Goldbug3318 Samba Member
Joined: September 06, 2014 Posts: 210 Location: Jacksonville, FL
Posted: Sun Sep 07, 2014 11:07 am Post subject: |
What a great build!!! Car is looking amazing!!! |
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
Posted: Sun Sep 07, 2014 3:23 pm Post subject: |
Time to work under the hood. Up first was the brake reservoir lines.
I drained the excess brake fluid into a jar since the brake reservoir was installed down on the master cylinder and had to be moved. Then I installed the correct Blue brake hoses. I first placed the hard lines in the correct place and measured how long the hoses needed to be, and then cut them to length. I also put a little blue hose (about 1/4' long ) where the hard pipes go through the body to stop chaffing.
I then added a few zip ties (in blue of course) to tidy it all up and stop them vibrating:
Then it was time to install the hood. Wanted to get the hood out of the house and onto the Bug before it got scratched in the house.
I installed the seal first. I rubbed some WD40 onto the channel and seal and pushed the seal into the channel. It's a little fiddly, but pushing it in means you won't scratch the paint:
I trimmed the seal in the middle to fit together nicely:
Then I got an old comforter and put it on the body to stop it being scratched ad I lifted up the Hood. I got my wife to help me, which also minimizes the risk of scratching the hood or body:
I started with one side first and tightened the bolts up snug then moved to the other side and did the same.
Yay, the Hoods on without a scratch!!!
Need to square it up next weekend.
_________________ My 1974 Standard Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=568220&postdays=0&postorder=asc&start=0
My Son's 1971 Bay Window Westie Build Thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7295189#7295189 |
Posted: Mon Sep 08, 2014 4:21 pm Post subject: |
Started to assemble the rear today.
Started with the decklid, first I put the spring on, then I covered the rear of the Bug with blankets to stop the paint getting scratched.
I then lifted up the deck lid and screwed in one decklid bolt on one side. Then I connected the deck lid spring and attached it to the body. After that I "walked the decklid" onto the car by rotating it onto the car, then fixed the second bolt. I followed up with the other two bolts, and aligned the decklid and snugged down the bolts:
Here's the spring orientation:
Decklid is one:
Then I attached the decklid thermostat vent that sits under the license plate:
(I now know the thermostat is orientated incorrectly, I'll be fixing that later this week):
I then attached the license plate light housing, note I added some shrink wrap to the wires to make it neater:
Then fixed that to the decklid with a new seal:
Then my first rear fender was fitted:
Then finally the new smoked light housing (under the new light, is an OEM light bucket with the original seals, it now fits really well to the fender):
There's less and less parts on the shelf _________________ My 1974 Standard Build Thread:
Last edited by peteandvanessa on Tue Sep 09, 2014 7:23 am; edited 1 time in total |
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
Posted: Tue Sep 09, 2014 7:20 am Post subject: |
This is looking great! _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Posted: Tue Sep 09, 2014 4:13 pm Post subject: |
Just a few Minor odds and ends.
Got the last front fender mounted. Both front fenders are replacement aftermarket. The fit is pretty good and they are also pretty solid. Strangely one fender had a hole missing for the turn signal, but the other didn't.
I just had to drill it out. The headlight buckets are also pretty good in the fender. My original headlights screwed right in:
Sorted the error in my decklid thermostat. Had to take it a part and reassembly it correctly. Here's the correct orientation:
When the engine compartment gets hot, it opens up the flaps behind the license plate to let the heat out:
Got the front bumper shocks mounted:
Finally I got the Hood latch release fitted with new stainless steel fasteners.In fact, almost all of my fasteners are stainless, there are expensive, but look good.
The hood release should be riveted, but I don't have a rivet gun (and I'm not buying one for a few rivets ):
Last edited by peteandvanessa on Wed Sep 10, 2014 4:41 pm; edited 2 times in total |
Her74buggy Samba Member
Joined: September 29, 2013 Posts: 367 Location: Houston
Posted: Tue Sep 09, 2014 4:36 pm Post subject: |
Your build looks great! Amazing and inspiring work! I love how the grey in the smoked rear lights picks up on the grey/silver paint on the sides. Have you thought about smoked front turn signals to tie it together? Just a thought. Keep up the great work. Can't wait to see the pics as you keep putting them up. Thanks for sharing. That first drive is going to be awesome! |
Posted: Tue Sep 09, 2014 5:40 pm Post subject: |
Her74buggy wrote: |
Funny you should mention that, I'm still thinking about fitting smoked turn signals to tie it together. I've only held off since I haven't looked for smoked turn signals yet.
I'm going to start wiring soon (have to get the glass in first though). I'm going to try and document the wiring in more detail since very few threads actually show the re-wiring and I think it deserves a few pics. _________________ My 1974 Standard Build Thread:
talljordan Samba Member
Joined: January 10, 2012 Posts: 968 Location: San Francisco, CA
Posted: Tue Sep 09, 2014 10:57 pm Post subject: |
A lot of tools shops might let you borrow a rivet gun for an afternoon. I would look around. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
99XC600 Samba Member
Joined: August 25, 2014 Posts: 3 Location: United States
Posted: Wed Sep 10, 2014 11:17 am Post subject: |
Amazing work. Just subscribed to the thread. |
ShooterM83 Samba Member
Joined: September 10, 2014 Posts: 1 Location: Navarre, FL
Posted: Wed Sep 10, 2014 12:28 pm Post subject: |
Incredible build! I've got to ask. Where did you get the blue tubes that fit over the brake lines as they move through the body? |
OzzyTR Samba Member
Posted: Wed Sep 10, 2014 3:33 pm Post subject: |
is that flappy-thing on engine cover custom made or can we find it in common dealers ? I'd love to have that on my car, too. |
Posted: Wed Sep 10, 2014 3:37 pm Post subject: |
Time to install the Bumper.
I looked all over the place for a good used bumper, I pulled this bad boy off a 1974 Bug in pick n pull sometime ago. I cleaned it up and now it's ready to fit.
Install your bumper shock first, but leave them a little loose for now.
I found it easier to install the bumper brackets first (note how the bumper brackets "grip" the bumper):
AND ALSO NOTE:
The Bumper has a number of holes to mount the bracket, mount it using the INNER hole pair, rather than the OUTER hole pair, otherwise you will be re-doing it later (ask me how I know )
Then slide one end on first and add the bumper bracket bolt, washer and nut, just leave it a little loose for now.
Here's the bumper installed:
I then installed the bumper overriders, bumper strip and the license plate bracket. The bracket, I also pulled from the 74 Bug in pick n pull then cleaned it up and painted it:
Here's a side shot of the Bumper end pieces, these are reproduction, but they fit really well. Some say that the repro Bumper end pieces don't fit well, but mine did, maybe I got lucky
Now square everything up and make sure the Bumper is level, then snug up all the bolts and brackets.
The front Bumper is done! _________________ My 1974 Standard Build Thread:
Last edited by peteandvanessa on Wed Sep 10, 2014 4:45 pm; edited 1 time in total |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Wed Sep 10, 2014 7:50 pm Post subject: |
My 76 bug front & rear bumpers had a total of 4, square rubber pads with a hole in the center for the mounting screws that go between the bumper & the bumpers mounts? Is that oem thing on the 74-79 cars? Does anyone still use them on their bumpers
_________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
Posted: Thu Sep 11, 2014 4:25 pm Post subject: |
Got the final rear fender mounted today. Another good fit, should be, since this is the original fender to the car.
After mounting the fender, it was time to fit the final rear light, so I took a few quick pics.
Here's the fender mounted:
Here's the after market light, and on the left, the backing plate from an original rear light:
The backing plate goes on first, then the aftermarket light:
Here's the finished light with the lense fitted:
Time, now to mount the rear bumper. Again, I rescued this from a 1974 Bug, this time I purchased it from someone at Bugorama in May of this year. Pretty good for an original.
Same as the front Bumper, mount the brackets first onto the Bumper shocks:
Then just do the same as the front, square and level it all up, then snug everything down:
Given that I'm originally from the UK, I had to add the "GB" marker plate. My wife bought me this last year for Xmas. Feels good to be able to finally fit it to the car:
tsfireman49 Samba Member
Posted: Sat Sep 13, 2014 9:59 am Post subject: Your turn signals |
Where did you find the clear glass turn signals? I am looking for a set to install my fire department strobe lights. Thank you for any help you can offer. |
