63 Standard walk-through build
Stocknazi
Stocknazi is offline
PostPosted: Fri Apr 11, 2014 5:24 pm    Post subject: Reply with quote
It would be a sin to paint that bus; beautiful fade.
That dash looks nasty. I guess someone REALLY needed a speedo.
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
AirCooledClassics
AirCooledClassics is offline
PostPosted: Sat Apr 12, 2014 10:14 pm    Post subject: Reply with quote
Yeah ,don,t paint it it just increases it's value. just keep it faded and don,t fix the rust. and try to keep the smell of mouse shit and rotting natural fiber. Your wife will love that odor. Besides if you actually restored this it would reqire effort and talent. Sorry I just felt like a good Rant.Big project keep it up!
2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552
55samba
55samba is offline
PostPosted: Sat Apr 26, 2014 6:59 pm    Post subject: Reply with quote
Don't know if you noticed but in the last photo there was no rear frame. The previous owner cut it out and the half ass welded it in out of alignment and poorly attached. That was a major fix I had to accomplish. Now I have an engine compartment again. Then working on corners and wheel wells.
55samba
55samba is offline
PostPosted: Sat Apr 26, 2014 7:18 pm    Post subject: Reply with quote
On the dash front I am glad I held out and waited for what a I wanted, a perfect replacement section from a rust free us being cut up in CA. I also got the complete clutch and throttle guide tubes I needed with their original bends. The dash wont happen for a few months.
55samba
55samba is offline
PostPosted: Sat Nov 22, 2014 8:42 am    Post subject: Reply with quote
I could use some help please. It has been a while since I removed the damaged clutch and throttle tubes. I have good originals to go back in.
Question, the photo is of the bracket on the torsion housing next to the nose cone. Does the clutch tube go in the notch further from the nose cone or closer to the nose cone? Thanks
Mile High Puma
Mile High Puma is offline
PostPosted: Sat Nov 22, 2014 8:59 am    Post subject: Reply with quote
Hope these pics help:
1965 Velvet Green DC
55samba
55samba is offline
PostPosted: Sat Nov 22, 2014 9:54 am    Post subject: Reply with quote
Thank you, that tells me what I want to know.
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Sat Nov 22, 2014 10:07 am    Post subject: Reply with quote
You're always welcome to come take a look at my 63 for measurements if you need to!!
Looking good by the way!
Z
Z is offline
PostPosted: Sat Nov 22, 2014 6:34 pm    Post subject: Reply with quote
Nice bus and nice work so far. I once witnessed a guy yank a barndoor speedo pod out of a rusty junkyard bus by hand. I think he may have hit yours next...
Good luck!
55samba
55samba is offline
PostPosted: Thu Dec 11, 2014 4:20 pm    Post subject: Reply with quote
Yeh, someone really did a number on the dash. Probably Sasquatch...
On the bright side it is nice to see the back of my bus look like a bus!
55samba
55samba is offline
PostPosted: Fri Dec 26, 2014 11:20 pm    Post subject: Reply with quote
So in the photo above what you cannot tell is how much work I had to do in order to fit the replacement corners. The left side was the worst, I had to cut it into 4 pieces in order to make it wide enough. The wheel well side was not straight so I had to modify it. The engine compartment side was too tall so I had to cut it down, and the "flat" portions on each side were too round.
I have been very cautious to post anything about these since I don't want to piss Gerson off, I need him, we all need him! But Thom's postings helped me, it is what it is, you just have to make them fit.
On the bright side I used Eastwoods lead free body solder kit for the first time today. From my first attempt, give me a few trys and I think I can go bondo free. If I want to... But I have been dying to try.
55samba
55samba is offline
PostPosted: Sat Feb 07, 2015 9:29 pm    Post subject: Reply with quote
I need to post more updates. Cargo floors in. Cargo door bottoms replaced. Just installed the passenger dog leg.
Z
Z is offline
PostPosted: Sat Feb 07, 2015 10:20 pm    Post subject: Reply with quote
Nice work so far. It's gonna be a great bus.
55samba
55samba is offline
PostPosted: Thu Feb 26, 2015 10:42 pm    Post subject: Reply with quote
Left dog leg. My tip, install and adjust the doors to your old dog leg. Cut out the old dog leg, never remove the door. Then I tacked the inner panel side of the outer dog leg on and tweak the outer dog leg to fit. Then for the inner dog leg I test fit, hammer, dolly, bend, test fit and repeat till it fits without messing with the outer dog leg fit.
Schwing
Schwing is offline
PostPosted: Fri Feb 27, 2015 7:32 am    Post subject: Reply with quote
Beautiful work! I am tackling the rear end on mine too and I can tell that was many hours just getting it all happy. I appreciate you sharing those detailed pics.
My corners don't even exist below the tail lights so any reference pics are helpful. You did what I plan to do and thats align the bottom of the corner to the pressed line on the apron, seems logical. I have seen a lot of variances of this on the samba but your's seems right to me, considering the body lines.
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
55samba
55samba is offline
PostPosted: Fri Feb 27, 2015 8:53 am    Post subject: Reply with quote
My corners don't even exist below the tail lights so any reference pics are helpful. You did what I plan to do and that's align the bottom of the corner to the pressed line on the apron, seems logical. I have seen a lot of variances of this on the samba but your's seems right to me, considering the body lines.
I will get another photo of the rear corners. The rear corners do extend slightly lower than the apron, this is correct.
But at the end of the day you are best to align the wheel well arches together in the front to set your height.
Edit, before welding this in I scoured original paint but photos for days making sure since this seems counter intuitive but the corner to apron looks like this from my research.
55samba
55samba is offline
PostPosted: Mon Mar 09, 2015 6:12 pm    Post subject: Reply with quote
Replacing the entire dash, using the clip I posted before. I am using the y-tube heater from the new dash and installing it at the lower tube seam. That way I don't have to mess with how it welds to the dash.
For the windshield center post I installed a square tube that was a perfect tight fit. I then plug welded it to the original and replacement sides to make sure the post is, and stays, straight. I primmered it with weld through primmer...
I am installing everything well and basic grinding the welds. Once most everything is done I will finish everything, such as finish grind the welds along with hammer and dolly work in the body working phase. You can see in the corner that I replaced the front floor sides also. I installed the petal just to make sure they still fit, they do.
The bus wont be original paint. Too much rust and damage to replace.
earlywesty
earlywesty is offline
PostPosted: Mon Mar 09, 2015 6:32 pm    Post subject: Reply with quote
Nice work on the bus, its looking great. Do you recall what size the od was on the tube you used in the center post?
55samba
55samba is offline
PostPosted: Mon Mar 09, 2015 6:46 pm    Post subject: Reply with quote
Yes, 3/4 inch from Home Depot. It taps in.
earlywesty
PostPosted: Mon Mar 09, 2015 7:25 pm    Post subject: Reply with quote
thanks, i have a bus needing the same repair.
Page 2 of 6
