Porschedave Samba Member
Joined: July 01, 2004 Posts: 454 Location: Vancouver, Canada
Posted: Fri Jan 24, 2014 10:13 am Post subject: |
Good morning Dwayne
Thanks for the reply. I would like to have a picture from below of the transition of the rocker to the front curved portion to the straight run to the back. Looking at the pictures I posted, at the front end, the track that sits on the pan is 2" wide. Does it stay 2" all the way to the back corner? Also, on the front curve piece, there is a lip and I assume that carries all the way to the back as well. Can you confirm that and perhaps take a picture for me?
And secondly, what happens at the back corner? Does it just run straight to the back and stop where it intersects the cross member?
Thanks for helping.
Dave _________________ 1977 911S
1958 Karmann Ghia build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=571683
1965 Sunroof Notch build thread here: http://www.thesamba.com/vw/forum/viewtopic.php?p=5600139&highlight=#5600139 |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sat Jan 25, 2014 12:42 am Post subject: |
I just posted 9 photos to the Ghia coupe section of the gallery. Hope they help you figure out what you need to know |
Posted: Sun Jan 26, 2014 9:58 pm Post subject: |
You are welcome Dave, Its all about the love of the Vdub |
Posted: Tue Feb 25, 2014 4:41 pm Post subject: |
Hi Folks
I've been a bit distracted and work on the Ghia has been slow. But here are a couple of updates - work in progress. First, I am working on repairing the passenger side rocker. I've looked at the sites here and everyone has a different solution, depending on the amount of damage. For me, the outer skin needs replacing as well as the internal strengthening section and the mounting plate. So, I am building my own. Here's the cleaned up area.
And then a section to be welded in.
And now trying to fit the new skin and the inner fender piece.
The fit is not great - yet. I'll have to do some more trimming before I start welding. Oh, and while I was working on this I knocked out a piece of filler along the back fender. Take a look at this wrinkle and repair.
I'm off to Germany this weekend and will get a factory and museum tour while in Osnabruk. I hope to see some old Ghias.
To be continued ...
Posted: Fri May 02, 2014 9:26 am Post subject: rocker repair |
Hi Folks
Finally managed to get some time ont he Ghia this week, mostly removing metal. I thought I'd show these photos for those who haven't seen a rocker in pieces. The first shows the pieces as I separated them after drilling out the welds and the second shows it all clean.
I didn't want to replace the whole thing since the inner portion is still in good shape and it would be less likely that the body would twist.
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Fri May 02, 2014 9:46 am Post subject: Re: rocker repair |
Porschedave wrote: |
Hi Folks
Dave |
Wow Dave, you've been moving right along on this project. It's looking good. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Fri May 02, 2014 11:26 am Post subject: |
Looks great Dave!
Trevor _________________ 1968 porsche |
ScottDoonan Samba Member
Joined: August 04, 2005 Posts: 546 Location: Northern California
Posted: Fri May 02, 2014 2:22 pm Post subject: |
Very nice work, stay at it. Rockers are not fun, but as you know they are a very essential part of structural integrity. With good rockers set right, a lot of other repairs can be made easier, fitment is more symmetrical and measuring points a bit more accurate. _________________ If you take time to do it, do it right and don't be so damn cheap.....🤙🏻
1959 Karmann Ghia Cabriolet (current restoration)
1965 Porsche 356 SC coupe
1967 Volkswagen Convertible Beetle
1969 Porsche 911E Targa 3.2 twin plug
2006 Porsche 987 Rüf 3400K Prototype #2 of 2 |
Posted: Wed May 07, 2014 8:47 pm Post subject: |
"LIKE" _________________ 1968 porsche |
Posted: Wed May 07, 2014 9:14 pm Post subject: |
after rebuild
before rebuild
hope this helps |
Loren Samba Member
Posted: Wed May 07, 2014 9:30 pm Post subject: |
Here is what I started with on my Ghia
Here is the same section after the body guy fixed it. |
Posted: Thu May 08, 2014 10:50 am Post subject: |
Hi Loren and Dwayne and others
On this piece inside the front fender, sitting behind the wiring harness pipe runs, is there a special purpose for the shape behind the pipe? It seems to me that this could be a flat piece rather than this fancy curved bit. It does not appear to help air flow up the tubes and certainly wouldn't be there to flow air up behind the door jam. Making it flat would make my repair easier. Your thoughts/experience would be helpful
Thanks.
Posted: Thu May 08, 2014 10:54 am Post subject: |
Dave, the bend is because the wire harness is coming from above and the tube is bent up to meet it. There is a grommet that goes over the end and seals the tube.
Danny at Gab Fab makes the tube with the bend and the flared tip. |
Posted: Thu May 08, 2014 11:19 am Post subject: |
Dwayne
Thanks - that helps. Another question, if you are looking to the front from inside the rocker (ya, I know that's difficult) how large or what shape is the opening for hot air into that section at the junction with the door jam? I think that where the wiring harness passes through it is closed - I think I can see that from one of your photos. But I am not sure about the opening for air since and I have to make a new section, I don't want to make the opening too small nor too large. Maybe you have a photo of that section.
Thanks.
Posted: Thu May 08, 2014 11:28 am Post subject: |
The wire tube runs in the rocker section outside of the heater channel so I am not exactly sure what you are asking. |
