ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Wed Apr 16, 2014 1:55 pm Post subject: |
I'd venture to guess one way to do it is smaller tire in back, larger tire up front... |
TommyBoyGomes Samba Member
Joined: May 28, 2005 Posts: 1531 Location: L.A./Dublin, Irl
Posted: Wed Apr 16, 2014 2:03 pm Post subject: |
Is your radio wired through your tach?
Jk, looks like someone got lazy with your radio and didn't wire it in through the ignition. That's the right way to do it. But if you want to remain lazy, just add a $1 switch in-line on the 12V lead between the radio and the battery (a single-pole single-throw switch should do). This means that you'll need to flick the switch every time you want to turn on the radio, but it's easy to mount it beneath the dash in an accessible spot. _________________ 1969 Squareback, 1776cc
1990 Vanagon Multivan |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Wed Apr 16, 2014 2:39 pm Post subject: |
WD-40 works nicely for removing old sticker goo. |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Wed Apr 16, 2014 8:35 pm Post subject: |
You can use acetone. It wont harm the paint. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Thu Apr 17, 2014 7:04 am Post subject: |
OhHerrooo wrote: |
also, I really want to level out my car by lowering the back but my 205/65 tires seem to be contributing to my stink-bugedness. would a smaller tire help with this? also, since the car is IRS i can't go short axle, can i? what is the best way to lower the rear and even it out? the tires are very close to rubbing the inner fender lip.
You could probably drop the rear 1 spline, and be ok. I think it'll allow the top of the tire to come in about a 1/2 inch with IRS. My 71 tucks the 205-65 nicely with a 1 spline drop.
The front looks like it's on a narrowed bug beam (or you've got some narrowed arms), as the fronts look tucked in pretty good. Those look like some 175-55's or something. You can go up on them to something like a 185-65, or even a 195-60 to help fill in the wheel well.
Carb cleaner will soften the glue from the stickers too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1423 Location: Toronto, Ontario. Canada
Posted: Thu Apr 17, 2014 7:54 am Post subject: |
you will need to change tires to lower the rear if the tires are close now, or change rims with different offset. Then lower rear down. With an IRS you really cannot tuck the wheels in. Good luck, very nice ride |
OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Thu Apr 17, 2014 11:18 am Post subject: |
Bobnotch wrote: |
OhHerrooo wrote: |
Carb cleaner will soften the glue from the stickers too. |
Thanks for the advice, bob. I believe the fronts are 155s and yes, they're on a 3" narrowed bug beam. I'll get under there this weekend and just see if 1 additional spline in back helps. Are there better wheels for lowered IRS cars with better backspacing?
chaosisme wrote: |
You can use acetone. It wont harm the paint. |
Perfect. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
www.evenkeelsurfshapes.com
Posted: Thu Apr 17, 2014 2:12 pm Post subject: |
eyetzr wrote: |
Thanks! What wheels would have better offset?
I had Gasburners on my 68, but it was swingaxle. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
www.evenkeelsurfshapes.com |
Posted: Thu Apr 17, 2014 7:34 pm Post subject: |
OhHerrooo wrote: |
Are there better wheels for lowered IRS cars with better backspacing? |
Fuchs. Im running stock width axles with no rubbing issues. 165's in the rear. I was actually thinking about going with a bigger rear tire but then I realized there are million other things my car needs so Im just going to leave the tires alone for now.
You could always run a bigger tire in the front too instead of those low profile tires. Im running Nankang 145s up front and Im pretty sure it has a taller sidewall than the Continental 155s. _________________ '65 1500 S [quareback]
'70 Westy
SBD Samba Member
Posted: Thu Apr 17, 2014 8:48 pm Post subject: |
If you can find a set of the factory 5.5" wide, 34mm offset Sport wheels from a 1974 "Sports Bug" (and you like the look of the factory sport wheel) they do a very nice job of tucking a wheel into the fender. I never tried it on a Type III but was able to put 205/50 15" tires on the back of a 1970 Ghia with no rubbing at all using a set of them (and Ghias just ain't got no room in the back fenders! ). Or just look for any wheel of comparable width with a 34mm offset and you should be in good shape. As long as the offset is the same it will center the tread of the tire in the same place in the wheel well. |
Posted: Fri Apr 18, 2014 5:15 am Post subject: |
OhHerrooo wrote: |
eyetzr wrote: |
I had Gasburners on my 68, but it was swingaxle. |
Keep in mind that the width of the IRS set up (inside the fenders), is the same as the long axle combination for 66 to 68 type 3s. This means that whatever rim and tire combo that usually worked for the early cars, does kind of work for the later cars, except for the extreme lowering treatment of the SA car (bent axle look). What I mean by that, is you don't get the extreme camber of the early cars when you drop the ass of an IRS car. You'll get somewhere from a 1/2 inch to a full inch depending on the number of splines. BUT, you have to watch tire width when dropping more than than 1 spine, due to the tire rubbing on the top inside of the inner fender tub (not the shock towers). BTDT had to raise it back up some.
Stock T-3 rim offset is 46mm, and you really need to stay close to that for stuff to work. I'm not saying you can't go with a different offset, but you just need to pay attention to it. You can even use the John J method of getting a little more outside tire clearance (not as extreme as Nate did ), so you can gain a little more room that way too. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Apr 18, 2014 9:29 am Post subject: |
Bobnotch wrote: |
OhHerrooo wrote: |
eyetzr wrote: |
Stock T-3 rim offset is 46mm, and you really need to stay close to that for stuff to work. I'm not saying you can't go with a different offset, but you just need to pay attention to it. You can even use the John J method of getting a little more outside tire clearance (not as extreme as Nate did ), so you can gain a little more room that way too. |
What's the John J method? I haven't been around in a while
I just looked up my wheels and they say they have an offset of ET45... so they shouldn't be changing my track width much, right?
I'm hoping to get under there this weekend and try lowering it another spline in back. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Fri Apr 18, 2014 10:45 am Post subject: |
OhHerrooo wrote: |
I'm hoping to get under there this weekend and try lowering it another spline in back. |
I tried looking for how much John moved his out (or some pics of it in progress (it's probably on his web site )), but I want to say it was 3/4 or 1 inch, which is right at the limit, as it starts to effect the front of the rear fender.
Nate took that idea, and went 3 inches.
Here's a pic of Nate's version. Keep in mind he really moved it out , and had to weld metal back in to both ends of the fender.
Quoting Nate from his thread; "I decided that I wanted to be more subtle with this set, so I bumped out the fender arches 3". This also forced me to have to extend the engine cooling air duct lip as well. The front bottom edge had to come out 3" or so to ensure and angled to the factory rocker width. The rear bottom edge had to be extended so that the rear edge of the wheel arch would cover the tire."
Pics of his mod are on page 19 of his "shop car" thread. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Apr 21, 2014 12:11 pm Post subject: |
Bobnotch wrote: |
OhHerrooo wrote: |
Pics of his mod are on page 19 of his "shop car" thread. |
I don't think I'll be going this crazy with it. I'm not too tied to the cosmics, so wheels with a better offset for being lower are definitely an option. Unfortunately I didn't get the chance to get under the car this weekend to try lowering it - that will probably happen this week.
I still can't figure out why my tach is sticking, though. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Apr 28, 2014 10:47 pm Post subject: |
OhHerrooo wrote: |
Changed the oil and gave the car a wash this weekend. Hopefully lowering the rear next weekend as the rake is really bugging me.
Are you missing a lugnut on each wheel? _________________ '65 1500 S [quareback]
'70 Westy
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3670 Location: San Jose, CA
Posted: Mon Apr 28, 2014 11:28 pm Post subject: |
They might be lock lug nuts. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
Posted: Mon Apr 28, 2014 11:42 pm Post subject: |
squaretobehip wrote: |
They might be lock lug nuts. |
Oh, that makes sense then. _________________ '65 1500 S [quareback]
'70 Westy
SBD Samba Member
Posted: Tue Apr 29, 2014 6:44 am Post subject: |
I'd be a bit worried about lowering the rear with that oil filter where it is. |
Posted: Tue Apr 29, 2014 8:54 am Post subject: |
SBD wrote: |
Yeah I'm planning on tucking it up and away before lowering it. A friend of mine offered to build a skid plate/enclosure for it as well.
That they are. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
