25, 2013 4:13 am Post subject: |
Nath,
Your picture looks instinctively older than mine as logo is almost kdf like and on the right of date stamp whereas mine is on the left and not as crisp.
Any ideas much appreciated, will post some accurate pics as I tear down motor.
Thanks for advice, do you have a 50's block still... |
Posted: Tue Nov 26, 2013 3:22 am Post subject: |
roymartian wrote: |
Nath,
I don't think its a date stamp but more a part number. I think if it where a date stamp it would be like those on engine cases. They look that way with the ring around the number because they where an insert. It was fitted to the die so as they could change the date etc.
As for the 50 case yes I do. But I did speak to someone whom may be interested that had a kubel as they didn't have and engine yet. |
Posted: Sun Jan 05, 2014 2:23 am Post subject: |
Lifted shell off my 11G, quite relieved floorpan looks pretty good, wanted to check if anyone knows about gearbox numbers to date the gearbox and also if I should have lever shocks instead of telescopic (on old question but still unsure) - thanks!
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Sun Jan 05, 2014 3:10 am Post subject: |
Those are casting numbers and part numbers you've shown there; the should be a serial number which I think should be on top of the bell housing near where it mates with the engine. It should tally up with column three here - rear axle number:
http://www.thesamba.com/vw/archives/info/bugchassisdating.php
I'm not sure on the lever/hydraulic shock question although I know some 51s had hydraulic shocks.
Cheers,
Dave |
bally Samba Member
Posted: Thu Jan 09, 2014 6:39 pm Post subject: |
Anyone seen these plates that modify lever shocks to telescopic, is it something cool to keep or return to lever shocks which leads to next question where to buy lever shocks?
Posted: Sat Jan 11, 2014 4:35 am Post subject: |
Thanks Bally, seems slightly later than body and pan, but got bigger items to work on!
Posted: Sun May 11, 2014 3:16 am Post subject: 25hp Engine rebuild |
Hi Guys,
Engine tear down begins, as many previous posts whats authentic and what not.
Block has no number and seems later cast date but most other bits seems genuine including dead rodent in head and wasp nest in exhaust manifold.
Grateful for any advice / comments;
Posted: Sun May 11, 2014 3:19 am Post subject: |
The bubbles are vinegar on block to test for magnesium - is this conclusive or note... |
splitjunkie Samba Member
Posted: Sun May 11, 2014 6:45 am Post subject: |
Definitely a later replacement case. the coil and the regulator (maybe) are later as well, but everything else looks correct. _________________ Chris
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Sun May 11, 2014 9:05 am Post subject: Re: 25hp Engine rebuild |
roymartian wrote: |
Hi Guys,
I'm sorry to inform you the dead rodent head and wasp nest are not original.
I have owned a few very nice original engines and these parts were not present.
What is that the date stamp on the coil? Maybe 2L? I cannot read it.
The date-stamped thermostat is neat - I have not seen a date stamp there before. _________________ How to Post Photos
