ibjack Samba Member
Joined: February 06, 2002 Posts: 2106 Location: Imperial Beach CA
Posted: Sat Sep 27, 2014 2:22 pm Post subject: |
avesondm wrote: |
I've been checking, tightening and cleaning. I don't want to be the one with issues this time. |
I think we are all in the same boat. I'm glad you will be going this year. _________________ '68 Lotus White T34 automatic sunroof
'64 Manila Yellow T34
'65 Sea Blue Square Panel
the1500club.com
Shop Lacky at the T3/34 Factory, https://www.facebook.com/profile.php?id=100094313902074 |
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Sat Sep 27, 2014 2:23 pm Post subject: |
KTPhil wrote: |
JeeJeeJason wrote: |
Anyone want to help me throw some spring plates on the back while at a rest stop? |
No, but I can bring my Peiseler 261 protractor tool if you want to give it a go in Cayucos. |
Just playin' Phil.
Just did my run down and tightened everything up in the engine bay. Good thing because some clamps on my fuel lines were super loose. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Sat Sep 27, 2014 2:53 pm Post subject: |
Me, too. I fixed the whistling genbelt. I replaced the belt with an un-cogged version, and also replaced the pulley with one bought from another Samba member-- less wear/grooves that might have made some noise.
Still worrying about the very recent presence of an oil light at idle. Hasn't done that in many years and now I'm driving 500 miles in two days.
Wish me luck, fellas, I may need it!
Posted: Sat Sep 27, 2014 3:00 pm Post subject: |
KTPhil wrote: |
Me, too. I fixed the whistling genbelt. I replaced the belt with an on cogged version, and also replaced the pulley with one bought from another Samba member-- less wear/grooves that might have made some noise.
Wish me luck, fellas, I may need it! |
You'll be fine I'm sure. . See all you guys there !
It would be nice to have a few numbers to keep in touch and find out where everyone is along the way until we all meet up. PM me if you'd like to keep in touch or shoot a few texts that day. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Sep 27, 2014 5:49 pm Post subject: |
KTPhil wrote: |
Is it at hot idle- and does it go out as soon as you blip the throttle? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
reay Samba Member
Posted: Sat Sep 27, 2014 6:35 pm Post subject: |
Drove mine to the Solvang Show today. About 75 minutes from my house. At times I was a nervous wreck and other times relaxed and really enjoying the cruise.
On the way home the wind was blowing 15-25 mph. I took a back road for a while, but eventually got back on the freeway. The car did really well in the head and side winds. (Glad I wasn't in my 66 Bus!)
When I got back to San Luis Obispo, my oil light was flickering a little as well. A small tap on the accelerator and it went away. I'm sure it was pretty warm. Would a different oil make a difference. 10-40? My motor is a low compression 2074cc stroker with 400 miles on it.
Back to the rally and temperatures:
On the Friday cruise, it will be a medium speed cruise uphill to Paso. 55 mph max. Most of the climbing will be at 35-40 mph max. It will be in the high 70s on the way up. On the way down, it will be in the low 90s. Really nice VW weather! (According to the 7 day forecast).
For some reason, the forecast for Cayucos next weekend is a high of 86 on Saturday! Wow- If that holds, it will be pretty amazing. _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
Posted: Sat Sep 27, 2014 6:45 pm Post subject: |
Sounds like your cars going to do great on this drive Tom. What a way to break that engine in.
I filled my car up after checking all connections etc in the engine bay and took it on a 20 mile cruise earlier. Noticed that it's leaking a bit of gas when full near the top of the fuel filler neck. Any ideas? I'm hoping it's an easy fix but the suns going down here so I'll have to check tomorrow when I can see better. |
squaretobehip Samba Member
Joined: August 23, 2004 Posts: 3692 Location: San Jose, CA
Posted: Sat Sep 27, 2014 8:43 pm Post subject: |
Noticed that it's leaking a bit of gas when full near the top of the fuel filler neck. Any ideas? |
Check your overflow hose. Might be old and brittle. In fact, all those rubber parts in that area should be checked and/or replaced. _________________ 1963 Notchback - Ruby Red
1963 Squareback - Pearl White
1965 Squareback - Baltic Blue
Follow ISP West on:
Instagram - @ispwest - www.instagram.com/ispwest |
KTPhil Samba Member
Posted: Sun Sep 28, 2014 10:40 am Post subject: |
Yeah, inland forecast for SoCal is in the low 100s! Coast will be better, but if it's the santana winds, the coast will be warm, too. Paso hills can be very hot. But it's cooling off at night, so morning drives will be cool and nights a bit nippy. |
Posted: Sun Sep 28, 2014 12:17 pm Post subject: |
squaretobehip wrote: |
Check your overflow hose. Might be old and brittle. In fact, all those rubber parts in that area should be checked and/or replaced. |
That's what it is. It's a bit cracked at the bending points. I may just replace it with some vinyl tubing instead of rubber in hopes that won't break down as quickly. |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Sun Sep 28, 2014 4:23 pm Post subject: |
dangit ill be in southern cali on the 9th-12th...if i was able i would come sooner and say hello since i wont be anywhere near my t3. ill be at the next rally for sure.
notchboy (Jason) said ill fit right in...and he said to warn you all im coming to join in on the type 3 crowd..... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
KTPhil Samba Member
Posted: Sun Sep 28, 2014 5:44 pm Post subject: |
Jim Adney sells a kit that solves this problem better than OEM. |
Posted: Sun Sep 28, 2014 10:38 pm Post subject: |
KTPhil wrote: |
Can you post a link please? Can't find anything on it |
Posted: Sun Sep 28, 2014 10:47 pm Post subject: |
Well, I won't be there but half the skin on my knuckles will. Be sure to stop by and say "Hi". _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Sep 29, 2014 3:40 pm Post subject: |
OC/LA people! We'll be meeting off the 405 at Palo Verde @ 4AM on Friday morning. Yes, 4:00AM. From there we'll be heading up the 405N to the 101. If you'd like to meet us at any point along the way, please post up on here or message me and I'll give you my cell phone number. That way if you're trying to meet us but run into a problem just call me or shoot me a text and we'll know to hang out for a few. For example, if you'd like to meet us off of the 405 at Palo Verde but you're running 10 minutes late, we'll know to wait 10 minutes instead of just leaving you behind.
See you soon! _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
KTPhil Samba Member
Posted: Mon Sep 29, 2014 9:29 pm Post subject: |
ETA for the 101/23 interchange in Thousand Oaks? |
Posted: Tue Sep 30, 2014 7:50 am Post subject: |
KTPhil wrote: |
It looks like it's around 60 miles or so, so I'd say between 5-5:30AM? _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
KTPhil Samba Member
Posted: Tue Sep 30, 2014 8:27 am Post subject: |
KTPhil wrote: |
It looks like it's around 60 miles or so, so I'd say between 5-5:30AM? |
Sounds about right. Shoot me a txt when you are at the 101/405, and I can catch you along the 101 about 20-30 minutes later.
Planning on any stops along the way, or a straight shot to Cayucos? |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
Posted: Tue Sep 30, 2014 9:21 am Post subject: |
KTPhil wrote: |
KTPhil wrote: |
Probably just gas and what not. _________________ 1963 Notchback - Ruby Red
Follow ISP West on:
