Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Thu Sep 19, 2013 2:36 pm Post subject: CV Joint Install Questions |
2WD rear axle, I'm installing new Lobro joints. The kit comes with a concave washer, and the joint supplier says it should go up against the shoulder on the axle. I see the Bentley makes a mention of the shoulder but no drawing. Guess, what? I don't have a shoulder on my axle, it's smooth all the way after the splines.
Any problems here? Just ignore the washer, lack of shoulder and move on? The old joint seemed to be fine that way before.
One more thing, these new cv joints are stiff as hell! I suppose that's a good thing and they quickly break-in for a bit more smooth operation?
Thanks!
msewalson Samba Member
Joined: September 14, 2009 Posts: 544 Location: Grand Junction, Colorado
Posted: Thu Sep 19, 2013 3:18 pm Post subject: |
Just ignore the washer. _________________ 87 Syncro w/EJ22 |
Syncroincity Samba Member
Joined: April 15, 2007 Posts: 1557 Location: New York City
Posted: Thu Sep 19, 2013 4:24 pm Post subject: |
New CVs are always very tight... makes it a pain to really get them greased well. Take your time packing them, make sure every nook & cranny is filled with grease before install. Clean excess grease out of the mounting holes with Q-Tips, you don't want ANY grease on the bolts. _________________ '86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight= |
bluebus86 Banned
Posted: Thu Sep 19, 2013 6:44 pm Post subject: |
yes that is really WRONG, you got the wrong axle there. You certainly need the curved washer. I have done my vanagons axles and they are supposed to have a shoulder on the axle, I used the curved washer there. I also have done my 914 axles (original German) and they did have a shoulder, and required the curved washer too..
The curved washer puts pressure on the cv joints, so that it is somewhat tensioned aginst the lock ring. with the shoulder and the lock ring you have to press the cv aginst the curved washer, partially compressing it, in order to fit the lock ring. this pretensions the cv aginst the lock ring.
What can happen without the curved washer is the cv is allowed to freely move on the splines, the cv will eventually pound its way into the lockring, and eventually pound the lockring off. that is the reason that it is supposed to be tensioned aginst the curved washer.
The CV MUST be pretensioned on the lockring to prevent any back and forth motion on the splines
Remember the CV will want to move back and forth on the splines as the axle moves with the suspension up and down, the CV joint is desinged to handle this in and out motion. If the cv is allowed to move in and out on the splines it will, and that is not good, I have found bent and banged up lock rings or lock ring grooves when the washer was not installed (or installed upside down). You must be assured the cv cant move back and forth on the splines.
I am certain you have crappy aftermarket axle(s).
I know that the EMPI aftermarket axles are junk, and they are much like what you have in the photo, I bought a set (complete with CV's attached) I returned them, the cv's were junk, (chinese made) they were packed with two different colors of grease (first clue something was wrong) (one joint had a bit of both types of grease) upon cleaning them I found the surface finish of the races was horribly rough, and the joints did move back and forth on the splines, no curved washer and no way to attach one, no shoulder!!!
I rejected them and ended up paying a bit more money for replacement LOBRO CV's that I installed on my original axles with the shoulder.
I took a look at my Bentely Offical service manual, there is a drawing of the axle, and it clearly shows a shoulder for the curved washer to rest on.
I dont know what version of the Bentely book you have, mine is the 1987 edition, the drawing of the axle is on page 42.7 clearly showing the shoulder, there is also a picture of the axle just above the drawing, again showing a shoulder.
also my book states....
Page 42.8
"Figure 6 Circlip/Constant velocity joint installing - press joint onto shaft until circlip can be pressed into groove."
The book tells us to "press the joint on to the shaft" that is because you are compresing the curved washer so that you can install the circlip. If you where not pre-tensioning the cv by pressing on the curved washer, there would be no need to press the joint on to the shaft, rather the joint would simply slip on and you would not need to press it to install the circlip. Figure 6 shows the press and special VW adaptor to do this pressing. Of course you can do this operation without this special tooling, but you still will need to press the CV aginst the curved washer before installing the lock ring. a suitable sized pipe and hammer will work if you dont have a press. you can actually press on the circlip with the pipe, then while pressing on the pipe, use a punch from the side to help seat the circlip
The design of the aftermarket axle with no shoulder is such that it does NOT satisfiy best engineering practice on how a splined part is supposed to rest on the stop (ie lack of any shoulder), the CV is just resting on the tiny bit of the end of the splines.
So what you now have is a poorly designed inferior aftermarket axle shaft, and a high quality German CV joint, the axle shaft is such that you can NOT correctly install the CV joints on it, the axle and CV will move back and forth, this will damage the spline ends and/or damage /break the lockring, which can leave you stranded.
I strongly urge you to find a used original German axle shaft. pull them off a wreck, do a classified ad, call a vanagon vendor (van cafe, Bus Boys etc.. what ever), get the right ORIGINAL axle shaft for the CV joint.
Then assemble the axle with the correct curved washer, check all tolerances, there must be no back and forth mothion on the splines refer to the Bentely book for the shaft diminsions. keep in mind that automatic transmission and manual transmisson vans use different length shafts, get the correct one.
Also if the curved washer is installed upside down, it wont pre-tension the CV aginst the lockring, and thus the CV will move and will bang up the lock ring, I have seen lock ring failures becuase the curved washer was installed upside down.
Sorry for the extra work you have to do, but getting the correct axle is the ONLY way to do this right |
Posted: Thu Sep 19, 2013 8:53 pm Post subject: |
tencentlife wrote: |
Every OEM Vanagon axle I've had in my hands has no ridge to support a conical washer and the washers are not used. The splines of the inner CV hub bottom out in the cut splines of the axle, that is the stop. Granted mine isn't a huge survey but the lack of a conical washer is also made clear in Bentley. The axle drawn on p.42.7 shows steps but there are none on any axles I've seen in use. There is no mention of a conical washer in the rear drive axle pages.
In the CV pictured above, the unsplined recess in the inner hub should not be there, the splines should be cut right to the face of the hub with only a slight angled taper at their ends, both sides. This is probably the cause of this axle being able to reach the flange cap and wear it down.
Conical washers are used on the inner CV's of Syncro front axles (p. 40.29) along with the spacer that resides in the front diff flange, but not on rears Syncro or 2WD.
Here's a pic of an '86 Syncro rear CV installed on the shaft, you can see there is no step, no washer, no gap where the splines mate:
Every Vanagon rear CV axle, early or late, I've had in my hands looks just like this one. Haven't seen a conical washer yet except on Syncro inners.
The thickness of the center hub of this OEM CV is ~27.8mm. It is bottomed on the axle splines, as you can see. The total length of shaft exposed on the free end is ~7.1mm. There is about 1mm free space between the clip and the outer hub face, so the length of splines out to the edge of the clip groove is ~28.8mm. The total length of the splined section is ~35mm. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Sep 19, 2013 9:06 pm Post subject: |
That concave washer is used on baywindow busses not vanagons(they share the same CVs). Throw it away. |
randywebb Samba Member
Posted: Thu Sep 19, 2013 9:29 pm Post subject: |
Syncroincity wrote: |
New CVs are always very tight... makes it a pain to really get them greased well. Take your time packing them, make sure every nook & cranny is filled with grease before install. Clean excess grease out of the mounting holes with Q-Tips, you don't want ANY grease on the bolts. |
my view is to then use brake cleaner and more Q-tips
because... you don't want ANY grease on the bolts or the internal female threads either[/b] _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu Sep 19, 2013 9:30 pm Post subject: |
GreenMachineVW Samba Member
Posted: Thu Sep 19, 2013 10:22 pm Post subject: |
Having six axles in the garage, I had to look. Five of the six are as above: no step, no washer, and no room for a washer. The sixth, on which I replaced the CVs with Lobros a couple of years ago, does have the step, and I did put in the washers, as there would have been play if I hadn't. Four of the five similar axles have the VW logo. The last, mismatched pair is still too dirty to see. The axle with the step is a no name one I got through a national parts franchise about ten years ago, as is the mismatched partner that I got at the same supplier, same order. |
Posted: Thu Sep 19, 2013 11:08 pm Post subject: |
randywebb wrote: |
because... you don't want ANY grease on the bolts or the internal female threads either[/b] |
I intentionally grease the bolts for my CV's. You want all the clamping force you can get. Never stripped or broke a bolt yet doing this. |
mr. c Samba Member
Joined: November 14, 2007 Posts: 153 Location: Black Hills, SD
Posted: Fri Sep 20, 2013 5:35 am Post subject: |
Wildthings wrote: |
I'm no expert but this seems like poor technique. If you use a torque wrench and tighten to the proper torque spec, you should not have any problems.
Greased bolts has never been a part of any mechanical design I've been a part of. _________________ Abe: 1987 Syncro Full Camper, TiiCo engine conversion, A3 pulley kit |
bluebus86 Banned
Posted: Fri Sep 20, 2013 9:32 am Post subject: |
whow, more Bentely confusion!!!! i guess VW made hese vanagons custom, with any parts they could find laying around.
anyway if your set up does not allow back and forth motion on the splines, then go for it, if however there is play that allows back and forth motion on the splines that is no good, as the locking ring can be damaged by this motion.
I know the aftermarket EMPI axles were inferior inpart becuase of the back and forth motion allowed by the design, my stock axles were of superior design. it could be inlight of this info above that your axles are stock , from a different batch and it could be they allow no back and forth motion as is. if so go for it, if not, figure out what you need to do to correct it.
i love my VW in a love / hate relationship, my 1986 van has so many in- consistancies with the contemporary bentely manual, wiring diagrams being amoung the worst. |
Snort Samba Member
Posted: Fri Sep 20, 2013 12:18 pm Post subject: |
OK, thanks for the input. I'm going to run with what I have and save the shouldered axle business for another life. Here's a shot of the joint installed, as described up above with the spline ends doing the work to provide the inner stop.
onemat Samba Member
Joined: November 17, 2011 Posts: 418 Location: Ashland City, TN
Posted: Fri Sep 20, 2013 2:37 pm Post subject: |
My appologies for hijacking this thread, but I also need axles and CVs for my '82 with 2.0 and 4 speed. Are the axles also known as 1/2 axles?
Lastly, what are the correct part numbers for my bus and where is the best place to order them?
Thanks,
Matt _________________ '82 Vanagon GL with 2.0 4-speed. Long term plan is to turn it into a camper. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Sep 20, 2013 3:36 pm Post subject: |
bluebus86 wrote: |
...my 1986 van has so many in- consistancies with the contemporary bentely manual, wiring diagrams being amoung the worst... |
Welcome to VW's take on a design transition year.
My '86 has the 2.1 WBX & rectangle headlights (of course) but the 1985 AC system.
My Bentley has three different wiring diagrams for '86's (camper, early & late)...
"Just keep running through parts until you run out of em..."
Back to topic: @ onemat: yes, a vanagon axle is a "halfshaft".
Any of the usual vendors can get you what you need (VanCafe, GoWesty, Bus Depot...)
Look in the stickies, ie: "Resources: Helpful Web Links" & FAQ's for specific links. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Sep 20, 2013 3:43 pm Post subject: |
mr. c wrote: |
Wildthings wrote: |
Greased bolts has never been a part of any mechanical design I've been a part of. |
Engineers typically specify the torque using the same kind of lubrication the fastener is most apt to have on it at the time of installation. For CV's most are going to have grease on the threads, so that is the correct lubrication, not dry, not lubed with motor oil, but lubed with MO2 grease.
The Bay window guys have the same argument, don't want to be over torquing those bolts, got to do it properly with dry threads. On the Bay though while their parts are pretty much identical to the Vanagon parts the torque is given at 24 ft*lbs, IIRC. Most Bay purist seem to like putting up with their bolts working loose from the number of threads mentioning CV's falling off. Being no purist, but someone who wants no problems out of my rigs ever if it can be avoided, my Bay gets torqued to 33 ft*lbs with grease on the threads just like my Vanagons. No problems with bolt breakage, stretching, or loosening on either Bays or Vanagons ever, or on any of the Type 1's I have had over the years. |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Fri Sep 20, 2013 3:55 pm Post subject: |
On my 91 automatic one axle had the shoulder and washers, the other did not. It had been on there a long time. I don't think imminent failure will occur if when you press the CV on the axle and it is seated at the end of the spline, if there is very little play available once the retaining ring is installed. If your axle has a shoulder it was designed for the washer and the washer should be utilized. |
boof1306 Samba Member
Joined: July 10, 2010 Posts: 304 Location: MELBOURNE AUSTRALIA
Posted: Fri Sep 20, 2013 3:57 pm Post subject: |
You will never achieve correct torque on any bolt without lubricant. Even Loctite acts as a lubricant on initial install. For the record I torque my cv bolts(10.9 grade non allen key) to 37ftlbs / 50nm. No stripped threads, no broken bolts and no issues off road in a syncro. |
Durk Samba Member
Joined: February 08, 2010 Posts: 14 Location: Kalispell, Montana
Posted: Sun Nov 17, 2013 3:58 pm Post subject: |
I have a couple of questions about cv joints and axles after installing new Lobros on one axle of my '84 2WD today. Are original VW axles stamped with the logo, and if so, where? Couldn't see any markings on mine, but obviously most of the shaft is rusty. It did not have shoulders. What it did have inboard of the old cv joints, though, were concave washers, but they had grooves on the inside that mated on the splines and kept them from sliding right up the shaft like the concave washers included with my new joint kit from Van Cafe would do. I understand that these new washers are useless with the non-shouldered shafts. I tried the fit with the grooved washers and the new joints, but the fit was too tight to get the circlip on. Does anybody know about this type of concave washer that can conceivably be used on the straight, non-shouldered shaft? With no concave washer inboard of the joint there is a small space, about 1/16", between the inner race and the circlip. Is this gap ok? I know you don't want much space there to avoid hammering.
Thanks. |
roscoePcoaltrane Samba Member
Posted: Wed Dec 28, 2016 6:51 am Post subject: Re: CV Joint Install Questions |
I had a cv go out on my 85 Westy automatic...ordered a pair of EMPI from GW. They indicated they were ungreased. The looked schmacked together smeared with some type of grease. Not impressed...I could not find the grease "packet" supposedly included or discern which was the inner or outer joint.
When removing the axles, I marked inner/outer, right/left. I am tempted to send them back and go with the lobros I have read about on Samba.
thanks
I appreciated any feedback _________________ 1985 automatic subyvanagon
daily driver |
