modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Aug 24, 2013 4:09 pm Post subject: |
bugguy1967 wrote: |
I never understood how header fabricators make equal length tubing without wasting a lot of material to get it right.
Do you pre-measure the first pipe before you bend, and then make the rest work at that same length?
I'd need a mile of tubing before I got one right myself. |
The tube lengths are probably within 2", the overall proportions are more important than exact lengths.
I just try to get as close to the "ideal" lengths as possible.
Yes, there are probably 3 times as many welds in this as a mass produced header.
The gentle bends are aluminized muffler tubing, those are the parts that don't have rust. I would like to find a supplier of aluminized J bends. |
modok Samba Member
Posted: Sat Aug 24, 2013 4:49 pm Post subject: |
58 Plastic Tub wrote: |
Glen-
I've been waiting for years for somebody to do this. Want to make me one? |
Thank you. I'd like to make a few headers for others, and hopefully in time I will be able to do so.
I will need to do some more research and make and buy more tools before I would feel confident about the level of workmanship and durability. |
ralf Samba Member
Posted: Sat Aug 24, 2013 4:57 pm Post subject: |
modok wrote: |
Glen-
better be quick bfor it starts coming from china LOL
keep a tab on who you make them for... so u can be aware of wh sent it to a manufacturer haahah just for fun _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
modok Samba Member
Posted: Sat Aug 24, 2013 5:10 pm Post subject: |
Shoot man, if china wants to make them then that's fine. I'd buy one
Did you see the tiawan attempt at a new performance design? utter baloney it was, but well constructed. The design is FREE to anybody who wants to construct it.
DIDya hear that VINTAGE SPEED OF TAIWAN? |
ralf Samba Member
Posted: Sat Aug 24, 2013 5:53 pm Post subject: |
i stil like the fact that
this lay out is "new"
the pairing ofcourse is.. ideal and
you mention tangerine has done the pairing
alot of others in europe too like remelle etc
but the lay out you did.. kind of works well as far as ground clearance goes
plus you can prolly run one of those sidewinder mufflers
if you put a merge 2-1 prior to the muffler
so it needs 1 inlete 1 outlet muffler _________________ Flow Through a Curved Conduit
modok Samba Member
Posted: Sat Aug 24, 2013 6:19 pm Post subject: |
The secondaries do merge together as they enter the muffler, it just doesn't look like it from the outside. That is the third muffler to be grafted on, so that area of the header isn't as "cleanly constructed" as it could be.
Even if I do discover good performance with a glasspack, I'd rather have a chamber type muffler.
Lower frequencies are generally perceived by people and animals to be more "threatening" than higher frequencies. There are a lot of reasons for that.
So you dampen the low frequencies and then your neighbors say it sounds good instead of "too loud", even though it's just as loud. |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Sat Aug 24, 2013 10:53 pm Post subject: |
You want to make a 1 5/8 header for me? I'll buy and test for ya? _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
modok Samba Member
Posted: Sat Aug 24, 2013 11:20 pm Post subject: |
Hmm, well I do have some idea of what would suit your "149HP" engine
If I do get geared up to make a few, you'll be on the short list, but for now I cannot make any promises. |
ralf Samba Member
Posted: Sat Aug 24, 2013 11:28 pm Post subject: |
modok wrote: |
yes i figured the merge is inside the muffler
but wat i meant is.. if it merged bfor the muffler, then "changing" mufflers would be easy with alot of choices as far as 1inlet 1 outlet goes,
even chambered
could even use the short f10 or v10 muffler its called by magnaflow? i think..
the juice can looking one, for the racer guys who want the noise hahaha _________________ Flow Through a Curved Conduit
ralf Samba Member
Posted: Sat Aug 24, 2013 11:30 pm Post subject: |
modok wrote: |
hahahaha the 150hp will never exist as its now
the "149hp" maybe the header can give it atleast 2hp boost..
to reach the 151 mark _________________ Flow Through a Curved Conduit
modok Samba Member
Posted: Sat Aug 24, 2013 11:34 pm Post subject: |
It would be "nice if"
If the bumper mounting area is cut out of the car it would allow the pipes going into the muffler to be higher, and therefore much easier to use a more common muffler, but I wasn't willing to do that.
But your right it could be done. |
Posted: Sat Aug 24, 2013 11:58 pm Post subject: |
modok wrote: |
Hahahaha....yeah....149......I'm sure it will be past that mark by enough......either way...150 hp in a light weight, low geared vs is plenty.....umm, I mean 149. By the time my parts get here ill have finally pulled the trigger on a cam. I've come to the conclusion that the E120 is too small for what I want........Engle 125 or FK10. Hey, at least its narrowed down to two! _________________ Good things come to those who wait.
4340 84mm crank
AA 94mm p&c' s
5.5 h beams
CB 1.4 rockers
NGK D7ea plugs
donnmon Samba Member
Posted: Mon Aug 26, 2013 1:38 pm Post subject: |
tri y so far.
primaries 32inches 38mm tube
secondary's 20 inches 42mm tube
these lengths include the merges. does the tertiary length matter?
the whole thing has taken about two days to construct so far but the layout took about another half a day to work out.
if it helps anyone else to work out their layout we did this with 6mm rod and reference the radius stated by the mandrel bends we were using, this gave us a centreline map which it turned out was pretty accurate. it saved a lot of time and pipe.
most of the work however was done by Glen because he put the time into the R & D. Many thanks once again.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Aug 26, 2013 4:36 pm Post subject: |
Looks nice, but can ya do it with heat? |
modok Samba Member
Posted: Mon Aug 26, 2013 4:39 pm Post subject: |
WOW, awesome buddy!
The tertiary length doesn't seem to be critical. I found computer simulation indicates 200mm may be good, and 800mm or longer may be good(in both cases it theoretically widened the rpm range a slight amount)......but it is only a small change, and in real life I haven't found any big difference.
I DID find that it likes to be large diameter. I did not find ANY advantage going smaller than 2" in any point between the secondaries and the volume of the muffler.
2.125 might be the perfect size, but it's either 2 or 2.25 in inch tubing..... so I preferred 2.25
Is there a better selection of sizes in metric tubing?
That layout with wire sounds like a good idea. I just lay it out by imagination and with scraps of old headers. It this point I have a LOT of scrap tube. i
tncsparky Samba Member
Joined: November 29, 2008 Posts: 703 Location: santa rosa
Posted: Mon Aug 26, 2013 8:01 pm Post subject: |
You can get a bunch of different bends from Summitracing.com _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself |
modok Samba Member
Posted: Mon Aug 26, 2013 8:07 pm Post subject: |
I've found everything except tight radius aluminumized, and a 1.5" expander.
It could be that the aluminum flakes off if bent too tight, that would explain it, which is too bad. |
tencentlife Samba Member
Posted: Tue Aug 27, 2013 7:00 am Post subject: |
Nice job, Glen! _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Wed Aug 28, 2013 7:31 am Post subject: |
modok wrote: |
Yeah I think that we are lucky enough to be on bridge between the world of imperial and metric measurements so we can can get both 2.125 and 2.25 inch pipe. Having said that, 2.125 inches is the ID of 57mm (2.24 inch) pipe, so I am not sure whether your 2.25 inch (57.15mm) pipe actually is an OD or ID measurment.
If you ever need some 2.125 ID pipe or bends let me know. |
Posted: Wed Aug 28, 2013 8:22 am Post subject: |
It's not pipe, it's tubing, and in the US at least, tubing is always measured on the OD. Pipe is on the ID. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
