Merlin 53 Tabacco Samba Member
Joined: June 09, 2010 Posts: 13 Location: farmington hills, MI
Posted: Mon Aug 26, 2013 7:27 am Post subject: What year is my transmission? |
the numbers and letters stamped on the case are.
AH1901271 |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Mon Aug 26, 2013 3:49 pm Post subject: |
If it has the floppy style throw out bearing it is a 69-70. If it has the guide tube sleeve for the throw out bearing it is a 71-72. They both have the same gears inside. 4.12 R&P with 3.80/2.06/1.26/.89 gears _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Mon Aug 26, 2013 4:03 pm Post subject: |
You wouldn't happen to know the gears in a 1968 type 1, would you? _________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Posted: Mon Aug 26, 2013 4:57 pm Post subject: |
67-68 swingaxle had the same R&P and gears as the 69-72 IRS. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Mon Aug 26, 2013 5:12 pm Post subject: |
i broke the arm for the throwout bearing, its the bearing that goes with the pressure plate with the ring on the spring plates |
GA_Boy Samba Member
Joined: October 10, 2006 Posts: 1405 Location: Jefferson, GA
Posted: Mon Aug 26, 2013 5:50 pm Post subject: |
vwracerdave. I have a '67 and thought the R&P was 4.375 based on an earlier test of (I have forgotten exactly how to do.) jacking one rear wheel off the ground and rotating other tire in 2nd gear or something like that. Can anyone give me the exact procedure? Now I'm not sure if I have a 4.375 or a 4.12 R&P.
Thanks, Marvin |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Mon Aug 26, 2013 5:56 pm Post subject: |
Typically 67-72 ran 4.12 r/p. Almost all were 3.8,2.06,1.26,.89 stacks. Late 71 and 72 had fine tooth gears on 3-4 _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
GA_Boy Samba Member
Posted: Tue Aug 27, 2013 12:04 pm Post subject: |
GA_Boy wrote: |
Thanks, Marvin |
Finally found it: SEE BELOW
Marvin
Bruce wrote:
mrblyoung wrote:
so how exactly can i tell which ratio transmission i have?
A way to determine your gearing is to jack up the rear of the car so that both rear tires are off the ground. E-brake off, shifter in 2nd gear. Turn one tire so the valve stem is at the top. Now turn the engine over by hand, counting engine turns needed to get one turn of the tire.
9 turns = 4.37
8½ turns = 4.12
8 turns = 3.88 |
Posted: Tue Aug 27, 2013 12:31 pm Post subject: |
If your ah code trans has not been effed with it has a 4.12 r/p, they all do, also they are all gleason r/p's _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Bruce Samba Member
Posted: Tue Aug 27, 2013 8:50 pm Post subject: |
mcmscott wrote: |
If your ah code trans has not been effed with it has a 4.12 r/p, they all do, also they are all gleason r/p's |
Not all are G types. When VW ran out of Gs, they substituted Ks. I know a guy who found a K type 4.12 inside the original untouched gearbox from a 1970. _________________
clooney Samba Member
Posted: Tue Feb 14, 2017 5:58 pm Post subject: Re: What year is my transmission? |
does anyone know if the AH gearbox comes with 15T or 17T type reverse gear? |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Tue Feb 14, 2017 6:24 pm Post subject: Re: What year is my transmission? |
From the factory, they had the 17 tooth ones with the round shoulders. |
Posted: Tue Feb 14, 2017 6:46 pm Post subject: Re: What year is my transmission? |
[email protected] wrote: |
thanks! |
Posted: Tue Feb 14, 2017 7:21 pm Post subject: Re: What year is my transmission? |
That one's kind of a hybrid of the design of the late 15 tooth gear that uses the paddle to shift it, but has 17 teeth instead. This is more like what would have come in an AH trans.
https://weddleindustries.com/products/1000155/1001717
There is a style with a couple little lines cut into the edges of the teeth, and one without lines. You need to have a match to what you're replacing, or mating up to the slider being used. |
Bruce Samba Member
Posted: Sat Feb 18, 2017 4:56 pm Post subject: Re: What year is my transmission? |
clooney wrote: |
The overwhelming majority had a 17 tooth reverse idler. But a rare number had 15 tooth idlers. _________________
mark tucker Samba Member
Posted: Sat Feb 18, 2017 6:45 pm Post subject: Re: What year is my transmission? |
my 73 box had the 15 and the 74 year box had the 17.both 388,one K one G. one .87 4th 1 was.93 the 73 year was ssc and the 74 date code was duel side cover. I think vw was just having fun building and grabing whatever they wanted to stick togeather that day for whatever model car they were building for. and when somebody has been in it you just never know what you might find. if you have to have the right one for a "quick" job...better get both gears...and the reverse gears on the input shaft can be diferent too that one threw me fer a loop for a little bit.and the other reverse gear too...there sure is a lot of reverse gears&stuff in these trans... |
Bruce Samba Member
Posted: Sat Feb 18, 2017 7:37 pm Post subject: Re: What year is my transmission? |
mark tucker wrote: |
.... and the 74 year box had the 17..... and the 74 date code was duel side cover. ... |
What you had was a gearbox assembled by someone that was NOT VW.
If this trans was IRS, it started out from VW as a swing axle. _________________
Posted: Sat Feb 18, 2017 11:08 pm Post subject: Re: What year is my transmission? |
the codes said diferent. I think they may of been in the use up old stock mode. |
Bruce Samba Member
Posted: Sun Feb 19, 2017 3:15 pm Post subject: Re: What year is my transmission? |
When a car company is manufacturing 4000 cars per day, there's no such thing as "using up old stock".
Unless you have direct knowledge of the entire history of that gearbox, you're just guessing. Transmissions get rebuilt to a different configuration every day by the large trans builders. Yesterday I was getting started on two gearboxes for a 64 and a 66 swing axle Bus. Both gearbox codes said Type 3 IRS! _________________
