roymartian Samba Member
Posted: Mon May 12, 2014 1:50 am Post subject: |
Not sure age, screw terminals |
splitjunkie Samba Member
Posted: Mon May 12, 2014 8:14 am Post subject: |
The bracket on that coil is a generic replacement and not a VW part. Makes me suspect of the coil. Can you post a picture of the other end with the terminals? _________________ Chris
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Mon May 12, 2014 9:13 am Post subject: |
splitjunkie wrote: |
Definitely a later replacement case. the coil and the regulator (maybe) are later as well, but everything else looks correct. |
Regulator should have a date code too.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Mon May 12, 2014 7:11 pm Post subject: |
Thanks Everett |
Posted: Thu May 22, 2014 7:47 pm Post subject: |
Anybody know of a short block rebuild post for 25hp, rebuilt a 36hp but need some guidance older engine...hoping to start this weekend |
Posted: Sat Aug 02, 2014 12:33 am Post subject: RHD Pedals |
Hi,
Looking for some advice please to add RHD pedals, my existing floor pan although original has had later pan halves welded in so looking to restore.
Images show my existing pan old LHD pedals and RHD pedals I picked up today.
1. Does anyone have details of RHD pan and mountings?
2. Are these repair panels available, ideally not full halves?
3. Does anyone have details on RHD pedals?
4. Any ideas for where to source some RHD pedal bits I am missing?
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Sat Aug 02, 2014 5:44 pm Post subject: |
those pedals will bolt to the pan mounts in your car, but they are 58-66 pedals (as is the pan section. edit the pan might be 67 or later???).
below are oval pedals and pan section. (ex 56/7 in this case) so will be closer to looking "correct"
Posted: Sat Aug 02, 2014 6:35 pm Post subject: |
Great thanks for advice - you don't have those bit for sale any chance ? |
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Sun Aug 03, 2014 3:16 am Post subject: |
henry roberts wrote: |
What are the two pairs of captive nuts for? Is one for the pedal assembly and one for the stop or are they both for the pedal assembly?
Do you have the dimensions for the plate welded under the floor please?
Cheers,
Dave |
Posted: Sun Aug 03, 2014 5:13 pm Post subject: |
the outer pair of bolts takes the pedal mount bracket and the brake pedal stop plate and the inner pair just the clutch stop plate.
i'll get you the dimensions and edit the post. |
bally Samba Member
Posted: Sun Aug 03, 2014 11:51 pm Post subject: |
Cool, thanks very much
Dave |
Posted: Wed Aug 06, 2014 7:31 pm Post subject: |
sorry that took so long. I hope you can read my awful dimensioning.
all measurements are only approximate, I was trying to measure a plate under a car. please check the dimensions against your pedals before welding everything together.
i think the plate is 1.5mm thick. sorry my callipers are elsewhere so I couldn't get a 100% accurate measurement.
the weld nuts are 14mm square nuts. measurements are to the bolt centre line, I kept getting 19mm as the spacing of the weld nut c/l to the edge of the plate, but the dimensions don't add up hence I didn't add it to the drawing. I think it should be 18.5mm.
the lip depth is from the pan to the bottom lip of the plate.
the plate locating dimensions are to the edge of the tunnel bottom plate and the edge of the front cross member bottom plate.
roger, I haven't forgotten you, pics on their way soon.
D-train Samba Member
Posted: Thu Aug 07, 2014 3:39 am Post subject: |
thanks for those dimensions henry, i needed those for my spare set to make the plate up. _________________ shiny paint doesnt make it worth any more |
Posted: Thu Sep 04, 2014 2:14 am Post subject: Pedal renovation |
Hi,
Managed to get my RHD pedals (thanks Bug boy), they're appear to be in good solid condition but wanted to check;
1. How to evaluate pedal condition / slop and recommended renovation work / techniques ?
2. Best way to achieve authentic paint finish ?
Was hoping to wire brush and paint but really want to be sure all working well.
Thanks,
parmaynu Samba Member
Joined: March 29, 2004 Posts: 182 Location: Kent, England
Posted: Tue Apr 25, 2017 2:11 pm Post subject: Re: 11G Project |
Old post I know but do you know the bolt size for those weldnuts? |
