OhHerrooo Samba Member
Joined: September 12, 2010 Posts: 1291 Location: Costa Mesa, CA
Posted: Tue May 06, 2014 9:04 pm Post subject: |
Big day today.
1. bought an OG steering wheel that is in great shape to replace the plastic repop wheel that is in the car. someone had cut a notch in the top of the wheel... maybe for a suicide handle? regardless, I don't like the feel of repop wheels so I'm stoked on the purchase.
2. lowered the car 2 outer splines in the rear. the car isn't IRS either, it is swingaxle. this was a huge revelation for obvious reasons. short axle conversion will be happening in the next 1-2 weeks along with new axle boots and a front end exam.
got the car lowered and it is slightly cockeyed, so we'll be doing the appropriate math to level it out on friday. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
OCT3 - Orange County Type 3's
www.evenkeelsurfshapes.com |
Posted: Thu Aug 28, 2014 12:51 pm Post subject: |
OG wheel is in, car is leveled in the rear and front has been lowered to match.
Picking up a new ignition column tomorrow to replace my current one with the broken clamp and eliminate my vertical play in the column. After that, new front, rear, and rear 1/4 window seals with trim are in order. And relocating the oil filter.
'69 Squareback
'68 Westfalia
'68 Squareback
jecontreras14 Samba Member
Posted: Fri Aug 29, 2014 5:01 pm Post subject: |
what is the story with the back vents they look removable??? is there a part ### for the seal??? |
chaosisme Samba Member
Joined: August 29, 2005 Posts: 1256 Location: Orange County, Ca
Posted: Sun Aug 31, 2014 12:00 am Post subject: |
jecontreras14 wrote: |
Back in the day there was a recall for Fastbacks and Squarebacks that consisted of cutting out the original vents and installing new vents that faced the opposite direction.
I believe they were riveted in and didnt include a seal. _________________ '65 1500 S [quareback]
'68 FI Sunroof Squareback
'70 Westy
OCT3 - Orange County Type 3's |
Posted: Tue Sep 02, 2014 12:44 pm Post subject: |
chaosisme wrote: |
I believe they were riveted in and didnt include a seal. |
Correctamundo! _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
laszlo805 Samba Member
Joined: December 15, 2011 Posts: 110 Location: oxnard
Posted: Tue Oct 14, 2014 12:53 am Post subject: |
very nice car.
i would like to ask if you know were to buy the type 3 sticker that was going down the side of the i have been looking for one thanks for any help |
Posted: Wed Apr 01, 2015 2:40 pm Post subject: |
been driving and enjoying the car a lot lately. re-registered my black places from my peru green 68 to the 69. i also recently changed the oil and had a shop fix a fuel leak and install a new column to fix the vertical play i had. they also relocated the external oil filter a bit higher to keep it out of the way.
i've noticed a squeak coming from the passenger rear wheel as the car rolls. it has been around for quite a while but i've been working on fixing lots lately, so i want to nip this in the bud. it sounds like it is squeaking once per revolution but doesn't make really any noise at speed. anyone have any ideas what it could be?
super happy to have the car on the road and driving _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Apr 01, 2015 2:52 pm Post subject: |
OhHerrooo wrote: |
super happy to have the car on the road and driving |
Either the big axle nut needs to be tightened, the splines in the hub are wearing out, or the rear torsion bushings are shot but I'd think it's wheel related since it's tied to revolutions.
http://www.dailymotion.com/video/x1ptiu_beatles-revolution_music _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Apr 01, 2015 3:04 pm Post subject: |
Tram wrote: |
OhHerrooo wrote: |
http://www.dailymotion.com/video/x1ptiu_beatles-revolution_music |
perfect, i'll check the axle nut when i get home. _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
KTPhil Samba Member
Posted: Wed Apr 01, 2015 3:23 pm Post subject: |
Also check your hubcaps/springs, and try adjusting your brake shoes and ebrake. |
Bobnotch Samba Member
Posted: Thu Apr 02, 2015 4:39 am Post subject: |
OhHerrooo wrote: |
Tram wrote: |
OhHerrooo wrote: |
perfect, i'll check the axle nut when i get home. |
Also check the CV joint bolts, as Joe had them come loose and had a squeak from them. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Apr 02, 2015 10:41 am Post subject: |
OhHerrooo wrote: |
It ended up being the big axle nut - got it tightened to spec and threw in a new cotter pin. No more squeaking! |
If it comes loose again it's likely time for a drum (5 lug) or a hub (4 lug). _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Apr 02, 2015 6:04 pm Post subject: |
Tram wrote: |
OhHerrooo wrote: |
If it comes loose again it's likely time for a drum (5 lug) or a hub (4 lug). |
Good to know. I have some pulsing in the brakes, taking it in to get that checked out next week. Might need new drums to solve that issue (if they haven't been turned previously). _________________ '67 Squareback
'69 Squareback
'68 Westfalia
'68 Squareback
Posted: Mon Apr 06, 2015 10:57 am Post subject: |
Got the square detailed this weekend. Yes, I fixed the door trim right after this photo was taken. Dropped it back off at the shop this morning to get my brakes figured out.
Also notice the oil filter isn't hanging so close to the ground like it was in previous pics.
'69 Squareback
'68 Westfalia
'68 Squareback
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Mon Apr 06, 2015 11:13 am Post subject: |
Pretty low! How many inches to your beam? Lots of scrapes on it I imagine? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Mon Apr 06, 2015 9:04 pm Post subject: |
OhHerrooo wrote: |
Cool! And I won't even harass you about your tires.
OhHerrooo wrote: |
Yep, it's pretty low. 3" narrowed beam. Thankfully the Southern California roads are pretty smooth |
You must be in one of the few areas where they take care of problems. S. CA seems to be generally garbage compared to AZ/NM/OR/WA from the travels I've done. _________________ How to Post Photos
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Tue Apr 07, 2015 12:43 pm Post subject: |
OhHerrooo wrote: |
heck yea, this thing is nice! _________________ 1968 FI Squareback |
