modok Samba Member
Posted: Fri Aug 23, 2013 9:31 pm Post subject: Sedan tri-y header |
while car was on stands, I took some pictures for you |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Fri Aug 23, 2013 9:52 pm Post subject: |
Did you make that? Can you explain the advantages? What size tubing? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
ralf Samba Member
Posted: Fri Aug 23, 2013 10:04 pm Post subject: |
awesome work man...
clever lay out. its always hard to figure out a "lay out" with that kind of pairing
bugguy1967, the pairing is to equally space each cylinder in accordance to firing order/rotation _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
modok Samba Member
Posted: Fri Aug 23, 2013 10:40 pm Post subject: |
Short story is I "re-discovered" the tri-y several years ago. I built one in a "baha" layout and tried a dozen or so small design changes, figured out somewhat how it tunes and so forth.
Then figured out this layout that fits behind the apron. I built the muffler also. It sounds like vintage porsche guys wish they sounded
Some parts are plain, some were ceramic coated, and some are aluminumized. It's clear which one is proving more durable |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Fri Aug 23, 2013 10:41 pm Post subject: |
ralf wrote: |
bugguy1967, the pairing is to equally space each cylinder in accordance to firing order/rotation |
Absolutely correct. The goal is to have each cylinder exhaust pulse enter the first Y in the low pressure between the pulses from the opposing cylinder to help flow. The pipes need to be equal length and connect cylinders that are 180 degrees opposed, which is what we have here. I did testing on a tri-Y header two years ago, and it took 0.4 seconds of my time at the dragstrip with no other changes. Nice improvement in low end torque as well. This was on a 200 hp naturally aspirated engine.
Paul |
Altema Samba Member
Posted: Fri Aug 23, 2013 10:47 pm Post subject: |
modok wrote: |
I don't have enough engine for pipes that big, but it would sure be nice to try something smaller. Bet it sounds awesome. Does anyone make a commercial tri-Y?
Paul |
modok Samba Member
Posted: Fri Aug 23, 2013 10:52 pm Post subject: |
it is only a 2007cc. 1.5 primaries and 1.75 secondaries.
Tangerine racing's one for the 356 and Tencentlife's vanagon tri-y are the only "commercial" systems I am aware of that have any resemblance
(that is, they fit the type-1 port layout). My tube layout is unique. It's kind of like a "45 winder". I found merging the primaries at about 45 degrees, and then turning another 45 in the secondaries was the only way to keep it behind the apron. The bend under the oil filter then must be extra tight, but one tight bend is a small price to pay.
This would work for more conventional four into one headers also, to allow shorter primary tube lengths than the sidewinder designs. |
Posted: Sat Aug 24, 2013 7:38 am Post subject: |
I never understood how header fabricators make equal length tubing without wasting a lot of material to get it right.
Do you pre-measure the first pipe before you bend, and then make the rest work at that same length?
I'd need a mile of tubing before I got one right myself. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Sat Aug 24, 2013 8:32 am Post subject: |
modok wrote: |
And the answer is???
Btw, pretty cool, Glen! Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
juki48 Samba Member
Joined: March 07, 2007 Posts: 602 Location: Upstate NY
Posted: Sat Aug 24, 2013 8:35 am Post subject: |
Glad I'm not the only one...
jhoefer Samba Member
Posted: Sat Aug 24, 2013 9:08 am Post subject: |
bugguy1967 wrote: |
I'd need a mile of tubing before I got one right myself. |
You could use ICEengineworks exhaust header modeling blocks now. It's a kit of plastic sections you snap together to mock up a header. But $750 is kind of expensive if you only do a single exhaust. You can waste a lot of pipe for that, but it'd save a lot of time. |
58 Plastic Tub Samba Member
Joined: September 03, 2007 Posts: 419 Location: Nowhere, USA
Posted: Sat Aug 24, 2013 12:08 pm Post subject: |
Glen-
I've been waiting for years for somebody to do this. Want to make me one? _________________ Stan Galat
"A single point in isolation is a reference point. Two points is a line. Three points is a trend. Trends don't lie." |
Howard 111 Samba Member
Posted: Sat Aug 24, 2013 1:30 pm Post subject: |
Watch that "only a 2007" Glen. That's what I run.
Nicely designed!
youngnstudly Samba Member
Joined: October 21, 2005 Posts: 833 Location: Whine Country (SF Bay area)
Posted: Sat Aug 24, 2013 1:38 pm Post subject: |
Tell us more about the muffler (if you don't mind). I'm just as curious about that as I am the rest of the setup! _________________ The economy is in a state of disaster, we have NO time for common sense! |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Sat Aug 24, 2013 2:05 pm Post subject: |
Carb bump? There's only one...
Would love to hear how that sounds, and I'm really thinking about a tri-y for the 2276 since you've been posting about them. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
juki48 Samba Member
Posted: Sat Aug 24, 2013 2:07 pm Post subject: |
x2 I was just thinking the same thing, would love to hear it! |
ralf Samba Member
Posted: Sat Aug 24, 2013 2:08 pm Post subject: |
the other cool thing about is is
an oilsump would fit and it doesnt look to be hampering ground clearance at all _________________ Flow Through a Curved Conduit
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat Aug 24, 2013 3:18 pm Post subject: |
I've installed tri-y headers on other engines, and the improved performance was extremely noticeable. Especially so with the Toyota 2f engine. I've been waiting to see one for an aircooled VW. Very, very nice work Glenn. |
modok Samba Member
Posted: Sat Aug 24, 2013 3:31 pm Post subject: |
Exactly. I had a merged bugpack header on this car for two years with a hideaway muffler, and the darn thing scraped on the ground all the time and really cramped my style.
This setup has not hit the ground yet! And adding the 26mm torsion bars has really transformed it too! I should have done that from the start!
The bulge in the decklid is to clear the aircleaner, I am using the CB big beef manifolds and they do not have any offset, so only the right side needs a bump. |
modok Samba Member
Posted: Sat Aug 24, 2013 4:01 pm Post subject: |
This week I will try to get my buddy to lend me a nice microphone to do a proper recording of the sound.
The muffler is very simple, inside is divided into three chambers. The tailpipe tube is 2" and perforated with 1/4 holes..... a lot of them, I forget how many but more than the area of the tube, and this runs through all three chambers.
The inlet runs through the first chamber as a perforated tube, then ends in the second, and there is a hole in front of it into the third chamber, (exactly like a flo-pro muffler).
I had a magnaflow glasspack on it at first but it had some VERY bad droning, enough that it actually upset the tuning |
