VWDog Samba Member
Joined: June 24, 2005 Posts: 617 Location: Ladysmith, BC
Posted: Sun Aug 18, 2013 12:01 pm Post subject: Brasilia Information |
Hello,
I am looking into buying a Brasilia. I live in Canada where they were never imported. I am having trouble finding information on the mechanical parts used. I am hoping someone might be able to help me out.
For example:
What kind of beam does it use?
Is it like a type 1 in the rear?
Are the shift rod linkages special to the Brasilia or do they use Beetle mechanicals?
Are there other specialties that I should be aware of?
Thanks very much for any light anyone might be able to shed on the Brasilia model.
Cheers,
Don |
igtoth Samba Member
Joined: May 09, 2006 Posts: 385 Location: Ribeirão Preto, SP, Brazil
Posted: Sun Aug 18, 2013 2:47 pm Post subject: |
If you want to import a Brasilia I can help to find one for you |
VWDog Samba Member
Posted: Sun Aug 18, 2013 3:14 pm Post subject: |
I actually know where one is, but don't know if it is a good idea to buy it or not, considering the parts and service manual availability.
Do you sell parts etc? |
igtoth Samba Member
Posted: Sun Aug 18, 2013 6:47 pm Post subject: |
VWDog wrote: |
Its pretty much a BUG in a square shell from mechanical perspective I mean... |
tecnica Samba Member
Joined: March 25, 2014 Posts: 7 Location: São Paulo - Brazil
Posted: Tue Mar 25, 2014 12:34 pm Post subject: Re: Brasilia Information |
Hi,
A bit delayed response, I guess.... but let´s go
VWDog wrote: |
The Brasilia uses two pair of non sealed 5" beans. The outside bean has a little 5W park lamp in a separated socket. The bulb are P45T ones (40/45W)
VWDog wrote: |
Yep, but the torsion bars are longer, because of larger floor pan. The Z bar is a bit diferent than Typ 1. All Brasilias are swing axle.
VWDog wrote: |
No, same of the beetle.
VWDog wrote: |
No, the Beetle and Brasilia are very similar. Only the oil level stick are diferent: in the Brasilia the oil level stick is in the body, at the botton of rear lid frame. There is a rubber hose inside the engine trunk to protect it.
best regards |
zombn8r Samba Member
Joined: July 25, 2013 Posts: 31 Location: Atlanta, GA
wbrown45 Samba Member
Posted: Sat Jun 28, 2014 9:19 am Post subject: Re: Brasilia Information |
[quote="tecnica"]Hi,
VWDog wrote: |
I believe he actually was referring to the front suspension beam (torsion tube housing). I love the look of those 5" headlights though. _________________ OK Thang |
VWDog Samba Member
Posted: Sat Jun 28, 2014 10:26 am Post subject: Re: Brasilia Information |
[quote="wbrown45"]
tecnica wrote: |
Hi,
VWDog wrote: |
I believe he actually was referring to the front suspension beam (torsion tube housing). I love the look of those 5" headlights though. |
You are correct wbrown45. I am still strangely attracted to these cars, but will probably never own one now. As they say though, "never say never" .
Thanks for the info from all above. _________________
1970 Lotus White Single Cab 2015- , 1979 Sage Green 2014-2015, 1978 Dakota Beige Westy 2012-2015, 1978 Neptune Blue Riviera 2012-2017 , 1970 Neptune Blue Bus 2010-2012, 1970 Deluxe Savannah Beige 2010-2012, 1985 Iltis 2010- , 1962 Single Cab 2010-2013, 1975 Brasilia? Bay/Split Kombi from Brazil 2008-2011, 1985 DoKa 1999-2009, 1971 Bus 1999-2000, 1968 Double Cab 1991-1998, 1965 Ghia 1987-1991, 1970 Westfalia-bought by Mum and Dad in 1970, sold by me in 1993 why-oh-why :_(
